Review: FandyFire/SolarStorm K2
Date ordered 2013/07/07
Date received 2013/07/15
Price paid $25.43 after 5% BLF discount
From Fasttech
Manufacturer/Vendor Specifications
Emitter XM-L U2
Lumens 890
Modes High > Med > Lo > Strobe > SOS
Tail-cap current 2500 mA
Battery 18650 w/sleeve, 26650
Switch Reverse clicky, glow-in-the-dark
Lens Glass
Dimensions 129mm X 41mm X 41mm
Reflector diameter: 3.6 cm
Head diameter: 4.1 cm
Tube diameter: 3.9 cm
Weight 215 g
Reviewer Specifications
Driver 46mm
Tail-cap current
Battery Button top 18650 w/sleeve, button top 26650
Protected or unprotected
Modes Low -> Medium -> High, hidden strobe & SOS, no memory
Switch side reverse clicky w/o half press, green backlighting
Lens AR glass
Anodized threads Yes
Tailstands Yes
Lanyard Yes
Dimensions Length: 128 mm
Head: 41 mm
Tube, grip: 37 mm
Tube, tail-cap: 39 mm
Weight 194.5 g
Pros:
  • multiple battery choices
  • high quality anodization
  • tailcap lockout thanks to anodized threads
  • hidden blinkie modes
Cons:
  • low isn't nearly low enough
  • spill isn't that wide
  • battery tube o-ring isn't tight enough
To follow: lux meter readings, wall shots, mcpcb measurement, pictures of pill/driver/mcpcb
Images
The light arrived packaged in a box with foam protecting the sides and bottom of the flashlight. This did a good job of preventing damage, which makes this one of my very few lights to arrive without any nicks or scratches to the anodization.
I was hoping to show off the anti-reflective coating, but I haven't figured that out that trick yet. At the 1 o'clock position you can see a minor blemish on the bezel.
A contact plate without a spring means flat top batteries might not work. A protected button top Keeppower 26650 fits with room to spare both vertically and horizontally, and this is a big cell, so this light should work with any 18650 or 26650 with a button top. Anodized threads here mean that tail cap lockout is possible.
Battery Fitment
Cells tested:
Cell Results
Panasonic NCR18650, 2900 mAh, unprotected, flat top Works.
MNKE IMR26650, unprotected, button top Works.
King Kong INR26650, unprotected, button top Works.
King Kong ICR26650, unprotected, flat top Does not work.
Trustfire flames ICR26650, protected, button top Works if battery tube o-ring is removed.
Keeppower ICR26650, protected, button top Works.
Construction
It has almost no flaws at all, and the only flaw I could find was on the edge of the inside of the bezel. Magnets are not attracted to the bezel.
The XM-L U2 is perfectly centered thanks to a centering ring. The reflector doesn't have any dust or fingerprints, and it sits behind a lens with an anti-reflective coating.
The rest of the body is aluminum and claims to have HA-III anodization. The threads are anodized, smooth, and came with a coating of thin oil.
The head has flats that help prevent the light from rolling, but attaching a diffuser will make the light roll easily again.
The inside of the battery tube is anodized, has an ID of 27mm and accepts a button-top protected Keeppower 26650.
None of the o-rings glow, but they are as thick and meaty as the o-rings on the real Sky Ray King. The o-ring for the battery tube is thick, yet loose, that care much be taken to make sure that it seats correctly. The o-ring seems to cause flickering when using Trustfire flames 26650's, which are my longest cells, but it works fine if the o-ring is removed. While the o-rings don't glow, the side clickie is backlit while the light is on.
The switch is a reverse clickie with hidden blinkie modes that are accessed by turning on the light and then holding down the switch.
The lanyard hole is in the side of of the battery tube, which allows a lanyard to be used with little to no chance of affecting the ability of the light to tail stand.
The build quality falls somewhere between the oLight S10 and the real Sky Ray King. If it had a metal switch, I'd rate it just below the SRK by the slightest amount. The UI of the oLight S10 is far superior to both the K2 and SRK.
As far as disappointments, it's using an XM-L U2 when XM-L2's have been around for a while. The modes feel nicely spaced, but it can really benefit from a much lower low.
Light output
The color is cold, and when indoors I see a little purple. It looks fine outdoors though. The beam profile reminds me of the BLF A8. It has a tight hot spot and when holding the light at my side, the spill starts a few feet in front of me. The low mode is very high even for night hiking.
Compared to the HD2010, it has less spill, but the spill contains more light. It doesn't throw as far or as tightly. The picture below was taken on a humid night over a creek, so the throw was limited by the environment. I think the HD2010 will throw much further on a clear night.
Compared to the BLF A8, it has more spill and the spill contains more light. The BLF A8 is much warmer, and its tint should be NW. The K2 has a much tighter hotspot than the BLF A8 and can throw much farther.
Low and medium has PWM.
Beam shots: Distance to the front of the bridge is 25 meters, the end of the bridge is 160 meters, and the shrubs behind the curve at the end of the bridge are 225 meters away.
Here's another set of beam shots.
First, the testing venue showing the distances taken for each shot:
The HD2010 is branded with the Ultrafire logo, and came from Tmart back when the East92 drivers were all direct drive. The light is unmodified aside from greasing the threads. The HD2010 is powered by a King Kong INR26650.
The SolarStorm K2 is also powered by a King Kong INR26650 is these beam shots.
SolarStorm K2 vs. Ultrafire HD2010 @61.45 meters
SolarStorm K2 vs. Xeno e03 @61.45 meters
SolarStorm K2 vs. Ultrafire HD2010 @89.04 meters
SolarStorm K2 vs. Xeno e03 @89.04 meters
SolarStorm K2 vs. Ultrafire HD2010 @162.51 meters
SolarStorm K2 vs. Xeno e03 @162.51 meters
reserved
Fasttech diffuser, SKU 1347101.
The diffuser/wand for the Xeno e03 casts a very even glow that made me fall in love with diffusers. This is now Xeno e03 diffuser. While it diffuses light, it allows the hotspot through because it doesn't have a thick tip like the Xeno e03 diffuser. The advantage to this silicone diffuser is that it compresses very well. It still diffuses light, and is well worth the $1.12 pricetag.
Nice shots. Thanks for the effort.
bump…
Rosebud.
Nice! Do you have an EA4 to compare it to?
Reserved.
Nope. That would've been a good comparison.
Reserved. :smiley:
That’s alright, looking forward to your review!
I'll add some pictures later today. It'll be a while before it's done since it's my first review, and I'll need some time to figure out how I want to do things.
Have you measured the tailcap current by chance? Hows she run?
Looking forward to the full review.
I have one on the way from DX for review. I also have the EA4 and D40A for comparison. I don’t expect it any time soon, China Post isn’t the fastest delivery method.
Worst movie EVER. |(
Crap, all reservations are gone :bigsmile:
I see, more and more people like my 360° view :bigsmile:
P.S. Nice light, thanks for review.
omg pointing the light at the compass is a great idea. very clever leaftye!
Also, reserved for something…
I don't know yet. I need to make some thick leads. I've been working on too many projects lately.
It's a very great idea, but it's not mine. I borrowed it from a reviewer here. I need to do the same thing with my other flashlights to make sure the images represent the beam pattern well. I'm totally fine with sharing ideas among reviewers so that everyone benefits from better reviews.
I received mine last week, and will post my review soon. My bezel is SS (strong magnet barely attracted to it), finish is very good.
Is the O-Ring on the body too loose and is difficult to get to stay in place when putting the light together? Mine is very loose and needs to be guided when putting it together. Very obvious, as it will pinch every time if I do not watch for it.
Yeah, the o-ring is loose. I commented about it above. I think it might be causing my light to resist turning on when I use it with a Trustfire flames 26650, but I've been noticing flickering without the o-ring and with shorter cells. Does your light flicker too? I'm wondering if my light has a bad ground. I hope to pinpoint and fix this when I start modding.
My bezel is barely attracted to a 165 pound magnet. That was with the bezel on though, so it's possible it was attracted to something else within the head. I didn't notice any attraction with a stack of 12.7 pound magnets. I'll test it again when I pull apart the head.
