Quickfix: HD2010 (XM-L2 T6, 3-mode from Willbuying) vs. the Sky Ray STL-V2 (original T6)
6 posts / 0 new
Rusty Joe
Rusty Joe's picture
Last seen: 14 hours 35 min ago
HD2010 XM-L2 T6 with 26650 4000mAh Kong cell – distance: approx 25 meters. V2 beam is a bit more concentrated, but is less bright. Left: HD2010. Right: STL-V2 (original) with XM-L T6
Well, my trusty budget thrower now takes second-place to this bright little new champion. Even with an ever-so-slight reflector size advantage, the V2 can’t quite out-throw the XM-L2-upgraded HD2010. I’d say it’s somewhere at that 55,000 kcd range easily. Can’t tell from the pic, but the more neutral-ish tint of the HD2010 actually serves to make objects at a distance less washed-out-looking. I’ve come to appreciate that. And the extra lumens become more obvious at a distance as the first T6 starts to struggle with illuminating down range.
If you get this light, but sure and use a good 26650 or Samsung low-resistance because the improved brightness is worth it! I believe that 1,100 lumen rating may be close to accurate.
Came just shy of 3 weeks. It was so well packaged it took nearly 15 minutes to get it removed! Not a scratch on it, no flickering, and the button feels easier to push, but still firm and responsive.
This gets a Rusty Recommend Heavy!
Flomotion
Flomotion's picture
Last seen: 6 months 1 week ago
Please Link It, as there are so many versions, Thanks.
Flomotion
Rusty Joe
Rusty Joe's picture
Rusty Joe
Rusty Joe's picture
This one also seems lighter than the previous ones I had.
zeremefico
zeremefico's picture
Last seen: 2 hours 24 min ago
Which driver does this version have?
Current?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Rusty Joe
Rusty Joe's picture
I was never familiar with the original HD2010 driver so I’m not the best to comment on it. And my meter is dead so I can’t tell the current. Need another one.
