Review: UV light shootout, seven lights tested
268 posts / 0 new
johan
Last seen: 4 years 8 months ago
ToyKeeper wrote:
johan wrote:
I have this Nitecore CU6, what would you like to know about it?
I’d love to see fluoresced beam shots compared to other UV lights. Smile
(actually, would really love to see it compared to the KD UV drop-in people have discussed here, on two cells, but you don’t have one of those… but the drop-in runs at up to 5W or so, while the CU6 is spec’d at 3W… also, the drop-in fluoresces many things which don’t really show up at all under my other UV light, and its visible light is dim enough I don’t need tinted glasses to see the result clearly)
I’m new to the world of dropins and hosts, but do I have it right that basically rather than buying a complete torch people buy the case (host) and light (dropin), and the two screw together by default? Can someone recceomend me a webpage on torchmaking for newbies like me?
Fwiw the CU6 shows the 20 on the £20 notes very well, on par with nichia, better than a BLB-T5 and much much clearer than all the 395nm LED torches from ebay
johan
Here you go, my little contribution to this discussion. The torches are all those referred to at my site http://extreme-macro.co.uk/uv-macro-lighting/
The KD UV would be nice to try
johan
Did this series as well, because mfm, the starter of the thread, also did a 20 Euro note so this should give some common ground to compare. What’s interesting is the way that the cover of the BLB-T5 ‘bank note checker’ actually does itself a disservice. The clear plastic cover over the tube is itself excited by UV and gives off blue light, which then swamps the already quite thin UV fluorescent green/yellow panel. Link: http://extreme-macro.co.uk/uv-macro-lighting/
Suncoaster
Suncoaster's picture
Last seen: 3 weeks 4 days ago
Location: Where the girls are green and the grass is pretty.
If you send me that 20 I’ll test it with the 365nm Ultrafire 501B and the Fasttech 395-410nm
. :bigsmile:
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 6 min ago
Awesome. I’ll have to post some currency pics… though I don’t have nearly as many UV lights to compare.
About all I can say so far is that my cheapo UV light looks about like the “41-LED” pics above, and the KD UV drop-in looks a lot like the CU6. However, it doesn’t do well at fluorescing the red stars and circles on the 20 euro note.
johan
The problem is though that some of the colours might be due to the camera rather than the lights. As in each camera interprets UV signal somewhat differently, so it’s hard to standardise. And to really see just the visible fluorescence you have to filter away any UV or IR signal, ie prevent it reaching the camera. Otherwise there is spillover. Trust me, I’m a camera geek Smile Here’s another thing I did tonight. the UV/IR cut from Baader I’m using on the centre column is about the most expensive “prevent UV and IR reaching the camera” filter around:
ToyKeeper
ToyKeeper's picture
Definitely. I’ve tried and mostly failed to capture accurate UV-lit images. But then, I don’t have the proper filters and I have a cheap camera. I especially haven’t been able to get accurate white-ish tints to show in beam shots, no matter what I do with the white balance.
So, any shots I post will be … a bit lacking. But maybe it’ll still be useful to someone.
I’m also trying to figure out how to accurately show the output of my wide-spectrum light compared to a high-CRI light and common medium-CRI tints, but I think I’d need a far better camera. An elph 110 HS is great for snapshots, but it simply doesn’t cut it when you want accurate representation of subtle color differences. At least it was able to show the not-subtle difference in how my eyes perceive the wide-spectrum light versus incandescent overheads:
Wide-spectrum BST (looks almost identical to a Nichia 219, only with slightly more vivid colors):
How I see with overhead incandescent bulbs (my eyes never adjust to the tint):
Mr Floppy
There is a new Tank007 365nm UV light on HKE. It uses an 18650. 3W version so 2×1.5W UV emitters under the dome I think like the 3W AA one. Same Japan UV as the other Tanks. Asking price is a bit high
ri chevy
Is there a BLF coupon for HKE?
blueb8llz
Last seen: 6 hours 45 min ago
ya i noticed that new one at a few other places too. until i found the older AA version for a good price at focalprice.com http://www.focalprice.com/LFD45B/TANK007_TK566UV_1Mode_1W_Purple_WaterRe...
there was also a 10% coupon online too. so i only paid $33 shipped
ToyKeeper
ToyKeeper's picture
I haven’t tried a Tank007 TK566UV, but a L2m + KD drop-in works pretty well and comes out to a little less than $30. With two cells, it runs at around 5W.
alternety
I found this thread too late. I bought a Ultrafire WF-501B (on the body it also says HWA/WYS). I claims to be 365nm and uses and 18650.
Does anyone have any experience/comparison relative to the Tank?
Ladp.1
Last seen: 7 years 3 months ago
First time poster, long time reader! You all have a lot of great information on this site.
I thought I’d share my limited UV experience. Several years ago I bought my first UV light. It’s a Pentagon Lights 2 watt UV that’s labeled as being 390nm. It really didn’t fluoresce that much as I had hoped. It mostly seemed like a deep purple light. A couple years ago I got an Inova X5, the newer version with the dual output and both 365 and I think 380nm LED’s. It worked much better for things like currency. That’s when I found out that the stripe on the $100 bill would actually fluoresce red and it won’t at 390nm. The problem with the X5 is that it’s not very powerful at all. I’ve visited this thread a few times looking for information on a higher power REAL 365nm light.
Anyway, a couple weeks ago I was looking at the CustomLites site and noticed Dave was selling a 365nm drop in with an LEDEngin LED and I kind of bought it on impulse. Oops Smile I’ve got it in a L2p running on 2× 18350 IMR’s and it’s just crazy to me how much light it puts out! It will easily fluoresce things at least 50 feet away. That’s the farthest I’ve tried so far. It was a little pricey but I was a little sick of messing around. Even so, it was still less than I payed for the Pentagon Lights one several years ago that I didn’t ever like and that includes an L2n host I had in the order. I’m very happy with it!
I would try it with a $100 bill but I don’t see many of those.
djozz
djozz's picture
Last seen: 5 hours 17 min ago
Ladp.1 wrote:
First time poster, long time reader! You all have a lot of great information on this site. I thought I'd share my limited UV experience. Several years ago I bought my first UV light. It's a Pentagon Lights 2 watt UV that's labeled as being 390nm. It really didn't fluoresce that much as I had hoped. It mostly seemed like a deep purple light. A couple years ago I got an Inova X5, the newer version with the dual output and both 365 and I think 380nm LED's. It worked much better for things like currency. That's when I found out that the stripe on the $100 bill would actually fluoresce red and it won't at 390nm. The problem with the X5 is that it's not very powerful at all. I've visited this thread a few times looking for information on a higher power REAL 365nm light. Anyway, a couple weeks ago I was looking at the CustomLites site and noticed Dave was selling a 365nm drop in with an LEDEngin LED and I kind of bought it on impulse. Oops Smile I've got it in a L2p running on 2x 18350 IMR's and it's just crazy to me how much light it puts out! It will easily fluoresce things at least 50 feet away. That's the farthest I've tried so far. It was a little pricey but I was a little sick of messing around. Even so, it was still less than I payed for the Pentagon Lights one several years ago that I didn't ever like and that includes an L2n host I had in the order. I'm very happy with it! I would try it with a $100 bill but I don't see many of those.
Welcome to BLF Ladp!
If it is the Ledengin LZ1 365nm led in that Customlites drop-in, that is the one I used for my small zoomie mod (I linked the build thread somewhere above in this thread), it is indeed impressive! The bare led alone costed me more than 30 dollars (twice as much as the host) Surprised
Ladp.1
Thanks!
All the tube the drop in came in says is:
Ledengin
365nm
1level regulated
4.2-12 volts
It doesn’t say if it’s an LZ1 but, just looking at the data sheets from Ledengin, it seems like that would be the best match. I actually started by putting a 18650 in there and was impressed already but then I saw the 4.2-12v I initially missed so I popped in the 2 18350’s I had and was wowed! It’s powerful enough that I’m actually a little spooked in using it before I get some protective glasses. I don’t know if that’s too cautious or not but that’s what Dave recommended to me in an email and he seems to know what he’s talking about.
ToyKeeper
ToyKeeper's picture
I might have a 380nm light soonish. It’s not as short a wavelength as I’d like, but it’ll be very compact and should be interesting to compare against my 365nm drop-in. Great to have around when I don’t feel like carrying the bulk of my nicer UV light. It’s the size of an Olight S10, which is like a third as large as the L2m I use for full-power UV purposes.
elsayedhussin
Last seen: 7 years 4 weeks ago
Can you describe the amount of visible blue light compared with your others?
How well would you say it works with 1 × 18650?
Thanks
Everything about LED ceiling lights types, led bulbs types, control led lights, new collection, prices, offers
http://ledceiling-lights.blogspot.com
ToyKeeper
ToyKeeper's picture
My SF L2m w/ KD 365nm drop-in is by far the best UV light I’ve tried. It has only a small amount of visible light and it makes pretty much everything glow if it’s capable of glowing at all. However, it’s significantly dimmer on 1×18650 than it is on 2×18350. On one cell it’s still better than my others, but not by such a wide margin.
The new 380nm light has been a bit disappointing. It’ll light up bleached paper but not much else.
In any case, I don’t have any good retail blacklights to test against, like the Nitecore CU6. So, I don’t know how those compare.
Shur
Hmm, the CUXP2 from Int'l Outdoor has a UV option that could be interesting.
Anyone planning to try it out?
specs say 400nm
Mr Floppy
Anyone splurged on this Ultrafire C3 version from KD yet?
http://kaidomain.com/product/details.S023295
If it is as a good as the P60, that would be great as it runs 14500’s.
Halo...
Halo...'s picture
Last seen: 5 years 3 months ago
How much visible light? Purple or white-ish?
ToyKeeper
ToyKeeper's picture
The visible light is more white-ish, and there’s a fair amount of it. I’ll have to get pictures later though.
Richwouldnt
Richwouldnt's picture
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
Any one compared the Kaidomain P60 (Approx $16), the Custom Lites P60 (LED Engin LED used, $68) and the Nitecore CU6 (Approx $100) as far as how they do for UV use? All claim to be 365nm UV output lights.
The Custom Lites P60 is 4.2V to 8.4v single mode, the Kaidomain is 3 to 18V claimed and I presume single mode while the Nitecore CU6 is UV, White and low level Red, green and blue outputs with multiple output levels for the white and UV lights.
I have read a lot of this thread but not all so sorry if i missed any comparisons. I note lots of favorable posts about the Kaidomain drop in and some positives about the Nitecore. One positive report on the Custom Lites P60 too. Are these the best 365nm LED UV options out there?
Rich Wood
Reno, NV
ri chevy
This UV LED is supposed to be one of the best.
http://budgetlightforum.com/node/35447
ToyKeeper
ToyKeeper's picture
Richwouldnt, I don’t think they’ve been directly compared, but I did at least volunteer to review the CU6 and compare it to other lights a while back. I didn’t get approved though.
As for the KD drop-in vs CU6, the CU6 is spec’d at 3W of power in UV mode, while the KD drop-in runs either lower or higher depending on the number of cells used. I got it running as high as 5W or as low as 1.5W, from what I recall. 600mA at 8.4V is what mine does on two cells.
From the sound of things, either of the LEDs djozz reviewed recently would probably out-perform both the CU6 and the KD drop-in:
http://budgetlightforum.com/node/35500
I’m kind of tempted to make a 1×16340 UV light with a really nice Ledengin XP-G sized emitter… but it’s a very very low priority since this P60 works more than well enough for my purposes.
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 11 months ago
ToyKeeper wrote:
[snip]I’m kind of tempted to make a 1×16340 UV light with a really nice Ledengin XP-G sized emitter… but it’s a very very low priority since this P60 works more than well enough for my purposes.
Just an FYI LEDENGIN doesn’t have any XP size emitters. LZ1’s are 4.4×4.4mm (arond XM size) but they do NOT use XM pad’s and can’t be used in XM MCPCB’s except for a modded xml color sinkpad.
http://www.ledengin.com/files/products/LZ1/LZ1-00UV00.pdf
They dont have any DTP boards available for LZ1 or LZ4’s and the LZC’s there are sinkPAD’s for arnt really usable in flashlight’s.
Side note on the LEGENGIN emitters, I’ve got a deep red LZ4 on order and a nice host and driver for it (~10vF), just have to find a reflector, I’ve been very impressed with their emitters since first hearing about them a few months ago from Mattaus.
ToyKeeper
ToyKeeper's picture
Oh, okay. I skimmed quickly and must have gotten two bits of info mixed up. I’ll be sure to check in more detail if I ever decide to do the project.
