I received it an hour ago, so its work in progress, this is your chance to raise specific questions related to this light, I will do my best to answer them all!
Whats included in package:
First impressions:
+ Tint, compared to my D40A Neutral White is visibly warmer, closer to the incan’s level, but not overly so! SD10 uses XM-L2 U2 3C
+ Starts on LOW, goes to HIGH, then goes to MED. Fast cycle through all modes will bring up strobe, strobe can be accessed also by double pressing on/off button when light is on.
+ Has mode memory even if you unscrew the tailcap.
+ Can be locked out by fraction of a turn.
+ Build quality is very good.
+ Very lightweight.
+ White wall beam profile seems clean
+ It has wider hotspot than D40A, thus making it more floodier
UPDATE:
This is my FULL review of Lumintop SD10 flashgliht!
(Tailstands perfectly!)
General:
It has Cree XM-L2 U2 3C warm white LED, unlike regular SD10 which ships with XM-L2 U2 1A in cold white.
Comes with cheap 3xAA adapter and cheap looking lanyard(more on that later), no holster included with this light.
Takes almost any cylindrical battery out there starting from single AA battery(with adapter) and going up to the big boys - lithium batteries, namely 18650, 26650 and 32650! Official specs list D, 3xAA and 18650-32650 batteries. But if you use your creative mind you can use all sorts of AAA-AA and AA-D adapters both for alkaline/Ni-Mh and for lithium batteries such as 10440, 14500 and up to 32650.
(Springs in tailcap and in head of the light)
I was unable to get 4xAA Turnigy Ni-Mh’s into the light, it would damage wrapper on batteries and most likely it would be impossible to remove battery carrier from light afterwards :D!
I used 4xAAA Turnigy’s with AA adapters which fit just fine and the light is really bright with this setup, as bright as with lithium batteries to my naked eye!
Generic alkaline D cell, 1AA/2AA to D adapter, 4xAA/AAA holder, 3xAA holder, 18650 DIY tube adapter, protected 18650:
NO reverse polarity protection, so make sure that youre insterting battery or battery carrier correct way, otherwise you might end up with fried light.
User interface:
Operation is quite simple - you turn on the light by pressing on/off button and holding it till the light lights up, it takes less than a second to do so, you turn it off the same way.
It has 3 main modes, high, medium, low and hidden strobe which you access by simply double pressing power button when the light is on.
One interesting feature here that I also like about this light is that its switch will light up green when pressed, its a good indicator that the batteries are inserted and that it should function normally.
Tint:
Now, regarding its tint - its really, really warm, not neutral, not even close, its really yellowish/orange, depending how you perceive colors.
I personally prefer more neutral tints, but this doesnt bother me at all, especially given that Ive used this light outdoors in wilderness and for that this light shines.
Heres the white-wall shot with EA8W(warm/neutral), SD10 warm white and D40A NW (neutral):
You might not notice, but in real life D40A appears to be the most neutral of them all, EA8W coming as second and SD10 being the warmest one, in fact, warmth of EA8W cant be noticed during real life use, unless you compare it with D40A NW face-to-face that is.
Output:
Regarding output - this light will run just fine with either single AA battery inserted into cheapo D cell adapter as seen above in battery adapter group-shot, naturally, the lower the voltage, the dimmer the light, thus maximum output will be achieved with either 3xAA/4xAA batteries or with lithium batteries.
I compared output on HIGH between EA8W, D40A NW and SD10 and, as expected, EA8W throws the farthest, next is D40A NW and then SD10, which is very good given that EA8W is dedicated 8xAA thrower with biggest and deepest SMO reflector of them all! While reflectors on D40A NW and SD10 seem similar in sizes, the one in D40A NW is deeper, thus better for throw and has smaller hotspot, which adds to tighter beam, both have OP reflectors.
Output is visible up to 400 meters in city against gray/yellow multi-story building. However, thats about as far as it goes, EA8W and D40A NW will outthrow this light, but everything past 100-200m with SD10/D40A NW will be unusable, EA8W is usable past around 300 meters, but you will want to use some optic vision enhancers given that even daytime its not easy to identify targets and details at this distance.
Even though SD10 will not throw as far as competition, it makes it up with its wider hotspot and thus floodier beam which is nice when you consider that this light is intended for universal use and not as a light sabre!
One thing that SD10 lacks is ultra-low/moonlight mode, both EA8W and D40A NW have ultra low modes. However, regular low mode is low enough for most around the house tasks, especially if you use D or AA batteries in this light, the lower the voltage, the lesser the output in all modes.
PWM:
PWM is present, but not distracting in my sample, Lumintop confirmed that they use PWM, even tho I didnt ask whats the frequency on it.
I was concerned that I might get turned off by PWM, but in real life use I never noticed it and it has never bothered me, however, if you try hard and look for it, you might notice it. Or you might not.
What else?
For the price Lumintop asks for this light(MSRP 59.99:money_mouth_face: they should have added nice holster with it, their competitors have done so. I understand why Lumintop dont see this as an issue - theirs can be used with almost any(when using multiple adapters) cylindrical battery out there up to the size of 32650 while Sunwayman/Nitecore both are dedicated AA Ni-Mh players so lack of holster might not be an issue for most. I for one would love to see holster at this price point no matter if its multi-chemistry light like SD10 or dedicated AA Ni-Mh/Alkaline light like EA8W/D40A NW.
Also, better quality 3xAA adapter is a must to increase SD10 output, because mfgs stated 500 lumens look more like 200-250 lumens and look to be on par with D40A NW’s medium mode!
And yes, adapter for 18650 would be also nice bonus!
Included lanyard looks cheap and it proved that its also cheaply made, at least part of it - one of the attachments broke off the first day when I started using this light outdoors, without any abuse from my part. You attach small loop to the light itself and then attach the main lanyard to the small ring on the small loop/lanyard attachment thingy.
This small part didnt last long and the small thread just detached from it.
I then simply attached the small ring to the light and then snapped the carabiner/clamp(which is quite strong) of the main lanyard on it and it has worked fine since then.
My light came with one small fault - when using 3xAA batteries or others with higher total voltage, the LED would light up even if the light wasnt turned on, the only way to avoid it is physical lockout by simply turning tailcap counter-clockwise for few milimeters.
Lumintop assured me that this is not normal and that all lights should be working properly and that my review sample is simply defective.
On the other hand, mine now has ultra-low/moonlight mode when used with 3xAA and up batteries :D!
Verdict:
Given the number of batteries that his light supports, it is very versatile flashlight and one that would be perfect as emergency light that can utilize most common sized batteries out there, all you need is couple of adapters and you’re set for that apocalypse!
Id give it 8 out of 10 for what it is despite some of its shortcomings - lack of ultra low mode and lack of holster and higher quality battery holder/adapters.
