Texaspyro's Handmade Multi-Emitter DIY Contest Entry
81 posts / 0 new
panthervision23
Last seen: 7 years 8 months ago
Good mod! I miss the golden and silver eras of rock when I heard this LED Zeppelin track.
texaspyro
Last seen: 2 years 2 months ago
I did a little more testing at 7 amps/220 watts. It heats up rather fast. The fan is going full blast after a minute or so. It starts going into thermal stepdown after a couple of minutes. Seems to level off at around 6 amps/180 watts.
Mattaus
Mattaus's picture
Last seen: 6 months 3 weeks ago
Looks like a an lamp lol. Outdoor shots PLEASE!
I'm sorry if this has been covered before, and I must admit I am being lazy, but how does this compare to say - the amount of MT-G2's (or XM-L2 etc) that you would need to have an equivalent output?
I mean - are discreet emitters like that more efficient than these arrays, and if so would it be a better bet to use multiple emitters rather than one large array? I'm thinking here of the drop LED efficiency as the input power increases. More LEDs at lower power > less LEDs at higher power.
MASSIVE generalization of course, but I think you can understand what I'm rambling on about...maybe Undecided
texaspyro
Mattaus wrote:
but how does this compare to say – the amount of MT-G2’s (or XM-L2 etc) that you would need to have an equivalent output?
I mean – are discreet emitters like that more efficient than these arrays, and if so would it be a better bet to use multiple emitters rather than one large array?
The MTG2 is a multi-emitter array. Arrays are more efficient than single emitters because each LED is driven less hard than an equivalent single emitter. The C9000 has 81 (?) LEDs in its array. When driven at its published drive level, each LED is around 1 watt.
fishmaniac
fishmaniac's picture
Last seen: 6 years 10 months ago
That picture of it next to the srk cracks me up!
Try not to get arrested by ATF when taking outside beamshots. lol
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 2 days ago
Awesome! Can't wait for beam shots!
'So much flood even Noah would despair'.   LMAO!
Mattaus
Mattaus's picture
Sorry I screwed that question up. I'm not really sure I asked it correctly. I definitely got my terminology wrong. Basically, for the same power input would you get more light out of say multiple MTG/XML/XPG etc emitters, than one of these larger arrays? For some reason I have always been under the assumption that these large arrays are not as efficient as their smaller cousins. Probably wrong and certainly never based of any actual research Laughing
DB Custom
DB Custom's picture
Last seen: 22 hours 37 min ago
You could try one of these bad boys in a car mounted light mattaus, boost voltage to 30 and turn the night into blazing daylight! The voltage requirements would seem to be the problem from what I can see. Output is certainly impressive! But with heat sinking and input power being what they are, you’re certainly not going to run this in a pocket light!
The beast Texas Pyro made is ~13 inches wide and ~18 inches tall with a 4” diameter battery tube! “Flashlight” is not really the descriptive word of choice…Photon Cannon?
Also of note is run time before step-down, even fan cooled. So this shows that massive heat sinking in combination with air cooling or liquid cooling would be a must for extended run times at anywhere near full power.
texaspyro
Added a couple of beamshots to post 4…
MRsDNF
MRsDNF's picture
Last seen: 1 month 5 days ago
I wondered what all the strange light action was on the horizon. Your latest pictures explains everything. So how many people did you blind?
Chazzy
Chazzy's picture
Spectacular wall of light! 8)
"Whoa that's a bright light!" ... Yea I guess.
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 2 years 5 months ago
Absolutely awesome!
Please make a youtube video about it and hopefully we won't have to look at this one any longer Tongue Out
https://www.youtube.com/watch?v=NkkU0UO3sek
FmC
FmC's picture
Steve_the_Chief wrote:
Absolutely awesome!
Please make a youtube video about it and hopefully we won’t have to look at this one any longer Tongue Out
Yes, if possible, pls make a short video, possibly with some other baseline lights for comparison Smile
Beer Beer Beer Beer Beer
texaspyro
None of my cameras that work do videos… and my phone is an original iphone…
scaru
scaru's picture
Last seen: 4 years 9 months ago
None of my cameras that work do videos... and my phone is an original iphone...
Jailbreak it and use cycorder (allows you to take videos with it).
texaspyro
Added materials and tools and comments to post 4…
DB Custom
DB Custom's picture
My camera does full HD 1920×1080 at 24 or 30 fps. It’s full frame sensor with a 17mm lens would easily show how awesomely wide the beam is. Would be cool to have a football field to use, or even a baseball field. We could go on top of one of the east side skyskrapers and light up Justin over in Tyler, have him wave at us for the video. lol
relic38
relic38's picture
Last seen: 3 years 8 months ago
That’s a beast, pyro. 180W sustained is impressive. 20,000 lumens is quite the light fixture (I’m thinking high bay). You have a portable version, even if it only operates for a few minutes until the battery depletes. Smile
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
texaspyro
Actually, should be able to run it for around an hour. Maybe 20 minutes or so of full-ish 210 watt output before the battery voltage falls enough for the light to start dropping off. Thermal control would have kicked in before that and reduced to drive to around 160 watts.
DB Custom
DB Custom's picture
for a photo session! Portable sunshine, impressive indeed! I have a light stand that will go up to 13’ 6”, that would get this monster up high enough to light a very nice area for shooting pics, seniors, family portraits, midnight sunbathers…
