5.75A to emitters TK70!
64 posts / 0 new
Hyprmtr
Hyprmtr's picture
Last seen: 7 years 6 months ago
I decieded to mess around with my TK70 today and got some pleasing results! First off the light was upgraded with XML2-U2 LEDs a few months ago and I was pleased but not completely happy. Here we go…
First I played with a few different resistors and never got above 2800ma to the dies with the Tenergy 10000mah D cells.
It was brighter but still not bright enough!
I then bridged the sense resistors over and put 3 26650 flames to it. I got 5.75A to the emitters now. I think I’m happy now! It gets hot quick. I may pot the driver so it will last. I havent yet checked temps since this mod was done just 10 minutes ago. Haha. I will update when my 32650 flames get here amd I can run the light fully assembled. I cant wait for beam shots!
bdiddle
Last seen: 9 months 5 days ago
5.75 to each led?
Newb
TrakTuned
TrakTuned's picture
Last seen: 8 years 4 months ago
Shocked Shocked Shocked
Throw should be very high on this one
BLF members are hilarious:
“That’s like saying “My car has top-speed of 200k millimiles per hour”. Why not to just say 10 Ah?”
RaceR86
RaceR86's picture
Last seen: 6 years 7 months ago
Like! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Hyprmtr
Hyprmtr's picture
bdiddle wrote:
5.75 to each led?
Yes! I cant believe it myself! I lost the high/mid/low modes but I still have strobe and sos.
MountainKing
Man you modded such an expensive thing!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Hyprmtr
Hyprmtr's picture
I have had this light since about 2008? Maybe it was 2009. I dont remember. I had problems with it a couple years after I got it. It would flicker and turn off by it self. It was a PITA getting it apart. I ruined the stock T6 emitters when I took it apart. So I upgraded to xml2-u2 emitters. I couldnt stop there! Haha!
Ken
Hyprmtr
Hyprmtr's picture
Quick update,
I got it put back together and measured lux at 10 meters. I got 2190 lux. I used (3) 26650 flames I made a short filler with a piece of brass to get the contact in the battery tube. I did measure current at the emitters with the light assembled and it was 5.1A. Probably because of the extra resistance of the brass spacer. Beam shots tonight! (Still daylight here)
Ken
2.4A
5.1A
Hyprmtr
Hyprmtr's picture
There it is. I barely got one shot in. Camera battery died. Im charging the battery in the camera. I will probably fall asleep before it charges. I been up since 4:45 this morning!
Ken
TrakTuned
TrakTuned's picture
Thing looks beast! Thanks for the shots.
MountainKing
looks beast?
it IS beast. lol
bibihang
bibihang's picture
Last seen: 21 hours 49 min ago
219kcd!!
Dedome them!!
Hyprmtr
Hyprmtr's picture
Thank guys! Im going to do some run times and heat tests today hopefully. Will update.
I have dedomed a lot of leds. Im not to crazy about tbe color afterwards. Im happy with 219kcd!
This light is sure a lot lighter now with 3 lithium batteries!
Oh yeah, strobe is wicked on this thing!!!!! J)
Ken
tatasal
Last seen: 2 hours 17 min ago
What is the input voltage range of a stock TK70?
Hyprmtr
Hyprmtr's picture
Stock TK70 takes 3-4D size batteries. Alkaleaks or Nimh
FMcamaroZ28
FMcamaroZ28's picture
Last seen: 7 months 6 days ago
Working Voltage: 4.8V – 8.0V
Max Input Current: 6.5A – 7A
From a quick google.
http://www.candlepowerforums.com/vb/showthread.php?317324-Fenix-TK-70&p=...
Hyprmtr
Hyprmtr's picture
I think my input current was less than 3A with the 3 lithiums. I can check later to verify. Dont hold me to that number just yet.
Ken
tatasal
Thanks for your link.
The Thai TK70S version uses either 2 li-ion or the usual 4 nimh
http://www.thaipowerlight.com/Fenix-Flashlight/Fenix-TK70s
xed888
All TK70 can use 2 Li-ion cells. Not sure about 3 though.
tatasal
xed888
tatasal
xed888 wrote:
tatasal wrote:
Two of either links will be good enough?
http://www.fasttech.com/products/1420/10002171/1156400-feilong-32600-37v...
(as long as the D cell)
http://www.fasttech.com/products/1420/10002175/1156800-feilong-32650-3-7...
Yup!
Have you tried this set-up or something similar? Aside from the weight savings, what are the other things that can be gained with such set-up?
xed888
Shorter and better balance with a dummy cell near the head. I would prefer a 2D tube but cant find one.
Hyprmtr
Hyprmtr's picture
I just measured tailcap current with 3 fresh 26650s. It was 3.84A on high. It stayed at 3.84A for 30 seconds of run time. I suppose my driver is safe!
Ken
blueb8llz
Last seen: 5 hours 30 min ago
wow nice mod! can you tell me how many lumens now?
Hyprmtr
Hyprmtr's picture
I can only really go by Matches test on the XML2 led on copper test. At 5100ma I would be at 4800 lumen. I like this light a lot because the reflectors are deep and it really throws well! I believe there is not a true way to convert lux to lumen?
Ken
FMcamaroZ28
So you have the stock driver in and running at 12.6V?
And its not smoking?
Hyprmtr
Hyprmtr's picture
Thats correct! I even tried 4 cells. It didnt like it. The light would only shine dimly. This driver is very robust!
The only mod I did to the driver was bridge the sense resistors. Thats it!
I have about an hour run time on it with this mod too.
Ken
bdiddle
Ken
The math doesn’t add up.
Input power is around 46 watts.
Output power at 5.75 amps per emitter == 5.75amp x 3.8(vf at 5.75A) x 3(emitters) = 65 watts.
Newb
Hyprmtr
Hyprmtr's picture
bdiddle wrote:
Ken
I didnt think to do the math. I am just measuring current in real time. I could have a fualty multimeter. Or maybe I’m not using heavy enough wire on my meter to test?
The 5.75A was a bench test with a Pb 12 volt battery. The assembled test was 5.1A at the emitters. The current test to the emitters was done at a different time when I did the tailcap current test. I do have another meter. I can try and test the output to the emitters and the tailcap at the same time. What efficiency are you using for the driver?
Ken
Hyprmtr
Hyprmtr's picture
bdiddle wrote:
Ken
I just did another tail cap current read. I used 10 gauge tin coated copper wire as short as I could I got a tail cap reading of 4.54A. That should be correct. I should be a little more thorough in my tests. I just get so excited to see such a gain in performance and I love to share my results. Thank you for allowing me correct my accuracy.
Ken
