Test/Review of Keeppower IMR18650 2250mAh (Black) 2014
Official specifications:
  • Brand Name: KeepPower
  • Type: Li-Ion
  • Cell: Made in Japan
  • KeepPower 18650 3.6V 2250mAh High Drain Li-ion Rechargeable Battery
  • Min Capacity: 2150mAh
  • Typical Capacity: 2250mAh
  • Normal Voltage: 3.6V
  • Quality Lithium Ion rechargeable cell made in Japan
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 10A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Dimension: (D)18.20mm*(H)66.90mm
  • Weight: 45.0g
This is a high current cell with added button top and no protection.
Using a Panasonic cell the discharge curves looks very good.
Conclusion
This is a very good high current battery, but it is possible to get 10A cells with more capacity.
Notes and links
The battery was supplied by Keeppower for review.
Thanks for the review.
My thoughts exactly.
Thanks for the excellent review.
