I was just wandering if anyone knows where to get some decent buck drivers that are 17 ish mm. Ideally a direct swap for a 7135 base driver or something close. 2.8A or more would be great. Nice 3 mode maybe???
Anything close?
I am trying to find a driver that will be a direct swap for the nanjg type boards so I can use them in my Maglite dropins.
I don't know that driver specifically but be careful, most of the 'LD-xx' drivers are not buck drivers, but constant current drivers that are made for multi-cell input voltage. If that's the case with this one it'll run a single 3v LED, but not multiples in series or a 6v MTG2 even when the input voltage is higher than the Vf.
That’s a hard one. :~
The driver linked from IO might have problems with the low voltage step down with the various voltage options. I don’t have the driver, so I cant be sure. That’s a lot of different voltage options your trying to fill. I don’t know of any solution. You need it to still accept a voltage of 8.4v correct?
Have you tried running 4 Nimh’s with a amc7135 board and a XM-L2? With the higher vf it might work.
So, what voltage range are you aiming for? I doubt there are drivers that work well for 2+ LiIon cells AND single cells.. so for single cell applications just stick with the good old Nanjg, for anything else.. depends on the number of cells.
I dont really need one that spans the gap between the 3-4D cell. I only asked about what kind of current is gotten from that board because it said it would work. If I can just find a buck driver that swaps out for 5 or 6+ volts that would work.
