Get the Convoy C8 AK47 from Banggood (8*7135)
231 posts / 0 new
CheapThrills
CheapThrills's picture
Last seen: 1 month 6 days ago
Rusty Joe wrote:
I had no idea the thread I started would take off like this!
…but thank you for starting it anyway! 8)
harry218
harry218's picture
Received mine today after 4 weeks. Quite impress with what we can get for $16. There is a small imperfection from machining on the head but the rest is just outstanding. The reflector and lens are very clean without any blemishes at all. I measured the tailcap using freshly charged to 4.15 (and also new) Sanyo UR18650FM and the result is 2.65A. Was that good?
Sirius9
Sirius9's picture
Last seen: 1 week 4 days ago
Yes, that is just fine. Smile
bushwhacked
bushwhacked's picture
Last seen: 6 years 3 months ago
After adding a few chips to mine, I was having trouble with the current measured, 2.8 up to 3.5a. It would not read past 3a. I took the pill out and unscrewed the driver to test. 3.48a. Screwed the driver in 3.48~a. Put the pill back in the head 3~a.
I had to clean my threads for it to work properly, the pill threads. I also removed some of the anodizing from the lip,where the head screws on on the inside of the tube. I have no problems with current now.
P60dropins.com (just a redirect for now)
B42
B42's picture
Last seen: 8 months 1 day ago
Great heads up, all I had in C8 category before this were $7-8 cheapy deal C8s, this is twice the price for a 4C tint and more than twice as nice Smile
harry218
harry218's picture
Thanks!
3.5A must be extra awesome for small amounts of money! How do you added the chips? Isn’t that will make the driver thicker?
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
harry218 wrote:
Thanks!
You can stack the 7135’s by soldering them on top of each other
http://budgetlightforum.com/node/20025
bushwhacked
harry218 wrote:
Thanks!
It is very inexpensive. It does make the driver thicker and creates some heat but in this particular light there’s lots of room. You must add the chips on the bottom of the driver though which can be tricky since there’s little room. I Desolder the chips that are there, stack them, then put the stacked chips back.
bibihang
bibihang's picture
Last seen: 10 hours 15 min ago
While stacking chips are good for better performance you should also change the LED star into direct copper MCPCB, something like the Sinkpad or Noctigon, otherwise the increased light output will sag very quickly and it may even damage your LED in a long run, depends on the current draw anyway.
Nbabu
Last seen: 2 weeks 5 days ago
How many chips did you add? What battery do you use?
“Trout are freshwater fish and have underwater weapons”
DB Custom
DB Custom's picture
Last seen: 6 days 12 hours ago
When you add chips to power up the driver, the choice of cell becomes increasingly important. Some cells simply will not deliver the current needed for the increased power of the driver.
Stacking 4 chips usually yields around 4.12A and many cells can do this, the Panasonic NCR18650PF is a great choice here for it’s excellent capacity and resulting runtime. It’s also capable of delivering more, when you get hungry to bump even more power. (which you will)
Stacking 4 more on top of those for a total of 16 chips usually results in around 5.34A (more if your cell can deliver), this does require a good cell like the one above or a Samsung 20R, there are several others that will run a driver with 16 chips but not at it’s maximum potential. When doing this, it’s essential, like above, to have a SinkPAD or Noctigon copper star under your emitter! (mtnelectronics.com here in the States has the Noctigons with emitters mounted, or you can get them at Intl-Outdoor.com)
This can get you to 1000-1100 lumens in the first example, and upwards of 1600 lumens in the second…this is Out The Front (OTF) lumens!!!
Have fun becoming a Flashaholic! Smile
Edit: I would be remiss to leave out that the tail switch is not made to run these currents. Adding 4 chips you can easily give the tailcap some breathing room by doing a spring bypass, which entails soldering a solder wick copper braid or a wire from top to bottom of the spring to carry the current. Springs are made from steel, in most cases, so the copper bypass will have less resistance and the current will follow the path of least resistance. Going to 8 added chips you might need to put a stronger switch in your light, like a McClicky, available at multiple places but Lighthound is a good choice.
Nbabu
Thanks for the info!
I got some Panasonic NCR18650B protected batteries. They should be able to provide enough power right?
Planned to put in a copper pill, dedome a XML2 on noctigon and put in some 22 awg led leads. So I think it should be able to handle some higher amperage….. J)
Edit: Ow yeah, almost forgot the copper braiding of the tailspring. Maybe also the driver spring?
DB Custom
DB Custom's picture
You can always add 2 chips and see how it performs. Go back in later and stack 2 more if you’d like to see more.
Stacking a second layer you can easily go one at a time until you reach your destination.
Me? I tend to throw everything at it all at once and go for the big bang theory! Smile
(The most chips I have on a standard Qlite driver is 22. There are multiple levels of new problems that accompany that many chips.)
DB Custom
DB Custom's picture
Braiding the driver spring can give you up to 600 mA more to the LED with lessened resistance. Every little bit…
BrightKen
Last seen: 7 months 2 weeks ago
Just patiently waiting for it to arrive.
scooby214
Last seen: 2 years 7 months ago
I know what you mean. I’ve only waited 11 days so far for mine to arrive. I figure I still have a couple weeks of waiting. I excitedly check the mail each day, just in case it comes in that “7-15 day” window shown on the Banggood site.
WarHawk-AVG
I modded mine, I ordered this one http://www.banggood.com/Convoy-C8-AK47-7135+8-8-Modes-White-Light-LED-Flahslight-p-908245.html (it was on sale and the BLF coupon code knocked it down to $$16.44 [not sure if on sale anymore]
Has 8 chips (2800mA), ended up flashing STAR V1.1 with pins 2, 3, 4 bridged to ground
It now comes on wide open for 2 minutes, then automatically steps down to a lower level, has 5 modes turbo w/ timeout, high, med, low, moonlight
I did it this way as my “bump in the night, blind badguy with a wall of light, but also keep the kids from burning the darn thing up by turning it on high and leaving it there” setup
Unlike my modded Convoy S5 that has last mode memory the C8 ALWAYS starts in turbo but after 2 minutes pulls back to keep from overheating (and no daggum flashies)
BrightKen
I am now a C-8 owner. Very impress with the quality and brightness. I got the L2 U2 1A.
Rusty Joe
Rusty Joe's picture
Last seen: 36 min 57 sec ago
It’s an amazing light on all levels.
saypat
saypat's picture
Last seen: 2 days 20 hours ago
c’mon, level with us….
CM2010
Last seen: 4 hours 40 min ago
Will Panasonic NCR18650B's be ok for this light?
jps
CM2010 wrote:
Will Panasonic NCR18650B’s be ok for this light?
Yes, why not? I use protected ones in mine, though unprotected can be used as this C8 flashes on a certain low voltage level.
sledger17
Last seen: 3 years 10 months ago
Hi Guys I want to get the G2: H 100%, M 30%, L 5%, with memory Convoy c8 the thing is i don’t know which one is it can someone please help me. TIA.
two¢¢
Last seen: 2 years 6 months ago
I think all stock Convoy C8 flashlights come with this ‘special’ two-group driver:
Group 1 (3 modes) Low 5% – Mid 50% – High 100%
Group 2 (5 modes) Low 5% – Mid 50% – High 100% – Strobe – SOS
To shift between groups, simply click to Low, wait about 5 seconds for the light to blink once, then click again.
So, with any stock Convoy C8 in your hand, you may click from Low to Mid to High, then back to Low (Group 1).
Then, you may shift to Group 2, and click from Low to Mid to High to Strobe to SOS, then back to Low, etc.
In other words, one of these flashlights gives you both groups.
I hope I understood your question?
WarHawk-AVG
Correct…and that driver is exactly like this one..they have several versions
http://www.fasttech.com/product/1186301-8-amc7135-2-group-25-modes-led-f... <-stars have no effect lo>hi
http://www.fasttech.com/products/1612/10001683/1122302 <- star selectable lo>hi
6*7135 http://www.fasttech.com/products/1612/10001683/1122301 <- star selectable lo>hi
6*7135 http://www.fasttech.com/products/1612/10001683/1232400 <- star selectable hi>lo
There is also custom firmware that can be written to the MCU on the driver to change what it does all together
JohnnyC’s STAR V1.1 and DrJones, and Werner, and a few others have written EXCELLENT open source code for us to use (some is also proprietary and you have to buy their drivers pre-loaded)
Omega_17
Last seen: 1 week 5 hours ago
Its a reliable driver but the problems are ; the annoying blinking for changing mode when in low, can’t change modes with soldering stars, the medium is so high that most of the times I can’t tell the difference between the highest mode when using it indoor and there is a little whining sound sometime.
sledger17
Thank you two¢¢ now I know
agarb
I bought one of these a few months ago and really like it. Was thinking about getting another for my Dad for father’s day. (He just loves the little Thrunite Saber 1A that I gave him last year. Carries it everyday.) I was thinking about a thrower for him this year. Does Banggood offer any good 18650 chargers to complement this light or should I look elsewhere?
WarHawk-AVG
Search around for a Nitecore i2 or i4…I really like the very small and portable Xtar MC1 (it costs $5.95)
Gj
Gj's picture
Shipping is crazy lately, USPS has been sending packages through 4-5 sorting centers. Sometimes through the same one twice.
:Sp
With a deadline of 5 weeks you might want consider a US dealer. Mountain Electronics, Illumination Supply, E2 Field Gear are all have great service.
Edit: I just re-read, it's a specific BG only item. I'd suggest ordering soon, then. Or maybe the Tangsfire C8 from tmart's US warehouse, it's very good too.
