Help Me Decide on a 26650 Light
26 posts / 0 new
Rusty Joe
Rusty Joe's picture
Last seen: 21 hours 57 min ago
I have decided to add just one 22650 light to my now meager collection, but can’t decide what. Criteria for deciding is…
-lightweight
-compact
-well-driven
-NOT a HD2010 (I’ve had four of those and the quality just sucks too much).
-budget
-more thrower than anything else
My runner-ups are…
-JM26
-JM07
-Prairiefire D11
Help me decide with a few-words review of what you recommend. Otherwise, I’m gonna get rid of the 26650 format and stay with 18650s from here on. This is driving me nuts!
Rusty Joe
Rusty Joe's picture
zelee
zelee's picture
Last seen: 1 week 3 days ago
Rusty Joe wrote:
This light just entered the race…
http://dx.com/p/ultrafire-xl-7003-cree-xm-l-u2-800lm-5-mode-white-flashl...
Big Smile
i hope this light doesn’t need to cycle through all the modes to turn it off Silly
how about this light
texas shooter
Last seen: 1 hour 3 min ago
JM07 or a good clone, it’s my favorite 26650.
leaftye
Last seen: 1 year 1 month ago
zelee wrote:
Rusty Joe wrote:
This light just entered the race... http://dx.com/p/ultrafire-xl-7003-cree-xm-l-u2-800lm-5-mode-white-flashl... :D
i hope this light doesn't need to cycle through all the modes to turn it off Silly how about "this light":http://wallbuys.com/Product/PAISEN-U2-Z6-CREE-XML-U2-1000-LM-Strong-LED-...
It has decent throw, but it calls for a different driver and thermal grease under the mcpcb.
The low mode should be lower.
zeremefico
zeremefico's picture
Last seen: 3 hours 6 min ago
If HD2010 quality is not enough for you, you should search for a non-bugdet flashlight.
Where did you buy your HD2010s?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Rusty Joe
Rusty Joe's picture
zeremefico wrote:
If HD2010 quality is not enough for you, you should search for a non-bugdet flashlight. Where did you buy your HD2010s?
1) Easy(HARD!)LightBuy.com
2) Tmart
3) Lightmalls
They all crapped out on me or flickered.
zeremefico
2) Tmart
3) Lightmalls
I believe you were unlucky, HD2010 is one of the best budget lights out there.
I own Trustfire A9 which is 26650 and might suit you. Also search for Palilight, they offer some 26650 models. Hope I helped you a bit.
My YouTube channel
K40M F16
Rusty Joe
Rusty Joe's picture
Thanks. This search is expanding with nearly every post!
gorky
you should consider XinTD X3
gords1001
gords1001's picture
Last seen: 3 years 7 months ago
convoy l2, great build quality and moddable.
nottawhackjob
Last seen: 18 hours 56 min ago
Absolute best bang for the buck IMO assuming you can find someone to do a simple bore out of the switch end of the tube, is the DST.
You don’t have to chop it either of course to gain the best of a few battery configuration worlds to boot plus that big reflector gives you so many options.
Can’t say enough good things about this or a similar setup.
http://budgetlightforum.com/node/23186#node-23186
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
nekdo12
Last seen: 7 years 11 months ago
Flomotion
Flomotion's picture
Last seen: 8 months 1 day ago
Flomotion
leaftye
gorky wrote:
you should consider "XinTD X3":http://intl-outdoor.com/xintd-x3-xml2-3aa-flashlight-p-739.html[/quote]
Since that has an integrated pill, a replacement pill would be huge and very expensive.  There isn't a thermal path with the X3 is already quite good aside from a little dip in the middle.  The main benefit for a new pill would be if it was redesigned to allow the use of protected 18650 & 26650's, or if it had a hole and plug to accommodate the use of a side clickie.
Oops.  Wrong thread.
Yes, the X3 is a nice light.  I have one.  I'd buy an updated version if it accommodated protected cells, and then I'd buy a third one if it had a side clickie that still used the Qlite driver.
gords1001
gords1001's picture
+1 to this ^^^^^
the x3 is minor developments away from being perfect.
I would add to the above, make the body tube 34mm id and 70mm internal length, it should then be possible to take 4aa/32650 protected cells and 26650/18650 with appropriate sleeves, side clicky would be easy to implement with a qlite but would add a little overall length, the trade offs for the above would make it just about the most awesome light available in this class.
Flomotion
Flomotion's picture
http://www.aliexpress.com/item/Portable-Cree-XM-L-U2-LED-2000-Lumens-5-Mode-White-Light-Waterproof-Flashlight-1-x/1402561378.html
3.5 amp at the tail on a Sony 26650 VT
Flomotion
DB Custom
DB Custom's picture
Last seen: 3 weeks 3 days ago
I need 3 of those Flomotion, I could strap them together for 12,000 lumens of light! Smile
Flomotion
Flomotion's picture
Chinese Looomens real about 800, hey, I was impressed for the money, nice gift to yourself. I find myself actually using this torch for actual use, it is a good combo light.
Flomotion
DB Custom
DB Custom's picture
I just recently ordered the Raysoon F13, plan to mod it into a useable daily use light. Have a couple of 26700’s I need to put to use, hope they fit (if not, I’ll make em)
Flomotion
Flomotion's picture
Well, well, I just put my Moli 26700 in it, perfect fit!
Flomotion
Rusty Joe
Rusty Joe's picture
Couldn’t resist at this price. Just ordered. It’s gonna run a Kong. 3.5 amps would give over a thousand lumens at start! I’m hoping I get that.
DB Custom
DB Custom's picture
Now that…is some serious Flow Motion!!! Sweet! Thanks Flomotion, appreciate ya checking it. Wink
nottawhackjob
the DST, now with this timely 26650 tube that mates with the head you can have it even better.
Plus now you have that extra XML-U2 & its head to mate back to the original DST tube on top of it.
A very compact DST running on a 26650 for a mere extra $6 and change. You put in the driver you like too.
I mean if I had to settle for one 26650 setup as you state there’s nothing out there for the money that comes close.
What’s not to like? :bigsmile:
http://budgetlightforum.com/node/25612
Flomotion
Flomotion's picture
I did that, but there is no switch in that configuration
Flomotion
nottawhackjob
If the 26650 tube screws into the DST head then doesn’t conversely the DST side clicky attached to the DST tube screw into the 26650 XML-U2 head as well?
Granted you lose the DST side clicky with this setup but you should also have a shortened setup with just the 26650’s tail switch, no?
Edit: Anyone know if my thinking here is incorrect? I still bought one anyway. :bigsmile:
