DrVette
(DrVette)
October 1, 2013, 4:16am
1
I’m hoping to get some el-cheapo drivers to convert some 1-mode SK-68 clone.
[The existing 3-mode units have a too-high medium and no low]
FT
These will be used by Joe Homeowner with alkaline’s, maybe a few NiMh’s, doubt 14500 usage.
1~2* AA/AAA
5-Mode Linear Booster LED Flashlight Driver Circuit
0.9V~3.6V
Rated at
1.5V - 500mA
3.6V - 800mA
Reverse Polarity Protection-No
17mm x 1.5mm
http://www.fasttech.com/products/1612/10001750/1127407-12-aaaaa-5-mode-800ma-linear-booster-led-flashligh
edit
to add a driver from DX
http://dx.com/p/3w-5w-20-mode-regulated-circuit-board-for-flashlights-7880
Thanks and all replies and opinions welcomed as usual.
Hi man. If you ever get this going, can you put some pics up so that I can get a clue how to mod Where are those wires supposed to connect?
What’s the SK68’s original driver look like? If it’s the same dimensions I don’t see why it wouldn’t fit.
I think there is a pretty comprehensive testing of that driver done somewhere here. Here is a review of it's one mode bother. Looks about the same except does not have an MCU.
In my other driver reviews I promised to post test results of this driver as soon as my order from Fasttech arrives, and here they are - sort of.
I have to say sort of, because the drivers I received are possibly not the real deal. I ordered three of them, and as soon as I opened the package I noticed they look different than the ones I received before.
The new driver has less parts and the pcb layout has changed as well. Unfortunately I haven't got any of the earlier drivers left to do a …
EDIT: Another review of the 1 mode verion:
Mode
LED Current Amps
LED Voltage
Tailcap Current Amps
Sanyo 18650 at 4.2 volts
High
1.75
3.1
1.9
Ultracell LiFEPo4 at 3.6 volts
High
.7
2.9
.8
Eneloop LSD AA at 1.4 volts
High
.37
2.79
1.9
This driver was purchased from Fasttech. Link below.
https://www.fasttech.com/products/1127402
Specifications from Fasttech website.
PERIPHERAL TYPE Flashlight Driver
Electronic Components
CONSTANT CURRENT Yes
DRIVER TYPE Boost driver a…
Werner
(Werner)
October 9, 2013, 10:09pm
6
If anyone gets a 17mm driver fit without machining the pill or finds a 15mm driver I would be very very happy.
I have need for some drivers too…
keltex78
(keltex78)
October 9, 2013, 10:38pm
7
Here's the thread on my SK68 driver replacement mod...
Pulsar13
(Pulsar13)
October 10, 2013, 1:24am
8
There’s no problem using 17mm driver - it will sit on the pill (not inside) and can be secured with some glue. I’ve been using one modded like this for about a year. It’s a regular 4.2V 17mm 3mode driver, used with TF Flame 14500.
I recommend also adding a ring on the negative driver terminal to enhance contact. I just use a solid copper wire bent to C-ring shape.
Werner
(Werner)
October 10, 2013, 1:17pm
9
I guess his method reduce the space between LED and lens so there is no perfect projection anymore when zoomed that’s not too bad…I will try it.
