Direct Drive MT-G2 with Two Samsung 20R's
54 posts / 0 new
moderator007
moderator007's picture
I first tried the MT-G2 with a fasttech TR-0124B driver, a TR-3T6 copy. I used a fasttech 10 ohm pot wired parallel to the original sense resistor as seen here on the driver. http://budgetlightforum.com/node/24933
The heat sink had a copper center section that I used to reflow the entire noctigon 20mm board with the MT-G2 on to.
With 2 NCR18650 2900mah laptop pulls, the driver done 4.5 amps to the MT-G2. Well, I wasn’t all that impressed with the driver. So I added another battery for a total of 3 and checked it again. The driver gave 8 amps to the led. Now I’am impressed. I didn’t test it more than about 30 seconds, the aluminum copper Maglite heat sink I made was blistering hot, no where near enough heat sink out of the light. I have no idea if the driver will survive at that current for very long. I didn’t notice anything getting hot besides the 10 ohm pot and it never got to hot to touch but that was only at 30 seconds of use.
The mag I intended to but this in is a 2D so as I was trying to figure out what I was going to do about getting 3 li-ions in a Maglite. I thought to myself, I don’t want to do that. I just got 2 of those Samsung 20R’s from RMM, Hey I’ll try those. I decide to take pics this time, so you couldn’t say it didn’t happen. :bigsmile:
That was the reading I got directly after plug it up direct drive.
This is what I got after 30 seconds. I don’t know if the cells where just starting to heat up and let the current flow or if it was the led heating up and dropping the vf. 9 amps direct drive with cells that have a very good voltage curve under that current. That should do just fine with no driver at all though modes would be nice.
At that current in 30 seconds the heat sink was getting so hot I couldn’t even think about touch it. It took a few minutes before I could even begin to touch the thing again. I have never seen a led produce so much heat in that amount of time. I set up another meter with a thermal probe and taped it to the heat sink, just to see how hot it was getting.
That was right around 30 seconds of being on and by the way that’s fahrenheit. You could boil water on that thing. I’am not real sure the Maglite body is even going to cope with this amount heat for any length of time. I guess I’ll find out. Shocked
Edited by: moderator007 on 12/08/2013 - 23:54
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 4 months ago
Do the words "massive heat sink" sound familliar?Wink An MT-G2 at 8-10 amps would need one, to last very long. The big heat sink, is only to, well, sink heat... It can't get out of the body fast enough to keep it stable, so a really big heat sink will just extend the inevitable, but that extends run time. Try a 4D maglite, with a tail cap switch and make the area from the top of the tube, all the way back thrub the first two cell places, into all heat sink. Now you got a little run time before the led melts off the star.Smile
One of these days, I need to al least do a lux test between an SST-90 at 10 amps and an MT-G2 at 9 amps.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
moderator007
I for one would be interested in that test as well OL.
That’s about the only way I see it too. There’s going to have to be more heat sink in this thing some where or back off the current, and who wants to do that. :_(
I original thought I would be able to use it for a few minutes at a time with out getting to hot, but now I think a minute may be about tops. Funny thing you mentioned the led sliding off, I kept checking the MT-G2 ever time I turned the power off to make sure it was still there. :bigsmile:
DB Custom
DB Custom's picture
Last seen: 3 days 6 hours ago
In my Solarforce M8, with the MT-G2 reflowed to 3 ounces of copper on a Noctigon (all reflowed together) and using 2 Samsung 20R cells, direct drive I was seeing 12A and 4140 OTF lumens at start-up, with the numbers falling like a bag of cement out of a helicopter.
I’m running it at 5.98A now on 2 Panasonic NCR18650PF cells through a Qlite, for 2322 OTF at 30 seconds, 2636 OTF at start-up. The MT-G2 is now sliced and diced. Smile
MRsDNF
MRsDNF's picture
Last seen: 6 days 11 hours ago
I like it. I haven’t succeeded in cooling the MTG-2 for continued running at that current either. Even 5 amps creates a tremendous amount of heat.
DB Custom
DB Custom's picture
Gosh, maybe we should listen to Cree and keep em at 3A or below!
Naaaaaaaaaaa! Silly
Just use em when it’s real cold out, not a problem! manxbuggy1 and rdrfronty brought some lights over and we went out and played, maybe 80 lights between us. At 40º and windy my K3 at 4.74A and 2311 OTF wouldn’t even warm my hands!
moderator007
12 amps from 2 cells. What charged voltage on the cells did you start out with? Did you warm the cells up first? I wouldn’t even have thought that was possible from djozz graph. http://budgetlightforum.com/node/22636#comment-417559
Not saying it didn’t happen, I just wouldn’t have thought it was possible with 2 cells and voltage sag. That’s impressive DBCstm!
Mine was actually increasing in current, I didn’t have enough heat sink to see where it stopped at.
moderator007
Thanks for the info. I was going to PM you ask how well your light coped with the heat.
If all the copper you used want get it done, then what will?
Old-Lumens
moderator007 wrote:
MRsDNF wrote:
I like it. I haven't succeeded in cooling the MTG-2 for continued running at that current either. Even 5 amps creates a tremendous amount of heat.
Thanks for the info. I was going to PM you ask how well your light coped with the heat. If all the copper you used want get it done, then what will?
Active Cooling, not passive. If one would forgo having a waterproof light, then a larger body light, (3x18560 or 4x18650), with a large head could be used and add a cooling fan.
Original led shelf
Copper CPU heat sink underneath
Cooling fan under the fins if the heat sink
Metal separation plate, so there would be inlet air and outlet air
Holes drilled in the head at both inlet and outlet.
With a 2S/2P battery set-up, you could just use a 6v fan. Plenty of them in round format, to fit into a head
Best off with a head/body made by someone with a lathe
I was going to do similar with an all copper light and 7xSST-90 leds, but I could never afford to make it.
fan
It could be simplified by drilling holes in the original led plate and letting the fan blow thru it and up around the reflector and exhaust out holes near the bezel area. For a custom one off light, who cares about the holes really?
Or, everything could be made so the fan area is  sealed off so moisture only gets there and use a sealed fan.
18sixfifty
18sixfifty's picture
Last seen: 1 year 6 months ago
I put together a direct drive last night with 2 king kong ICR’s to a MT-G2 It’s in a body from a 4xt6 no pill so the heat transfers directly to the head and out of the light. Works great outside but it’s well below freezing outside right now. Orange peel reflector 3,000 lumens, excellent flood and the tint is super. Perfect for walking around the backyard with (five acres) but I wouldn’t take it on long hikes. It was still at 3,000 lumens when I came inside. The head was hot but not the batteries so that’s good.
I put two of the Samsung 20r’s in a ZY-T08 MT-G2 that has a lustefire driver, it was popping the protection on Panasonic protected batteries after 30 seconds or so on high. With the Sansungs it was way more lumens at startup but dropped down so fast that it wasn’t worth running them. So I’m running Sanyo unprotected and it’s great.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
DB Custom
DB Custom's picture
I like to test em on rested cells. My SoShine S1 Max V3 charges these to 4.21V, after a rest period they stabilize at 4.18V. This was just done recently, as I haven’t had my lightbox long, and the weather has been chilly so the cells were probably under 70ºF when I started the test.
I also took the body off the M8 and tested it with 2 Powerizer 26650 cells. The amperage was almost identical to the 20R’s with slightly more lumens at start-up, but falling the same. The 20R’s seem to be a near equal to the larger 26650 and it’s one of the best out there.
I tested 4 different cells with the MT-G2 in the M8 in it’s regulated form, with interesting results…
Sanyo lap pulls 5.92A 2205 OTF at 30 sec.
Efest IMR V2 5.96A 2260 OTF at 30 sec.
Sam 20R 5.98A 2087 OTF at 30 sec.
Pan PF 5.98A 2322 OTF at 30 sec.
The Panasonic does what the best Hi Discharge cells do but have considerably better sag control with their 2900mAh capacity. So that’s what stay’s in em. The Sanyo lap pulls at 1.08 ea. hold their own quite well too, best bargain cell I ever bought! (HP battery pack, 12 of em for 12.96 shipped)
Sliced and diced
moderator007
OL, that ought to do it. :bigsmile:
That’s probably a little more time than I would want to invest at the moment, but who knows if I cant find some happy medium. Where have all you MT-G2 users been hiding?
I might end up making a copper aluminum head extension, similar to what OL was suggest with the 4D. Just use the 2D and a massive extension.
DBCstm, did the tint shift noticeable after your dome fell off? :bigsmile:
Lothar
Lothar's picture
Last seen: 20 hours 26 min ago
I too would be very interested in that test. Perhaps even a SBT-90. With almost half the Vf of the MT-G2, the watts and heat would be almost half at 9-10A. If lumens are close to each other, the SST-90/SBT-90 might be a better bet. Is there sinkpads/noctigons available for SST-90's?
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
LinusHofmann
LinusHofmann's picture
Last seen: 1 year 9 months ago
Lothar wrote:
I too would be very interested in that test. Perhaps even a SBT-90. With almost half the Vf of the MT-G2, the watts and heat would be almost half at 9-10A. If lumens are close to each other, the SST-90/SBT-90 might be a better bet. Is there sinkpads/noctigons available for SST-90’s?
The MT-G2 should definitely win in the lumens department, but potentially higher lux and cleaner/tighter hotspot from the single die sst90 could be beneficial in some lights. A comparison between a 5000k sst/sbt90 vs a 5000k mt-g2 (domed and trimmed) would be very interesting!
DB Custom
DB Custom's picture
The dome is still on 007, it’s just been sliced off directly above the die surface, and the phosphor extensions around the dies diced and removed. This gives a bit tighter hot spot, a little warmer tint, and better throw from the hybrid reflector in the Solarforce M8.
All in all, a nice experiment. Tint is about the same, maybe a bit more towards green than pink, as my triple Nichia 219. It looks merely warm by itself, but side by side next to the Nichia, it’s not as rosy a warm.
DB Custom
DB Custom's picture
The M8 has a separate pill from the rest of the light…the pill is the mid-section that the battery tube and head screw onto, with the Noctigon thermally pasted directly to a shelf on the top end. I’ve added 1/2” of copper under this shelf, which of course is still not enough.
My plan is to put any money I receive at Christmas towards a fully copper mid section. VOB will be doing this for me. A bit wider in diameter, with thinner fins than the stock finned mid-section and about 10mm longer as well. The Noctigon will then reflow directly to this finned copper mid-section and it should be good for me to go direct drive. I will be utilizing a 20A switch…the smart switch, from mattaus in Australia. Should be good for the full 12A and we’ll see how the Panasonics handle that.
Might be pertinent to have VOB machine the copper section to fit his new HD2010 extension tubes and go with 2 26650’s instead of the 18650’s for better sag protection and longer run times. Hmmmmm……
The sliced and diced emitter in the baked M8 pill…
“Pill” in the M8, notice that the HA TypeIII anodize baked into an olive green military look, which compliments their choice of font quite well!
The M8 baked, in shorty configuration using one tube
Lothar
Lothar's picture
Hi Dale. I thought the sliced and trimmed MT-G2 had a cooler tint than the original unmodified MT-G2? How does the tint of the sliced and trimmed MT-G2 compare against a dedomed XML2?
DBCstm wrote:
The M8 baked, in shorty configuration using one tube !
That is pure flashlight porn there! (running off to bathroom) 8)
Current Collection:
nitro
nitro's picture
Last seen: 3 years 3 months ago
here is a copper sink that i was going to use in a monster build but never got a chance yet to start lol but that’s what u need Smile
! photo copper1_zps62f7c61b.jpg!
holes drilled for the wires and drilled and tapped to hold your star in place. with a set screw to hold the slug in place in side a maglite body
! photo copper_zps34c94d2d.jpg!
RaceR86
RaceR86's picture
Last seen: 5 years 2 months ago
Ive been doing direct drive MT-G2 for some time.
With fresh 20R, im seeing around 9A on startup and uptowards/around 9,5A after a bit (15-20 sec?) runtime (on the tail).
Thread and post here.
If you want sustained high output, the Sony 2600mAh 26650 is better than the 20Rs.
Ill start a beamshot thread some day this week comparing that light and several other high output lights, already have the pictures. Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
DB Custom
DB Custom's picture
Like a big fuel tank for heat, huh Nitro? Wink
Race, the Powerizer 3600mAh cell does even better for total amperage, just saw today that while the 26700 Moli doesn’t make as high amperage at start-up, it holds it longer than the Powerizer. A trade-off. Kind of tight squeezing those Sony’s into places made for 20R’s…..
RaceR86
RaceR86's picture
Proper direct drive MT-G2 makes a lot of heat.. Larger 26650 lights are better suited, and 26650 are generally better at maintaining high voltage under load (not that my 26650 light has got a pill to body contact that is well suited for direct drive 26650, but it works. Smile
I have yet to see some discharge graphs for the Powerizer compared to the Sony cells. If you want better amperage, King kong is an option too. Silly
Question is, is the Powerizer on level with the Sony in terms of voltage sag when its been used for some time.. Direct drive is all about limiting voltage sag and achiving high amps..  J) (atleast for me it is)
A comparison picture I posted in another thread, but 10A is kinda similar when looking at the cells ability to maintain high voltage.
Peak amps on the 20R and the US26650VT are quite similar, but use them for 5-10 minutes and its easy to see which is better.
I hope HKJ will test the Powerizer and more 26650 cells. Im in need of more 26650 cells..
moderator007
I had figured that out by your description, I was just poking at you a little. Big Smile
Thanks for the info about the tint. That M8 looks awesome as a MT-G2 host.
I stuck everything together late last night. With 2 Sanyo UR18650FM protected batteries I was seeing 4.5 amps of tail cap current. With the 20R’s I was seeing a little over 6 amps in the mag with everything stock besides the heat sink and the led. The cells where a little down on voltage as I had been playing around with them without charging them up.
It lit up a power pole at a hundred yards like daylight, huge hotspot and that’s with a rebel reflector. The XML in a mag does good at lighting up the power pole too, but it doesn’t light up the whole pole with intensity like the MT-G2 did. It lights up everything in the beam path even the spill is bright.
The mag did not seem to get that hot until after about a minute. I had used some thermal paste in between the head and tube threads but most all the heat was running down the tube. I had finned the head to help get rid of some of the heat, but after a minute it didn’t seem like the head was absorbing much of it. I guess it was making heat so fast it hadn’t had time to get to the head yet. The tube heat was increasing with every second and I could definitely tell where the heat sink was placed. Didn’t run the light much longer than that. I was impressed with the amount of light this mag was putting out. I have a 4 XML kung running 10 amps and doesn’t seem as bright from memory as the MT-G2 mag. Maybe I’ll find time tonight to get them outside and compare.
DB Custom
DB Custom's picture
Very nice, love it when a plan comes together! Are you as impressed as I am with the Sanyo UR18650FM cell? Who would have thought a $1.08 cell would perform like that! Smile But then, they didn’t cost that new going into the HP battery pack I’m betting.
I’m really loving the MT-G2, incorporating it more and more. Wish it weren’t so hungry, but I reckon it’s the nature of the beast. Thinking about using one in a smaller light, keeping power level down and accepting the lumens it makes for the gorgeous tint I prefer.
djozz
djozz's picture
Last seen: 9 hours 58 min ago
DBCstm wrote:
Very nice, love it when a plan comes together! Are you as impressed as I am with the Sanyo UR18650FM cell? Who would have thought a $1.08 cell would perform like that! Smile But then, they didn't cost that new going into the HP battery pack I'm betting. I'm really loving the MT-G2, incorporating it more and more. Wish it weren't so hungry, but I reckon it's the nature of the beast. Thinking about using one in a smaller light, keeping power level down and accepting the lumens it makes for the gorgeous tint I prefer.
My Shadow tc300 (a modest size light) modded direct drive with a MT-G2 does 8 amps (initially) on two cgr18500ch's for a few minutes of wow, and for prolonged use I can put two A123 18650 LiFePo 's in it for 2A and 1100 otf lumens.
DB Custom
DB Custom's picture
How is the heat in that one djozz? Is there a line there somewhere in the middle where the choice between XM-L/XM-L2 crosses what the MT-G2 is doing? I put an XM-L U3 in a SupFire F9, driving it at 4.41A with Sanyo lap pulls for 1259 lumens OTF at 30 sec.
Makes me wonder at what point the 2 footprints cross over in lumens, amps and heat. Where’s the happy medium?
I’ve also got an XP-G2 in my Convoy C8 pulling 4.55A on a Samsung 20R and making 883 lumens OTF. Tighter beam yet again over the XM-L footprint.
It’d be cool to find out where the heat was the same for the 3 sizes, at what amps and then what the output was by comparison. If heat were the determining factor, say 125ºF at 5 minutes on the plane of the emitter on the head. Wonder how that would end up? Might be a surprise to a lot of us!
EDIT: I might just try that. Convoy C8’s in a host only are about $10. So 3 of those would be about the cost of a semi-normal light. With an XP-G2, XM-L2 and MT-G2 I wonder what the magic amp number would be to create 125ºF at a given place on the head in 5 minutes? It’d be an easy thing then to compare beam profiles and lumen output, as well as kcd and throw range. Hmmmmmm……
moderator007
Direct drive seems to be a common way to drive the MT-G2, if you want some serious output. Has anyone else used a buck driver with 3 or 4 cells besides MRsDNF to regulate current? I’am not really crazy about the idea of running 3 or 4 cells in series, pushing 6 amps or more through each cell. One lazy cell could spell disaster with that much current. Looking for ideas before I go and spend several hours machining a solution. 2 cells and a voltage modified amc7135 driver with modes seems might be my best option, but I wouldn’t mind running the MT-G2 at 8 or 9 amps fully regulated either.
DB Custom
DB Custom's picture
007, it seems like 7A is the best middle ground. For the amperage required, the heat produced (and dealt with) and output…the heat produced and likewise expense gone to in order to deal with it is really more than the output is worth after 7.
And, well, it does seem like 7 is your “lucky number” Wink
moderator007
I completely understand what your saying DBCstm, I just cant help myself. I keep looking at that wonderful graph djozz provided and wondering how to achieve near the top of that mountain. :~
Does anyone know of another source for the IOS 9 amp driver?
Tom E
Tom E's picture
Last seen: 6 hours 39 min ago
Interesting, looks like that graph at 12A match's Dale's results exactly! 12A - 4,140 lumens... The graph looks like ~ 4,160 lumens - damn close.
DB Custom
DB Custom's picture
Half a blink and you’d miss that 4140! The cell was losing fast at 12, REAL fast!
MRsDNF
MRsDNF's picture
.Does anyone know of another source for the IOS 9 amp driver?
the IOS driver was not successful in this application in the respect that it would lock into high after a short period of time and would not change modes.
