Toshiba battery yields 18500 cells
80 posts / 0 new
Gj
Gj's picture
I received this Toshiba 3400mAH laptop battery today, $8.99 free shipping.
http://www.ebay.com/itm/170893824570
Fairly easy to open to reveal six 18500 cells, should be 1700mAH cells.
No glue! Held in by a strip of double-sided tape, not super sticky.
4 cells @2.56V, 2 @1.96V
The codes printed on the cells:
All have this line: LDGFK15
Below that each has a different code: 002198, 006214, 020330, 017552, 016789, 013922
The last two also have a larger "C" above the LDGFK15.
Streamer
Streamer's picture
Last seen: 1 year 8 months ago
What do you use them in? I’ve yet to run across an 18500 light.
Slim Pickens
Slim Pickens's picture
Last seen: 7 hours 35 min ago
You can use them in most lights that use 3xCR123A since 2×18500 is almost identical in length (plus, the voltage is close enough that even 3×123 incandescent lights ala Surefire 9P will run great on 2×18500).
Malkoff Wildcat comes to mind. Also useful for C cell lights, just use a sleeve and you’re good to go since C cells are ~50-52mm in length.
Gj
Gj's picture
Many lights that use a short form 3xAAA carrier. You might want a liner to prevent rattling. I have one like this except made for 18500, but I can't remember which light it came with.
http://www.fasttech.com/products/0/10002938/1219900-3-x-aaa-to-1-x-18650-battery-converter
NightCrawl
Last seen: 5 years 5 months ago
There arent many 18500 lights. But there are some AA/14500 lights than can be bored to accept 18500. Sunwayman V10A for example.
rojos
Last seen: 5 years 7 months ago
L2m with a few mods maybe?
ohaya
Last seen: 3 years 4 months ago
Wow! 18500s! I’ve never seen those in a pack (but then again, that doesn’t mean much :)).
Are you able to check if their capacity is actually 1700 mAh?
When I first started, I used 18500s in some “Techlite” (Costco) lights, with the convertor tube you linked, cut in half (so one convertor would be used for 2 batteries/lights). I still have them (the lights and batteries) in all our bedrooms, as emergency lights.
If you can confirm that these are 1700 mAh, I might have to pick up a pack, as most of the ones I found were lower capacity that that (like in the ~1000 mAh range).
Also, FYI, when I was searching back then, I saw some references that said that these were used in a lot of the solar-powered landscape lights :)…
Thanks!
Jim
skyrider1
Last seen: 2 years 2 months ago
Yep, I use 18500s in an l2m with shortened drop-in. It’s a tight fit but it works.
vuanhquoc
vuanhquoc's picture
Last seen: 4 years 3 days ago
I just ordered two pack, they look like the Sanyo 18500
Boaz
Boaz's picture
Last seen: 12 hours 4 min ago
nice to use in decent 3AAA lights .I was thinking about an 18500 to use with the  edi-t p13 I picked up from wallbuys
Gj
Gj's picture
I don't have a charger that measures capacity. If they're OEM of a big name like Toshiba I'd think they should be close.
One just finished charging in a Nitecore i2, ~4hrs. @500mA, I didn't note the exact time I started them. I put the two 1.96V cells in that, the others in the Xtar WP6II @600mA.
Edit. the second in the i2 finished as I hit submit.
Gj
Gj's picture
Two in the Xtar just finished.
Gj
Gj's picture
The last two finished. All settling ~4.22V
ohaya
Gj,
Thanks for the info!
Jim
Gj
Gj's picture
You're welcome.
I just tried 4 cells in my UV Solarforce L2P. I had four 16340's using 1 extension, the 18500's fit using 2. Seems brighter with the 18500's, although I'd rather use protected cells with 4 in series.
watalee
Last seen: 7 years 11 months ago
this laptop battery should be throwwed out because they must be second used batteries inside.
the 18500 battery’s price is about 1.4usd made in china and about 2.5usd made in japan, how could they make a laptop battery and just sell it at 8.99usd with free shipping?
those chinese sellers are ruined chinese business reputation all the time.
i would advise my friends that do not buy those cheap products which are lower price than material costing.
(This post/thread “may” contain referrals,a little contribution I “earn” in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to share info about them. It will not cost y
Vieplis
Last seen: 5 years 10 months ago
A laptop battery can be cheaper than the cells, if nobody needs a battery for that laptop. A good find for 3AAA lights, thanks Gj.
Regarding never used old batteries I just wonder how the seller can be reasonably sure the battery is not dead. Judging by the cell voltages about 1.9V in other threads, the seller has not tested them.
watalee
Vieplis wrote:
A laptop battery can be cheaper than the cells, if nobody needs a battery for that laptop. A good find for 3AAA lights, thanks Gj. Regarding never used old batteries I just wonder how the seller can be reasonably sure the battery is not dead. Judging by the cell voltages about 1.9V in other threads, the seller has not tested them.
some sellers do not concern about if the battery is dead, they want to make the prices lower so that buy many second hand batteries and no any testing before making the laptop battery.
they are ruining the chinese international business all the time, i hate them
fyesilova
fyesilova's picture
You can put 18500 inside of a D cell case (nimh) and get a D size LiPo battery.
Or you can use a pipe to make 2 cell battery pack to use inside a maglite, and can use 6 cell bulb.
Istanbul New YSM Bridge
Istanbul’s new bridge at night
ohaya
That battery is for, among others, the Libretto U100/U105 laptops, which were from, apparently, the 2005 timeframe, see:
http://support.toshiba.com/support/modelHome?freeText=997820
So, these could be/probably are leftovers “new” packs that the seller are trying to get rid of.
As discussed elsewhere, it appears that if the pack is really new, e.g., in this older thread:
http://budgetlightforum.com/node/20513
Pulls from a “new” pack come out a little low (in that case, the ones I got all came out of the pack at ~1.9V.
DB Custom
DB Custom's picture
Last seen: 2 days 8 hours ago
Nice find Gj, I have a couple of lights that I use this size cell in. Just picked up one of these, will give harvesting a go;)
Gj
Gj's picture
How would a seller test them? All I can think of is to charge them. Then they're not new anymore, right? Or I misunderstood what I read in other threads.
These drop right into those free Harbor Freight flashlights and work fine without an adapter, should need recharging every year or so. Laughing
DB Custom
DB Custom's picture
The cells look identical to the ones in your picture. 2 were at 2.23, 2 at 2.35 and 2 were at 2.02. 4 are in my SoShine Max 3 4 bay charger as I write this. The lower 4.
Battery case opened up really easy, tape came off clean, even the tabs were not too difficult to remove. Nice find! Nice price! Thanks for sharing this!
As far as buying these so cheap goes, with laptops getting outdated every year or so, these are almost assuredly old stock that the laptop they were designed for is not longer in production. So they are just recovering some losses. Makes sense to me, at any rate, to get Japanese cells for $1.50 ea works for me!
Thanks again, really appreciate it!
ImA4Wheelr
Last seen: 1 week 10 hours ago
I just noticed this thread for the first time.  Thank for finding and sharing this Gj.  I bought 2 packs.
DB Custom
DB Custom's picture
My first 4 are up to 3.94V in the SoShine S1 Max V3. I’m thinking they will work nicely in any of my single 18650 lights with a short spacer. Smile Almost free, considering. I have a single AW 18650 Protected that’s 3400mAh that cost over $20 by itself!
With a couple of smaller lights that actually used to use the 3AAA adapter, this works well and I plan to put them to good use. Now if I could just round up all those lights…
ImA4Wheelr
Thanks for the report DBCstm.  Please keep us updated.
One of the lights I plan on using these cells in is my Rook.  I get tired of fiddling with the 14500's and these are close to the capacity of 3 of 14500's.  Plus, I have other lights the 14500's can go in.
DB Custom
DB Custom's picture
3 at 4.21V 1 at 4.20V, put the last 2 on just now. I have no idea how to compute any of that, but it took 2 hours and 17 minutes at 1A charge rate.
DB Custom
DB Custom's picture
In my modded M3, an Efest IMR18650 2200mA cell will allow 4.28A. One of these charged up will allow 4.13A. Not bad! Smile
Gj
Gj's picture
I received 2 more today. I don't recall even seeing new 1700mAH 18500's for sale anywhere, usually 800mAH off-brands. This seller ships fast. Smile
Has anyone tried adding a protection circuit to cells? I see FastTech has them. I'd feel more comfortable with protected cells in my 4 cell UV light.
Gj
Gj's picture
That's an interesting mod. How are you going to bore it out? Will you need contact plates at both ends?
ImA4Wheelr
Not sure how it should be bored out.  I think I better ask some gurus for advice on that.  I'm guessing a drill at high speed in a drill press and moving slow.  Not much material needs to be removed.  So I could just use a curved file if I had too.  The driver takes positive in the center pad.  So no mod needed on the driver side.  Probably just drop a floatng plate in the bottom on top of the springs so that I can remove it to use 14500's.
Any one figure out the date code on your cells yet?  I wouldn't be surprised if they are fairly old, but one can hope they are not.
