XinTD X3 - a close-up look (Updated with mod details)
34 posts / 0 new
Tom E
Tom E's picture
Last seen: 1 hour 23 min ago
I'm not sure if anyone has mod'ed one yet, but I started  on a mod to change out the emitter/star to possibly U2 1A or 1C on a copper star, boosting up amps to 4.5A, and custom programming the driver to modes I want. I felt compelled to post what I found so far.
Update 08/18/13: See post #5 for details of the mod and the test results!
Here's the product listing: http://intl-outdoor.com/xintd-x3-xml2-3aa-flashlight-p-739.html
Here's a review in progress: http://budgetlightforum.com/node/23362
I'm impressed with the light, the look, solid feel. I'm not happy it's not just a standard 26650 form factor, but has extra width with no provided spacer for a 26650 cell. I ordered mine with the T3 warm white LED, which I really like. First thing I did was put in a King Kong ICR 4200 and did measurements:
  694 lumens at start, 666 at 30 seconds, throw of 36 kcd
The throw # is impressive for under 700 lumens, so this is why I decided to pump it up and see what I can get out of it. As leaftye pointed out in his review, it's a unihead construction, making working on the star difficult because you have to work down into the head. Coming stock with an aluminum star is a shame for a light of this caliber. Here's some pics of the break down.
Here is a view of them empty pill, driver removed:
Notice the depression in the center - was thinking of adding full width copper discs, but that is a big hole:
Here's where it gets strange. The pill top is nice and thick. The surface under the star is polished. I found a iPhone/iPod repair kit that had the perfect size star driver to fit the screw heads that secure down the star. For some unknown reason, they used an epoxy instead of grease under the star, Below is the removed star. It took some coaxing to get it out, specially at a angle with no leverage (straight down) but eventually gave way.
Here's a view of the head:
The bump of epoxy is caused by this:
Note in the photos above, I cleaned up the surface of the pill top by removing the epoxy (maybe fujik), then cleaning with iso. alcohol. The scratches are from the screw driver and pliers I was using to try to remove the star.
Now that hole is directly under where the emitter is mounted on the star. I measured it roughly at 1.2 mm deep, which is deeper than the hole on the underside of the pill. Why?? Why would they kill such a good design? Is it easier to machine this way?
I'm sooo disappointed now, but my plan is using a 20 mm Noctigon, though I'm considering mounting the Noctigon on a copper disc to get a bit more thermal transfer out of it, though the height may be an issue. I'm thinking it will take a lot of AS5 to fill that hole, so maybe for a filler, I'll use some copper filings I've been collecting, mixed in with the thermal grease.
Another thing is they obviously didn't use enough thermal epoxy to even completely fill up the hole, or for that matter, didn't use enough to cover the full alum star contact surface.
For a good quality, not so cheap light, I'm a bit disappointing finding this kind of deficiency. I'll pm Hank with a link to this thread so he knows. Maybe it's not that bad once you fill the hole and use a Noctigon - I'll find out.
Edited by: Tom E on 08/25/2013 - 12:00
MRsDNF
MRsDNF's picture
Last seen: 3 hours 52 min ago
Tom E. Thanks for starting this thread on the mod. Its almost laughable the way this has been machined. I’d suggest that the light was designed however and given to the machine shop to build without them having proper instruction. They have machined the light to the best of their ability and tooling they had to get the job done. How thick is the material the star sits on?
Pulsar
Pulsar's picture
Last seen: 4 months 2 days ago
that big divot is disappointing to see...
Tom E
Tom E's picture
I'd say the pill top is about 4 mm thick. Overall, the pill has a lot of mass for the size of this light.
MRsDNF
MRsDNF's picture
If you had access to a lathe I would machine it flat and fill the gap with a piece of copper. Good luck with whatever you decide.
Tom E
Tom E's picture
Finished the mod. here's some steps along the way:
I took a small piece of household copper wire and flattened it to fill the void. Thinking it's better than wasting all that AS5 in the hole
I piled up the AS5 in the center, hoping it will fill the void and spread out under the star - I think it worked based on how much came out after it was screwed down - nott too much but a little sign of it coming out.
Here's the Noctigon secured down with the stock screws
Here is a view showing the size compared to some popular lights, including it's little brother:
Closer view with it's brother:
Here's a close-up with my 2 favorite cells at this time:
Sorry, I don't have pics of all of this, but here's the full details of the mod:
  • IS XM-L2 U2 1C on a Noctigon
  • sanded pill top, sanded w/2500 grit the Noctigon bottom, AS5, copper to fill the hole, stock screws to lock it down
  • Qlite stock 3.04A driver with 4 380's added, total of 4.56A
  • kept stock 22 gauge wires
  • copper braided both the driver spring and tailcap spring
  • the tailcap spring is small, looks cheap, and spring was not hard connected, so soldered the spring to the switch contact
  • Nyogel on the threads, may have used CRC 2-26 in contact surfaces or points
  • re-programmed the QLite driver to have 8 modes (based on Dr. Jones' luxdrv):
                    turbo(100%), high(56%), med(32%), lo(6%), moonlight(value of 5), low moonlight(value of 4), strobe, battery check/beacon
Test Results
  • freshly charged King Kong 4200 ICR, amps: 4.26A 4.56A measured at the tail (Note: new 14 gauge DMM leads)
  • Light Output in lumens:  1,469 at start  -  1,448 at 30 seconds
  • Beam Intensity (Throw): 76 kcd
Notes
  • now the lumens #'s seem high, higher than my fully mod'ed HD2010's I believe, and I re-tested the HD2010 and got same results as previous
  • the throw # is somewhat expected, I suppose - mod'ed out C8 I get 45-50 kcd, HD2010's 90-100 (re-measured mine at 92 kcd)
  • also what should be noted is how well it holds the lumens during the 30 secs. This light has excellent heat sinking with a thick pill top, thick amount of aluminum in the critical pill area, and it's one piece. So my guess is the dimple under the star didn't hurt much, whether because of the AS5/copper fill, or that there's enough surface contact between the star and pill and secured down by screws, making a very good bond.
  • it's not the easiest light to mod because of having to work on the emitter/star by going down from the head, but wasn't as hard as I thought it would be
Summary
 I don't know but I think this light is a lumens monster with a nice throw for it's size. I hope someone else could substantiate this. The KK 4200 (or 4000) flat tops seem to fit fine, but I tried a KK ICR button top and it was too tight - couldn't screw down the tailcap, and took some playing to get the light to even work.
08/25: Edited amps measurements done with new DMM leads
jmpaul320
jmpaul320's picture
Last seen: 1 week 5 days ago
those are some very nice numbers for a single cell 26650 light
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
RaceR86
RaceR86's picture
Last seen: 4 years 9 months ago
Nice mods!  8)
Do you know if a KK 4200ICR delivers the full 4,56A, and how long it will be able to stay above 4A?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Tom E
Tom E's picture
Well, throw seems right there, but lumens - I checked, re-checked, checked with another light.... Now I have a lot of confidence in the PVC lightbox, built by rdrfronty and manxbuggy1, and used by several others. TurboBB seemed to be the first with this particular PVC design, and in his tests, he got good results across the spectrum of flooders and throwers, so I'm thinking these #'s are pretty good.
It is high #'s but pretty high amps as well - I have to re-check readings, but I believe they are 4.2-4.5, in that range, which is very efficient for an XM-L2 on copper. I really, really like the KK's over any other battery because not only does it deliver high amps, but it keeps the amps high much longer than a IMR or high current 18650 cell. This is the main reason why I prefer single cell 26650 lights over a 18650 single cell.
Tom E
Tom E's picture
RaceR86 wrote:
Nice mods!  8)
Well, funny because I always said you can't get 4.5A on a 7135 based driver, single cell, for an XM-L2 or XP-G2 on copper. Let me re-check tailcap readings -- it was difficult on this light because of the anodizing on the threads, and the outer shell is very thin, so I've been using the top edge to connect to with the DMM lead.
gords1001
gords1001's picture
Last seen: 2 years 5 months ago
nice job Tom, I may get another to play with but this one is staying stock, its too good at what I want it to do to play with.
my stepson has taken mine away loaded with rechargeable Panasonic aa’s for his week long scout camp. hope he looks after it.
comfychair
comfychair's picture
Last seen: 4 years 6 months ago
It's just begging to have the head drilled out and filled with a press-fit plug cut from copper bar stock.
tkmckay
Last seen: 2 weeks 5 days ago
Nice work as always Tom! This torch is definitely moving up my list….. but I really should limit myself. Wink
Tom E
Tom E's picture
Ok - got a 4.26A measurement at the highest with the cell at 4.00v, so I'm thinking that's pretty up there. Sprayed CRC 2-26 on my 12 gauge DMM lead ends and that helped get a higher and more consistent amp reading (before I was getting only 3.0-3.7A), so, there's lies my amp measurement problems.....
Weights:
XintTD X3 w/KK 26650 cell:  400 grams
HD 2010 w/KK 26650 cell, copper added to inside of pill: 396 grams
You can tell just by the feel it has weight to it. It's got a thick alum tailcap too, but the smallest, cheapest looking switch around.
RaceR86
RaceR86's picture
Thanks for the info. I have not pushed the XM-L2 beyond 4A from a single cell yet.
Ill stick to 4,2-4,3A as absolute upper limit. Small gain for limited time in going higher.
Tom E
Tom E's picture
I usually go to 3.5 or 3.85A for C8 size lights, and 4.2A for HD2010/SS T08 sized lights, but this hunk of metal I figured could do more - I don't think I've ever seen this amount of weight in such a small sized light and the uni-body construction must help. I ran it for 6 minutes straight on high and it holds up well - well warm but nothing crazy.
At 350g stock, no cells, it's heavier than a SRK or most standard 2 cell throwers like the STL-V2, TF X9, or bigger head single cell lights like the HD2010 and Small Sun T08, and all associated lights in the same form factor.
oRAirwolf
oRAirwolf's picture
Last seen: 1 year 6 days ago
Nice job Tom. That is an impressive gain.
tallboybass
tallboybass's picture
Last seen: 1 year 8 months ago
That looks like a nice light that didn’t quite get finished at the factory. As a stock flashlight, it seems lacking. After Tom’s work, dynoMITE! Party It throws 551m?!!
DayLighter
DayLighter's picture
Last seen: 3 years 6 months ago
always fun to hear your modded light Tom Beer
The only way to do a great work is to love what you do.
atbglenn
atbglenn's picture
Last seen: 1 year 4 months ago
Wow Tom, cool stuff! I'm satisfied with my stock X3. If it gives me a problem in the future, I'll mod mine just like yours. (I may need to get in touch with you on some of the details)
Boycott Nike
vēer
vēer's picture
Last seen: 1 year 3 weeks ago
I was wondering the same – awesome mod, but dont you Tom feel like its stock version should be worth more like 30-35$ rather than 45-47$?
Tom E
Tom E's picture
vēer wrote:
tallboybass wrote:
That looks like a nice light that didn't quite get finished at the factory. As a stock flashlight, it seems lacking. After Tom's work, dynoMITE! Party It throws 551m?!!
I was wondering the same - awesome mod, but dont you Tom feel like its stock version should worth more like 30-35$ rather than 45-47$?
Well you could argue the price I suppose, but figure a XinTD C8 at $30, this has a SS bezel, weighs a ton more because of all the solid aluminum, seems to have an excellent reflector, same length as the C8 but bigger head/reflector. What is a shame, for me, is it targets the triple AA carrier, but I would have preferred it as a 26650 targeted design (can only take short 26650 cells with lots of side slop). Of course the finished anodizing and threading is awesome. Also the 22 gauge wires and QLite driver is a hugh plus too.
ryansoh3
ryansoh3's picture
Nice work and great pictures, thanks for sharing!
BLF ≠ B-grade Flashlight Forum
agent80
Last seen: 5 hours 55 min ago
I have never modded a light before. I want to replace the stock board with a U2 Noctigon. Do I just buy this http://intl-outdoor.com/noctigon-xm20-mcpcb-cree-xml2-u2-1a-led-p-749.html unscrew the bezel, de-solder the wires, replace with the noctigon and solder the wires back? Does something need to be done under the board?
Thanks
Tom E
Tom E's picture
Well.... Not so simple, but basically that is the procedure. As shown above, I had a hard time prying up the existing star because it was epoxied down. Then you have to clean up all the old epoxy. I'd recommend using a thermal grease instead of epoxy for seating down the new replacement star.
Notice I filled in the hole a bit with copper.
Mr. Nobody
Mr. Nobody's picture
Last seen: 10 months 5 days ago
Anyone try dropping a mtg2 in this light yet ???
3Tronics
3Tronics's picture
Last seen: 2 days 5 hours ago
I did for a bit, I used 3 14500 in the triple AA battery carrier, worked well, but prefer XML2 in this light for the throw (Convoy X3 not XinTD)
Custom builds | Modifications | Powder Coating
Gallery: Instagram
Mr. Nobody
Direct drive the xml2? Smile or DD XHP50
3Tronics
3Tronics's picture
Currently an XML2 de domed with the LD-2 driver at 6A, one of my faves!
Gallery: Instagram
Mr. Nobody
nice! kcd?
3Tronics
3Tronics's picture
Not sure but I’d say over 100Kcd stock is 46kcd so dedomed and 6A is well over that
Gallery: Instagram
