10A CC/CV buck converter for led tests...
25 posts / 0 new
viffer750
Last seen: 4 years 10 months ago
I got this from ebay: http://www.ebay.com/itm/181089352568?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
1
It’s a nice little buck converter, very good for testing leds and flashlights. If you have a power supply which is strong enough, you can build a voltage and current controlled test PS with a lot of potential for pennies. It’s not for professional use, but the ability of the converter is enough for a lot of tests. The efficiency is very good, does not generate too much heat, it can work without any additional  heatshink. I tested it at 30-40W for a long time, and the warmest components were only 50-60°C.
tested at 7.16A:
2
at 60Watt:
3
unique engrish language... Smile
mattthemuppet
Last seen: 8 months 2 days ago
cool! Is that a passive GPU heatsink I see in the first test picture?
comfychair
comfychair's picture
Last seen: 5 years 8 months ago
WANT Love
viffer750
yep, a zalman zm80d-hp Smile
mattthemuppet
damn, that’s a seriously fancy LED test bed heatsink Smile Takes me back to the day…
comfychair
From a quick glance at the 'DC power supplies' category I spotted this: http://www.ebay.com/itm/130949993786
Only 2A capable, but for an actual application instead of test bench use, could be perfectly adequate. In particular I'm thinking of my current project using those '10W' 10-12v square LEDs for car interior lighting, and not really being happy with the typical 12v AC/DC drivers commonly used.
FlashPilot
FlashPilot's picture
Last seen: 2 hours 54 min ago
2A would be great at 12-15V. Interesting find, and the price is certainly reasonable. Perhaps you could drive 2 of those 12V square LED’s in parallel @1A each. I wonder if that device could withstand voltage spikes while the car is running?
tivo532
tivo532's picture
Last seen: 7 years 1 month ago
comfychair wrote:
From a quick glance at the ‘DC power supplies’ category I spotted this: http://www.ebay.com/itm/130949993786
Only 2A capable, but for an actual application instead of test bench use, could be perfectly adequate. In particular I’m thinking of my current project using those ‘10W’ 10-12v square LEDs for car interior lighting, and not really being happy with the typical 12v AC/DC drivers commonly used.
Nice one too! Can this be operated/wired in parallel? 2 to get 4A max? or 4 to get 8A Max? Beer
A Buy it now is around $1.54.
tivo532
tivo532's picture
This seller has 10pcs 2A for $12.26. I’ll buy a set and will try. Beer
ryansoh3
ryansoh3's picture
Last seen: 1 month 1 week ago
I guess this doesn’t apply too much for LED’s, but watch out for current spikes.
When we’re driving laser diodes, it was a PITA to find power supplies that would be noise free.
BLF ≠ B-grade Flashlight Forum
dave_
Last seen: 10 months 3 weeks ago
They are clearly not made for this. If you do it, please add a proper fuse! (So if the chip dies and shorts out it doesn’t test how long your wiring can withstand the short circuit current of your battery+alternator. ;-))
comfychair
So what IS the proper way to run one of those 10W LEDs in a car?
FlashPilot
Id like to know as well…
relic38
relic38's picture
Last seen: 4 years 3 weeks ago
Comfy, why not use the driver you have, or the other one I posted about in your thread? They should work in a car just fine I think, unless I’m missing something.
Tivo, that’s a great price on those modules! Putting them in parallel could be a problem. Make sure the output voltages match before connecting them together. Not sure if they are protected from reverse current flow.
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
comfychair
The drivers I have don't take kindly to the heat. In stock form they're just OK, but with an added resistor to get the output up from 700mA it starts flickering and not behaving nicely, and a 0 ohm resistor added in parallel with the original only upped output to 900mA. I would like something more robust.
tivo532
tivo532's picture
Yes Relic! Number one in mind.
As for power supply, I remember I having this 12V/35A!
Beer
relic38
relic38's picture
The one I tested had no flickering problem. Left it at 1A for 15 minutes or so. The chip got to 85C. Moght be worth a try, I think the larger components handle heat better and are more efficient.
sorry for sidetracking this thread Smile
Welcome the night.
dave_
The needed protection circuit is neither expensive nor complicated and looks usually somewhat like this:
-Choke to filter out high frequency noise which can irritate your regulator
-Transient voltage suppressor Diode to limit voltage
-Fuse to limit current if TVS diode triggers or something else happens
-Diode to block negative voltage spikes
That’s about the minimal protection for devices that are allowed to be powered with running engine.
Sirius9
Sirius9's picture
Last seen: 11 hours 33 min ago
Cr@p, doesn’t ship to my country, and we are neighbours!!!!
I would like DC-DC converter which I could adjust from about 0.90V to 8.40V with one fine potentiometer, doesn’t have to be 10A, 3A would suffice.
ryansoh3
ryansoh3's picture
I have something like this: http://www.ebay.com/itm/Green-LED-volt-meter-DC-DC-Step-down-Converter-Regulator-combine-2-in-1-/390401987125?pt=LH_DefaultDomain_0&hash=item5ae5c59235
Works pretty well, and I have added a cap to the output to smoothen the output current.
Sirius9
Sirius9's picture
Saved in my watch list Smile
relic38
relic38's picture
Sirius9. DX and FT have what you want. Voltage and current can be adjusted by trimpot. They seem to work well. They look very similar to the ones in the eBay links.
Welcome the night.
viffer750
Sirius9, choose one  Smile :
 http://www.ebay.com/sch/i.html?_odkw=DC-DC&LH_BIN=1&_sop=15&_osacat=117000&_from=R40&_trksid=p2045573.m570.l1313.TR10.TRC0.A0.Xconverter&_nkw=converter&_sacat=117000
viffer750
poor man's mini power supply, about for $30 Smile
1
not a beauty, right? Smile
but...
2
About 14-15A max current Cool,of course not for so long time. The little converter is very robust.
above 100W...
3
The bottleneck is the laptop power supply, the protection kicks in at about 105-110W. This is enough for almost everything.
Unfortunately there is a little problem with the current regulation. If the voltage is set to a high value, and if I connect a power led to it, the initial transient can kill the led, even if the current is set to a not too high value. So before I connect a led to the power supply, I have to check and set the voltage to a desirable value, this is below 5V in case of a single xm-l.
Apart from this, it is a very useful "tiny monster" power supply. :)
MRsDNF
MRsDNF's picture
Nice build viffer 750. Very creative.
