Email sent, once I get the list is it ok if I post it here? It would make it easier for everyone else to look through it.
Here the list is:
Parts inventory.doc
EMITTERS
Luminus
SST-50 7 bare new
1 drop- in new tested no Dvr
SST-90 3 on HS new
SBT-90 1 bare new tested
CST-90 2 on copper HS new tested
CSM-360 1 on copper HS new tested
Cree
XM-L T6 22 on HS 16mm Al HS new
XM-L U2 2 drop- in smo new installed, tested, removed
XM-L U3 9 on 20mm star Al HS new
XM-L2 U2 2 12mm Al HS new 1 installed & tested, removed
XM-L T6 X 3 1 on reflector
DRIVERS
5 amp
6V – 13V 2
3V – 18V 2
5V – 12V 5
7 amp
6V – 15V 1 new tested/install & removed
9 amp
6V – 12V 1 new
6V – 15V 3 new
6V – 15V 1 new tested/install & removed W/contact spring & partially potted
Buck/Boost
3V – 18V 3 new
AMC71380 3040mAh 12 new
AMC71350 2.8amp 3 new
AMC71350 2.8amp 1 new tested/install & removed
AMC71350 350mAh 4 new
Super Output Driver
5V – 15V 3 amp 4 new 3 mode L/M/H
3.2V – 4.5V 3.5 amp 1 5 mode new
9 LED 3 Lion dvr 1 new
XM-L T6 Dvr 3.7V – 4.2V 2amp 10 new
Cree XM-L T6 emitter Led Driver 2 new
XM-L T6 2500~3000mA, 4.5~18V, 3-Mode Regulated LED Driver 9 new
FLASHLIGHT
TrustFire 1200 3 x XML T6 1 new (driver removed-piece of crap)
FLASHLIGHT TUBES
Cree C8 1 new
Sun C8 size 4 new
Sun C8 size 1 new (Lense collar scratched bad)
UltraFire 501A 2 new (shinny black)
UltraFire 501B 4 new (shinny black)
UltraFire 502B 1 new (flat black)
TrustFire 1200 3 new
REFLECTORS
64MM X 63MM SST-90 smo 1 new
64MM X 63MM SST-90 smo 1 new (emitter hole hand filed to fit Luminus CSM-360)
41mm x 58mm XM-L smo deep 2 new
41mm X 57mm XML/Q5 smo deep 4 new
52mm x 30 mm SST-50 smo 2 new
52mm x 30 mm SST-50 op 2 new
36mm x 31mm XM-L/SST-50 4 new L-OP
42mm x 37mm emitter hole 9mm (SST-90 ?) 2 new OP
42mm x 30mm XM-L 5 new SMO
36mm x 30mm XM-L 1 new SMO
35mm x 32mm XM-L 4 new OP
26mm x 27mm XPG 3 new OP (threaded external base)
31mm x 20mm XM-L 3 new OP
42mm x 37-38mm SST-50 2 new OP
25mm x 20 mm XM-L 4 new OP
27mm x 14.5mm XM-L 4 “ :
28mm x 24mm XM-L 3 new SMO
3x XM-L reflector cups only 1 new SMO
3x XM-L 24mm dvr port 1 new SMO
3x XM-L 19mm “ “ 1 new SMO
LENSE
3 x LED lense 2 new
28mm glass lense 4mm rim 1 new
28mm glass lense 1mm rim 1 new
BATTERY
SECONDARY/RECHARGEABLE
Used
18650
Many Laptop pull-apart, 18650 many 2amp in decent to good condition. Some 2.5mAh.
Laptop PA are difficult to ID, most appear to be Sony, Sanyo, Samsung & some Panasonic
Primarily want to sell 2 AMP+ bats. If anyone wants 1800mAh have those also
ID Capacity Qty Cdtion
PANASONIC 2000mAh 4 good
CGR18650A
SAMSUNG
2000mAh 2 good
“ 2200mAh 7 good
“ 2600mAh 10 good (a few nicks in bat skin)
SANYO
18650F 2400mAh 6 ok (some skin damage, but fair)
18650A 2150mAh 5 good (1 has skin nick)
SONY
18650GR G5 & G6 2200mAh 38 good (a few may have skin nicks)
18650GR G7 2400mAh 11 good
18500
BRC 18490A 1550mAh 4 2 in a pack 2 PA (skin marred w/scratches)
18500 1400mAh 3 new
CMICR 18490F 1300mAh 2 good
New
TrustFire 5000mAh (4000mAh actuall) 25650 protected 2 new
TrustFire 5000mAh (4000mAh actuall) 25650 2 new (these 2 bats protect circuit removed they look bad,
but are just as new as 2 above)
Moli 4000mAh 26650 2 new (have tabs glued to + end) beyond initial function tests & tab gluing
Keygos 4800mAhh 2 new (have tabs glued to + end) these have never been used.
TrustFire 14500 900mAh 2 new
FandyFire 14500 900mAh 2 new (must use caution & reason with any…Fire battery)
TrustFire 14650 1600mAh protected 4 new
TrustFire 10440 600mAh 8 new (4 w/tabs 4 w/o tabs 2 have tabs glued on)
ULTRAFIRE
BRC 18650 3000mAh 2 new (remove protect circuit)
BRC 18650 3600mAh protected 2 new
“ “ 4000mAh “ “ 2 new (1 remove protect circuit)
PRIMARY/NON RECHARGEABLE
Duracell
CR2 exp date 03/2017 11 new
223 exp date “ “: 5 new
245 “ “ “ “ 6 new
Energizer
2450 exp date 03/2019 2 new
MISCELLANEOUS
Voltage regulators
LM 1084 adj 5A LDO 5 new TO-263
LM 1085 adj 3A LDO 4 new TO-263
LM 338T adj 5A 9 new TO-220
AMC71350 or 71380 (believe to be 380mAh) 13 new
Switches
Gilt spring switch 13 new
Clicky 11mm 8 new
MCPCB
20mm star XM-L 8 new
16mm round XM-L 5 new
14mm round XM-L 13 new
20mm star SST-50 4 new
16mm round SST-50 4 new
13mm “ “ 5 new
50mm 3x SST-50 2 new (intended to go with 3 x LED lense above)
32mm 3 x LED 4 new (black) Not sure which emitter fit these boards
24mm 3 x LED 5 new (white) Not sure which emitter fit these boards
Drop-ins (no emitter)
P60 reflector, 2 springs, pill 5-10
