Features
Structure: New die cast model, made by high quality ADC12 aluminum, more stronger; Patent new lamp body is design to support heat sink, with better ventilation, no fans cooling, no noise! Temperature rises 25 degree in the full load; Could customize white/ Black housing.
!http://www.prlog.org/12199985/1 !
Optic Design:Standard white light output, standard white, nature white, warm white, blue, etc, different colors to customize; Beam angle (10% intensity) 15 degree, 45 degree, Optional.
Electrical: AC 90~240V 47-63 Hz Input, 45 Watt max consumed, power factor 90%;
Dimming: Silicon Dimming; PWM driving, Frequency>3K Hz
More than 35000 Hours Longevity for SMPS.
Smooth dimming, can replace 100 watt traditional Halogen, metal halide Par light.No need to change original primary dimmer rack circuit, no need to add extra DMX system,suits for applications as technology reform of stage, studio room, save wire and labour cost.
This product comes from:
Specification
Voltage input: AC 90-240V 47-63HzMax power consumption: 35W
PF: 0.9
Light source:7pcs*5W, 2800-8000K optional, warm white 200K as 1 BIN, standard white 500K as 1 BIN, Standard white LED 2080 Lumens Output;
LED Life Span: 50 000 – 100 000 hours
Beam Angle: 15°、25°、45°、60° optional
Dimming: Primary side dimming Smooth dimming curve
PWM Frequency: >3KHz, flicker free
Cooling method:Natural cooling
Net Weight: 1.2Kg
IP Rate: IP 20
