Test/Review of Kinoko IMR18500 1200mAh (Gray)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 5 hours ago
DSC_3907
Official specifications:
  • Brand: Kinoko
  • Style: Button top
  • Nominal Voltage: 3.7V
  • Capacity: 1100mAh
  • Lowest Discharge Voltage: 2.50V
  • Standard Charge: CC/CV ( max. charging rate 1.5A )
  • Cycle Life: > 500 cycles
  • Weight: 45g
  • Length: 48.78
  • Diameter: 18.21
Kinoko%20IMR18500%201200mAh%20(Gray)-info
This battery is shorter than a 18650 and has considerable less capacity. This battery is an IMR cells
DSC_3906
DSC_3908 DSC_3909
DSC_3910
DSC_3911
Kinoko%20IMR18500%201200mAh%20(Gray)-Capacity
The battery does fine with up to 7A discharge current, constant capacity and fairly good tracking between the cells.
Kinoko%20IMR18500%201200mAh%20(Gray)-CapacityTimeHours
Kinoko%20IMR18500%201200mAh%20(Gray)-Energy
Kinoko%20IMR18500%201200mAh%20(Gray)-PowerLoadTime
Kinoko%20IMR18500%201200mAh%20(Gray)-TripCurrent
Kinoko%20IMR18500%201200mAh%20(Gray)-Charge
Conclusion
The battery can deliver a lot of current, but capacity is fairly low (This is the same for all 18500 IMR cells).
Because the battery is from an unknown manufacturer I will limit my rating to acceptable.
Notes and links
The batteries was supplied by Illuminationsupply for review.
Gj
Gj's picture
Thanks for the review.
NightCrawl
Last seen: 5 years 7 months ago
On par with Efest. Nice.
