DQG 26650 3 XP-G2 available at wallbuys
http://wallbuys.com/Product/DQG-26650-Triple-3-x-CREE-XP-G2-R5-1A-CW-1250LM-5-Mode-Cool-White-LED-Flashlight-Black-1x26650—11648
I guess this light is available at wallbuys now. They need to speed up their shipping.
Any Discount Code work with this Light?
You can always try the blf code. Their shipping sucks though. I get orders from fasttech in 9 days and 30 days or more from wallbuys
WALLBUYSALLMAGIC shows $5 off.
meh… for $40 after code not too impressed
when its $22-25 ill buy one
but thank you for posting
Looks interesting but too expensive IMO.
try TFFWALLBUYS, it’s a bit better (but not much more) than the WALLBUYSALLMAGIC
bah… they’re run out :weary:
Where does is say that they have run out?
Right under the ‘Product Features’ section:
Notice: The factory just told us that they will send this new model to us in 6th November ,so just wait for it
Perfect. The 6th is my birthday.
Quick review. It’s light in fact its slightly lighter than an empty Solarforce L2M host. I’m running it on a MNKE imr 26650. Low is 0.01 amp, medium is 0.29 amps, high is 1.11 amps. A quick double tap gives an initial 5.60 amps settling down to 5.10 amps before the 30 second limit kicks in. Switch is electronic and lags about a half second after being pushed. A little twist of the tail cap locks out the light. Fit is a little rough with garbage in the threads. The tube had on both ends rough inner edges that needed trimming. Finish is average. The body tube is 0.057”/1.45 mm thick. It’s not a $45.00 light. I would like to see its mass double and the current levels double for Low/Medium and 1.5 times higher for High. The 30 second turbo is right for its light weight.
$36.00 @ Banggood with code bgf155
Link: (non aff)
http://www.banggood.com/DQG-3xCREE-XP-G2-R5-1A-Or-3B-Tiny-Triple-LED-Flashlight-26650-p-910416.html
