Test / Review: UltraFire ICR123A 3.0V 800mAh (Green)
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 18 hours 32 min ago
DSC_2575
Official specifications:
  • Battery Capacity (Mfg Rated): 800 mAh
  • Battery Chemistry: LiFePO4
  • Battery Feature: Rechargeable
  • Battery Form Factor: CR123A
  • Battery Rated Voltage: 3.0 V
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-info
When I got the battery I wondered what it was, it is marked with ICR, this means LiCoO2 chemistry and the capacity must also be LiCoO2 to get anywhere near the rated capacity, but the text on the battery says charge to 3.6 volt and the specification says LiFePO4 (Letters for LiFePO4 is IFR). The testing shows it is a LiFePO4 battery.
Note: CR123 size is the same as 16340 size, i.e. this battery can also be called a 16340 battery.
DSC_2572 DSC_2574
DSC_2576 DSC_2577
DSC_2578
DSC_2579
I am not impressed with the spelling.
DSC_2580
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-Capacity
The actual capacity is way below the rated capacity and due to the LiFePO4 chemistry the voltage is about 3 volt.
Do not expect 16340 sized LiFePO4 to have much more than this capacity.
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-CapacityTimeHours
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-Energy
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-PowerLoadTime
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-TripCurrent
UltraFire%20ICR123A%203.0V%20800mAh%20(Green)-Charge
On the charge curve it is very easy to reconize a LiFePO4 chemistry, the voltage drops from 3.6 to 3.4 volt when charging is terminated.
Conclusion
I do not like the wrong markings on the cell (i.e. ICR) and the overstated capacity, the actual performance is average for this type of cell.
Notes and links
CR123A and rechargeable substitutes
Edited by: sb56637 on 08/26/2014 - 17:45
sb56637
sb56637's picture
Last seen: 1 hour 18 min ago
Thanks a lot for the review! Frontpage’d and Sticky’d.
