Review: Protected NCR18650B from Wallbuys
6 posts / 0 new
Milan
Last seen: 1 day 32 min ago
Cells arrived “professionally” packed in 2 pink rubber iPhone cases. I’d still prefer a normal 18650 case though.
Cells were at 4,17 after some rest when fully charged.
I believe if I used lower termination current and lower discharge values, I could squeeze out the last 100-200 mAh. The last 100 mAh is probably not there or very hard to reach. At voltage below 3V, direct driven flashlights will only glow.
So these are obviously genuine unused batteries since no other cell has such capacity nowadays.
Short circuit protection works and resume immediately.
Tried high load at 4,25A so the cut-off is higher.
Maximal diameter is 18,7mm.
Lenght is 70mm sharp including the button.
PS I will publish an internal resistance chart where you can compare different batteries later.
Edited by: sb56637 on 08/26/2014 - 17:45
_the_
_the_'s picture
Last seen: 5 days 10 hours ago
Thanks for the review!
Milan wrote:
Cells arrived "professionally" packed in 2 pink rubber iPhone cases.
Just like my last two shipments of NCR18650As. Laughing
Now I've got four pink iPhone 5 silicone cases and four purple iPhone 4 cases. Hmm.. Maybe the next giveaway.. Wink
..but the price was good at $13.21 - $1.32 w. coupon WBQYMONSTER = $11.89 (for 2 pack => $5.95 each), so I'm not complaining. Smile
Ps. The same coupon seems to work also for those NCR18650Bs, bringing the price down to $15.83 for 2 pack ($7.92 each) - not bad at all.
=the=
bgyen
Last seen: 2 years 1 week ago
That’s how my TF 26650 came packaged. Sandwiched in-between two pink iphone cases. I beleive mine were in a yellow envelope as well (with yellow tape all over – I think they do that to give the envelope extra resilience). I got cases labelled 5G. I don’t have an iphone, so they’re not too useful to me.
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Thanks for the review.. I have bought 4 of these from WB. I have not done any technical testing, but they seemed to perform as good as my other NCR18650B from various sources.
WB had the best price I had ever seen when using 10% coupon. Price was slightly lower when I ordered.. At the moment FT is cheaper when using 5% coupon code.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
southland
southland's picture
Last seen: 4 days 11 hours ago
Just ordered 3 pairs/6 of the protected Panasonic NCR18650A earlier today. Over $5 cheaper than Fastech, 6 cells for less than $35. With Fasttech if you use the quantity price, you can’t use the discount code. With Wallbuys you can use the quantity price and discount code together.
sb56637
sb56637's picture
Last seen: 1 hour 2 min ago
Thanks a lot for the review! Frontpage’d and Sticky’d.
