I want to assemble some Disaster Supply Kits for family.
I have sturdy backpacks I picked up Goodwill, and I added Long shelf life “Water Blocks” , Nutrition Packs
hand tools/gloves/duct tape/fire starters —but looking to add torches and batteries to the kits.
Are lithiums the way to go?
Will they hold most of a charge (60%?) for 5 years?
Rechargeable or primary not as important as ability to maintain a charge.
I have this WakaWaka in my GO bag, as well as a few others lying around like this one from Fasttech as well as a few 18650 battery packs. Everything is USB based so it’ll be really simple in an emergency to move power around to the devices that need it.
Here’s a random dump of some photos which show what I am talking about: The flexibility of USB charging. I even have a crank light with a USB port on it. Towards the bottom you can see me charging some NiMH cells with a USB charger from one of the battery packs.
A small inverter is a must for emergencies
So is a portable tire inflator which also acts as a 12V power source I can plug a USB dongle into
I have a Goal Zero solar panel Amazon.com that I’ve used to charge NiMh batteries as well as my Android cell phone. The included battery charger works but I don’t think the channels are independent.
I much prefer the Sanyo because it has an attached USB cord while the Recyko plugs directly into a USB port (unless you use an USB extension cable). Also the Recyko has a sliding mechanism that you have to push down to insert the batteries, which doesn’t seem all that robust to me.
It’s more cost effective to just get the panel (around $80) and then get one of the chargers above. Unfortunately for me the Sanyo’s weren’t being made when I bought the panels, and I didn’t know about the Recyko’s.
