Some of you may already be familiar with the Photon-style Inova Microlight. The Night Vision range from Inova offers coloured LEDs in the same slim form factor.
Gone are the low mode, SOS and strobe, in their place are mechanical switching that make it more comparable to the fauxton lights: squeeze the soft button for momentary on, slide the switch on the other side to keep it lit.
Retail packaging, no scissors required:
Run time of up to 15 hrs stated:
Although the red rubber forms a large part of the top, only the centre activates the light. The switchable part has grooves so you can tell by touch:
The slide switch has nice grip too, but on my example is a little stiff. It is easier to use than the tiny slide switch on a fauxton:
Often cheap fauxtons ship with two CR2016 cells which together is too much for a red LED and shortens the life. Here a single Panasonic 2032 cell is included. The rubber button can simply be pulled out to change the battery:
I bought this with plans to change the LED, but a closer look shows modification might not be so straightforward as the casing has been melted to secure the metal contact leaf:
Instead of protruding from the case the LED sits recessed, so the casing acts as a kind of diffuser:
The clip:
Size comparison to other keychain lights, from largest to smallest (from left to right: Ring Micro Cybalite, Inova Micro Light, DX fauxton):
Inova actually feels the slimmest:
Quite a lot of the casing also lights up:
Beam shots at 50cm. Left is Inova Microlight, right is DX 20cd fauxton. The effect of the casing is clear. Although not as nice a beam, it allows for more spill from a 5mm LED:
For comparison sake, left is Ring Micro Cybalite with stock LED, right is DX 20cd fauxton:
White wall beam shot at 1 metre. The beam is larger than a typical 5mm LED but not without imperfections:
For contrast, here is a SK-68 clone (probably XR-E Q3 emitter) with red filter. The 5mm red LED is a cooler red and feels a little unnatural in use.
You can see there is more orange present in the red filtered SK-68:
Thanks for reading! ^_^
