Test/Review of Tensai AA TR-6 2000mAh (White)
Official specifications:
  • Model: TR-6 (single cell) / 4TR-6 (4 pcs blister pack)
  • Manufacturer: TENSAI
  • Size: AA, LR6
  • Chemistry: NiMH (Nickel Metal hydride)
  • Nominal Voltage: 1.2V
  • Capacity: Minimum: 2000mAh, Typical: 2050mAh, When discharged at 0.2C to 1.0V at 20°C
  • Fast Charge: up to 1000mA
  • Service Life: >500 cycles
  • 90% charge after 6 months, 80% charge after 12 months.
  • Internal Resistance: <55mOhm (upon fully charged)
  • Diameter (mm): 14.5
  • Height (mm): 50.5
  • Weight: 28g
Maximum temperature raise at different discharge currents: 1A:+1,9°C, 2A:+5,0°C, 3A:+8,0°C, 5A:+14,3°C, 7A:+19,4°C
These cells are LSD (Low self discharge, i.e. they can stay charged for a long time.
The cells can handle a lot of current, but there is small differences between the cells.
Being a NiMH cell the capacity differences between the two tested cells is only a minor problem.
Conclusion
The cell has more than rated capacity and good performance.
Notes and links
The batteries was supplied by ENERDan for review.
Thanks for the test.
Seems like good cells.
Compared to eneloops these have slightly lower voltage under load but overall more capacity and energy…
thanks for the review, nice to see more alternatives.
