Tangsfire C8 XM-L2 U3 Review
174 posts / 0 new
Muto
Last seen: 8 sec ago
unknown00101 wrote;
“Got my Tangsfire C8 in today.
502b is 2.55A +/- .2ish on unprotected vs protected 18650.
C8 is 3.55A on 4.14v unprotected NCR18650B 3400 (A little disappointing compared to what others are getting).”
[/quote]
Solder some braid on the driver spring and that amperage will come up well over 4 amps. Mine has approached 5 amps and some crap started to smoke up off the dome of the LED, Smoking seemed to stop after a short time so I really think it was just some dirt/etc. I have since used a battery with more resistance to lower the power a tad to be safe.
Eventually it will get a Copper Sinkpad and new emitter.
HTH
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
BLightSam
Last seen: 3 years 3 weeks ago
Muto wrote:
… Solder some braid on the driver spring and that amperage will come up well over 4 amps.
What material is the braid? Pic of the driver spring w/ braid?
relic38
relic38's picture
Last seen: 4 years 3 weeks ago
Solder braid is made of copper, here’s a how-to:
http://budgetlightforum.com/node/22529
I’ve ordered one of these, you know, because I do not have enough C8s already Wink
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
unknown00101
Copper,
I just found it a bit disappointing because I was expecting 4A+ stock.
Edit: relic beat me by seconds! Silly
Muto
This is the stuff;
http://www.radioshack.com/product/index.jsp?productId=2062744#
Or here;
https://www.fasttech.com/products/1004/10002730/1202500
Sorry, I don’t have a picture of it installed.
Look here for details on spring braiding ;
http://budgetlightforum.com/node/22529?page=1
Thanks,
Keith
Edit, Damn you guys are quick!
BLightSam
As somebody said, “Damn you guys are quick!” Smile Thanks for the responses.
Asked about the braiding thinking that no delicate soldering is required, thus even I can do it, my first ever modding. Cursory reading of the linked posts confirms that (even though tad more involved than I first visualized). Will order the braid first and mull over the soldering. Again, thanks for the ‘damn quick’ responses!
DayLighter
DayLighter's picture
Last seen: 4 years 8 months ago
dang.. that desoldering stuff from radio shack is mad expensive.. you can get 2 of those for half price from fasttech.
but then again.. you get it right away though Silly
The only way to do a great work is to love what you do.
noravanq
Last seen: 10 months 3 weeks ago
I got my light today. It looks really bright.
I was surprised to see it has next mode memory. Others here were saying it always should start on high. IMHO, next mode memory is the worst kind of them all.
unknown00101
I checked mine, and thought you performed some sort of bad juju curse upon it because it too was showing next mode memory.
But a few more tests later I found that the reset to high is approximately 8 seconds once turned off (Which is very slow compared to my other lights, normally it is around 2-4 seconds).
jmpaul320
jmpaul320's picture
Last seen: 1 month 2 days ago
i am impressed with mine
i had a spare ucl i installed too
a good light for the price
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
noravanq
That’s great! I checked mine again after seeing your comment, and you are absolutely right. It acts like a next-mode memory when you don’t wait before switching it on again, but turns on high if you wait long enough.
I am really impressed with both the throw and very useful spill.
noravanq
Does this light have a low voltage cutoff or a low voltage warning? Doesn’t seem to be indicated anywhere.
Thanks.
noravanq
From green protected panasonic ncr18650b my light measures as follows
High: 2.6amps
Mid: 1.0amps
Lo: 0.18amps
using a $20 craftsman DMM.
The cables are 2-3 feet long, and 18awg.
unknown00101
High: 2.6amps
Mid: 1.0amps
Lo: 0.18amps
Mine pull somewhere around 3.2A on protected iirc which is still comparatively low to other’s readings. I believe your leads may be limiting your readings though. I’m using 10gauge a bit over a foot long.
saypat
saypat's picture
Last seen: 1 week 1 day ago
High: 2.6amps
Mid: 1.0amps
Lo: 0.18amps
My readings are very similar! $5 meter off E-Bay, but replaced the leads. I am not into the ‘numbers’ but am very happy with this purchase and its’ performance. Hoo-yah!
freeme
freeme's picture
Last seen: 5 hours 51 min ago
Just received my Tangsfire pairs. Here are my rough results (stock).
Mode Unit1 (A) Unit2 (A)
H 3.24 2.62
M 1.3 0.97
L 0.23 0.14
Two of them yield rather different results using same NCR18650B unprotected 3400mAh@4.16V
Over-rated product?
1thedeals.comyoutubeAstroluxNealsgadgetsolight
FlashPilot
FlashPilot's picture
Last seen: 53 min 10 sec ago
Damn! I hate the fact that they cant built a descent 92 driver any more! WHAT IS WRONG WITH THESE PEOPLE!!!??? |(
… thanks for posting your results.
freeme
freeme's picture
Both of my units have dirty dome. Requires some cleaning.
Muto wrote:
unknown00101 wrote; “Got my Tangsfire C8 in today. 502b is 2.55A +/- .2ish on unprotected vs protected 18650. C8 is 3.55A on 4.14v unprotected NCR18650B 3400 (A little disappointing compared to what others are getting).”
HTH
Keith[/quote]
noravanq
saypat wrote:
High: 2.6amps
Mid: 1.0amps
Lo: 0.18amps
Me too. I measured the amperage just for comparison reasons. Otherwise I am very impressed and happy with this light.
freeme
freeme's picture
Anyone knows if I can get an 37mm OP reflector replacement? Does it exist?
Nbabu
Mine should arrive any day now. I think I’ll improve it and will give it as a present to a friend.
I was thinking about soldering some braid at the tailcap and changing the wires from the driver to the led. But what width should the braid be? And what diameter should the replacement wires be?
“Trout are freshwater fish and have underwater weapons”
relic38
relic38's picture
If the ones at Fasttech will fit, then yes. Smile
They are the ones used in Convoy C8 lights, if that helps. I do believe they are a standard C8 reflector format.
Welcome the night.
unknown00101
relic38 wrote:
If the ones at Fasttech will fit, then yes. Smile They are the ones used in Convoy C8 lights, if that helps. I do believe they are a standard C8 reflector format.
Iirc the tangsfire has the deeper reflector.
relic38
relic38's picture
OK, once I get my Tangy C8 I’ll compare and try the fit.
Welcome the night.
penumbra
penumbra's picture
Last seen: 1 year 8 months ago
saypat
saypat's picture
penumbra wrote:
http://www.customlites.com/McR-38-Op-Reflector-McR38-OP.htm
where are they located?
Calmaja
Last seen: 2 years 5 months ago
I’m not sure either, but if the size is correct, I guess this one can fit Tang’s C8.
41 × 37mm OP reflector
Nbabu
This is the measurements in the openings post:
The reflector is smooth aluminium, 35 mm deep and 40mm wide
Hope that helps
freeme
freeme's picture
USD21! I rather spend on brand new Convoy C8 Smile
freeme
freeme's picture
Measurement is right. I think it will fit in. Thanks.
