Incomplete Review: XTAR WK30. Once the review's done there will be a giveaway.
28 posts / 0 new
Don
Don's picture
Last seen: 1 year 1 month ago
Xtar WK30
Reviewer's Overall Rating: ★★★☆☆Copy and paste, maximum ★★★★★
Xtar WK30
Summary:
Battery: If it is 14mm in diameter and around 50mm long it'll probably work
Switch: Reverse clicky
Modes: The usual 5
LED Type: Cree XP-E Q5
Lens: Feels like glass to me
Tailstands: Yes
Price Payed: List price US$39.99. SZWholesale say $15.96 plus shipping
Date Ordered: March 2011
Pros:
  • Type 3 hard anodising.
  • Comes with a spare switch and two spare O rings.
  • Comes with a useful keychain attachment and a lanyard.
  • This one won't roll.
  • Very durable finish.
  • Reverse polarity protection.
  • Well put together.
  • Available in seven colours
  • Nice gift box and presentation.
  • Can't see any PWM even on low.
Cons:
  • The head and body don't line up perfectly when the head is fully tightened down.
  • Claimed maximum voltage is 3.2V though I've fed it 14500's with no trouble.
  • There are rings in the beam. White wall hunters are likely the only folks who'll be bothered by this.
  • I'd like it better without any flashing modes.
Features / Value: ★★★★★
This was provided for free by SZ Wholesale (Who seem to be the main distributor for XTAR lights). Once this review is finalised, I'll be giving the light away as is my policy for review stuff. If I like it enough, I can buy my own one.
At the list price of $39.99 it isn't a very good deal to me. However, from the SZWholesale link above, it sells at $15.96 plus shipping. Unless the shipping is silly expensive I'd give this one 5 stars. I'm giving it 5 stars assuming it can be had for $20-22 delivered. At $40 I'd only give it three stars - at $20 I'd say it is an excellent deal. It is now available from szws here for $20 in three colours. At that price it richly deserves five stars for value.
http://budgetlightforum.com/node/2355
It has the usual five modes but no detectable PWM flicker. As an aside since most of Europe's AC power is 50Hz as opposed to the US/Japan's 60Hz, Europeans seem to be much less sensitive to flicker than Americans.
I like the hexagonal body design - you put it down and it isn't rolling.
The package is rather nice.
Packaging
The upper box is the WK30's one, the lower the WK20's. Ignore the CR123 which came with the WK20 for review.
It comes with some nice extras. A spare switch is unusual. The two spare O rings are very good to have, the handmade lanyard does little for me but the crab claw keychain attachment is very good.
Extras
I have no way of testing whether or not the finish is Type 3 anodising or not, but the light spent a month attached to my work keys so I can vouch for the durability of the finish.
There are a small number of marks visible on the tail end after a month of sharing a pockets with keys, coins and all the other stuff one keeps in pockets. The marks round the switch retaining ring were my attempts to remove it to play with the replacement switch.
Tail end
The head end also has a few marks. With my normal usage of lights, none of these marks would have happened as I don't normally put anything bigger than an AAA light on a keyring.
Head end
One good feature is the reverse polarity protection. A wrong way round battery isn't going to do bad things to the driver. The black foam ring at the base of the head has a hole for the battery's + contact. A wrong way round cell can't complete the circuit.
The head
It is a pretty big light as AA lights go. It is a couple of millimetres longer than the Trustfire F22/Yezl S5 but smaller in "diameter"
Size comparison
WK30, Yezl S5, Trustfire F22 (A replacement for the much-loved lost one), Trustfire R5-A3, Uniquefire S10 singlemode, Tank007 E07, Zebralight H50 and an XTAR WK20 whose review will be up soon. All but the last one are AA lights.
Design / Build Quality: ★★★★★
The design is a matter of taste. My taste doesn't like the extra engraving. I like plain and simple.
?vines
Beloved!!!!!
This bit's OK
If they'd just left it with the XTAR logo I'd have liked it more. The build quality is very good. The only niggle I can find with it is that if you screw the head down hard, the head and the body do not line up.
It gets the five stars for the hexagonal body and the build quality, most emphatically not for the extra engraving. It may appeal to some, but doesn't to me. Some appropriately coloured filler would fix that easily enough. If the engraving bothered me more, I'd give it 4 stars.
Battery Life: ★★★☆☆Copy and paste, maximum ★★★★★
Current Draw:
Battery TypeHighMediumLowStrobeSOS
NiMH
Alkaline
Li Primary
NiZn
LiFePO4
14500
Runtime graphs to follow:
Alkaline High
Alkaline Medium
Alkaline Low
Light Output: ★★★★
The reflector is pretty deep for an AA light and has a narrower beam than many AA lights. On the left, the XTAR on a 14500, on the right an Ultrafire C303 on medium. As you can see the beam is relatively narrow. Both are tailstanding on top of a door 60cm from the ceiling.
WK30 and C303
The beam on its own.
WK30 Beam
I need to add results from LiFePO4 cells which arrived last week. I also need to add throw numbers, which I am sure I have already done, I just can't find the numbers.
  Lightbox luxLightbox luxLightbox luxEst. LumensEst. LumensEst. Lumens
LightBatteryTurn-on30 secs2 MinutesSwitch-on30 secs2 Minutes
Xtar WK30 HighNiMH386353333696360
Xtar WK30 MediumNiMH144142140262525
Xtar WK30 LowNiMH343434666
Xtar WK30 HighAlkaline418356324756458
Xtar WK30 MediumAlkaline157152143282726
Xtar WK30 LowAlkaline353535666
Xtar WK30 HighLi primary338327320615957
Xtar WK30 MediumLi primary123120120222222
Xtar WK30 LowLi primary373635766
Xtar WK30 HighNiZn441428424797776
Xtar WK30 MediumNiZn176175173323131
Xtar WK30 LowNiZn474747888
Xtar WK30 High14500976888854175159153
Xtar WK30 Medium14500317310303575654
Xtar WK30 Low14500767575141313
Some outdoors beamshots.
It wasn't all that dark but I was in urgent need of sleep. It was, however, a lot darker than these pictures make it seem. Living in a city with plenty of light pollution and rapidly lengthening days, we don't get all that good-quality darkness round here till around the end of September.
I'm not working this weekend so will do better pictures later at night.. The white balance is locked on daylight so I also used an outright yellow light (Mega warm designed for jewelry inspection) for comparison.
Control
Control
Strange jade inspection light. According to DX this is a very warm bin Cree XR-E P4. According to my lightbox it puts out just short of 100 lumens at switch on, down to 70 after a couple of minutes. It gets hot.
Strange yellow thing
WK30 High
WK30 High
WK20 High This is an XP-G as is the Ultrafire C303
WK20 High
Ultrafire C303 High
C303 High
WK30 Medium
WK30 Medium
Ultrafire C303 Medium
C303 Medium
WK30  Low
WK30 Low
WK20 Low or medium. It is a 3 mode light with high, less high and strobe.
WK20 Low
Ultrafire C303 Low
C303 Low
The level spacing is good at 175 / 57 / 14 lumens on a 14500, 69 / 26 / 6 on an NiMH. This is not the brightest AA light, but performance is respectable on 14500 and perfectly acceptable on NiMH where it is in the same ballpark as the Tank007 E07 but is much throwier.
Summary: ★★★☆☆Copy and paste, use rounded average, maximum ★★★★★
I like this light a lot. It will be given away, but I think I might well get myself another one. My rating is absolutely dependent on the shipped price. I'm expecting it to be available for $20-22 delivered. If it is at the RRP of $40 I'd not be interested. SBFlashlights are selling it for a little over $40 shipped.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Edited by: Don on 05/07/2011 - 04:46
Don
Don's picture
oldbobk wrote:
 Been a few years since my high school Latin. Could ya do it in English? My real question is, how do you like it compared to a Trustfire R5-A3?
It's probably nearly as long since mine. That is just placeholder text until I get around to writing the body text. It doesn't actually have any meaning. For some reason, printers have used that text for centuries.
Here's what Google Translate makes of it. "Hello world! is love, consectetuer adipiscing elit, make it hidden by contributing authors tincidunt administer and pain _PN_OF. Be added to by trivial example, whichof us ever undertakes the army tation ullamcorper lobortis nisl when some from the selection below. Edit or the normal models upon vulputate News, products, and / orpain good to him easy, but to no feugiat eros and but a heap and to hatred of the justwho upon gentle with a ready Sample a different zzril delenit a Sample duis feugaitthere is no pain you easy. This is text for us at the time when the feeble Thinking ofnothing option congue imperdiet mazim Domingo that which is roasted at the can I doto please. Where can I get some? is the use of the reader is in them that makes their splendor. The investigations showed the son of the readers to read me, they read that they very often too. The brightness of the process is also dynamic, which follows the custom of a change of the bed. It is a wonder to note than the Gothic alphabet, which they now do we think a little clear, anteposuerit of letters the form of humanity through the ages of the fourth and the fifth of the tenth to the tenth. In the same way types, who is now famous for it seems to us a little, they become a feast in the time to come."
I like the light more than the R5-A3 but it isn't as bright. The XTAR on a 14500 makes 175 lumens, the Trustfire 292 (Both are initial switch-on figures). The modes on the XTAR are better spaced. I have to do the throw numbers - I thought I'd already done them.
It is better built than the Trustfire and the switch is more usable though it is similar in design.
sb56637
sb56637's picture
Last seen: 21 hours 58 min ago
Hey Don, looking good. Lucky! Want to trade for a nasty yellow color WK30? Wink But it's good to know we are "Beloved".
This is a pretty nice light, I'm just having a hard time getting over the ugly color and engravings.
edc
edc's picture
Last seen: 6 years 1 month ago
Interesting! I like the shape.
http://i1193.photobucket.com/albums
Don
Don's picture
I like the light. If I can get a blue or grey one for $20 shipped I'll buy my own. For me, that is the real test of a review light.
KDLST
Last seen: 6 years 10 months ago
Nice rewiew so far!
Davx
Davx's picture
Last seen: 5 years 9 months ago
Nice light. I like the different shape. Maybe the beam is too narrow.
"There are always new jobs, women, and apartments......there is only ONE BLF." - Chicago X (27/03/2012)
fran82
Last seen: 11 months 3 weeks ago
Nice review and nice flashlight. However it would be better if it had a completely round body instead of that "hexagon" shape....
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Don
Don's picture
It seems to work for me - there are beamshots now up. Not great ones, but they show the beam clearly enough.
Don
Don's picture
Actually, one of the reasons I like it is the body shape. That one isn't rolling off of anything. I suspect the WK25 is rather similar internally and has a nice round body - i rather like the look of it.
fran82
But Don, It is comfortable in your hand?
Don
Don's picture
It is, it is quite a large light for a single AA - I have some pictures of it with other lights to upload when I get back home to a faster (and much less expensive) internet connection.
It is about 2mm longer than the very large Trustfire F22/Yezl S5, though about 1mm less in "diameter". I do not have large hands and find it comfortable to hold.
fran82
One curious thing:
I know that, to make a flashlight with normal round shape, you only need a lathe. But... How do they make this rare shaped flashlight in the factory?
I think they must invest many time in mechanizing the body... probably they begin with a round tube.... the start mechanizing and they get this thing?..... I dont know
Oldienea
Oldienea's picture
Last seen: 6 years 6 months ago
Aluminium rods are availible in various shapes. They probably made it out of a hexagonal raw material.
Don
Don's picture
Or got hexagonal tubes cast. If you are making enough of them, this might be cheaper.
fran82
mmmmm I thought that only were available round aluminum tubes. Never knew about hexagonal shaped alu tubes. Now I understand. Sorry
Buwuve
Buwuve's picture
Last seen: 4 years 6 months ago
Thank you Don for the review and the lux/lumens of all the different batteries.
I like it, if things are a little bit special and different to many other products. Most flashlights are round - a hexagon form could be nice.
Nice flashlight in blue (I love blue).
Light up the darkness.
how2
Last seen: 2 weeks 3 days ago
At $40 It's expensive but if it was available for $20 including shipping then it would make a great gift light
KDLST
I really like the look too. The hexagonal shape is a warm welcome from the normal shaped flashlights and i really like the blue color. Too bad it's a bit pricy
Langcjl
Langcjl's picture
Last seen: 3 years 7 months ago
I like the hex shape, nice to have something a little different. I reapply like the beam though. I probably wouldn't have thought about that one before I saw those.
Piers said " ....but who wants enough light, when you have the option for far too much "
mfm
Last seen: 10 months 1 week ago
Actually Japan has both 50 Hz (Eastern Japan) and 60 Hz (Western Japan).
Don
Don's picture
I didn't know that. It must complicate their grid managers life considerably.
Budgeteer
Budgeteer's picture
Last seen: 8 years 1 month ago
Nice review! Glad to find out i was not the only one thinking of it as a good one. I hear ya, blinkies could be hidden at least otherwise a very likeable flashlight.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
SirJohn
SirJohn's picture
Last seen: 8 years 3 months ago
Has anyone been brave enough to find out some actual shipping costs on this yet?
mfm
The "handling fee" if you buy for less than $200 is 30% of the order or $6 (whichever is the highest).
discord
Last seen: 9 months 6 days ago
The light looks bright, but it has what appears to me to be a yellow tint on hi. I think I'd have to see it in person to determine whether I like the tint, or maybe its your camera?
devman
I've heard it's a bit worse than that, since the earthquake took out the reactors.  They can only move something like 1 GW between grids?
http://www.itworld.com/business/140626/legacy-1800s-leaves-tokyo-facing-...
Don
Don's picture
Not to my eyes. The first pic after the control shot is from an ultra-warm light designed for inspecting jade and jewellery. It certainly is very yellow, the next pic is the WK30.
