Test/Review of 1~2* AA/AAA 5-Mode 800mA Linear Booster LED Flashlight Driver Circuit
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 53 min 9 sec ago
DSC_4059 DSC_4060
DSC_4061 DSC_4062
Driver is from Fasttech.com
Official specifications:
  • 0.9V~3.6V / 500mA@1.5V / 800mA@3.6V / 17mm
  • Constant Current: Yes
  • Driver Type: Boost driver and Linear regulator
  • Input Voltage: 0.9~3.6 -volt
  • Output Current: 800 mA
  • PCB Height (w/o Components): 1.5 mm
  • Reverse Polarity Protection : No
  • Flashlight Modes: Hi > Mid > Lo > Strobe > SOS
  • Mode Count: 5
  • Mode Memory: No
  • Depth: 2 mm
  • Diameter: 17 mm
  • Product Weight: 1.1 g
  • Booster driver mode when input voltage is 1.5V or less
  • Linear regular (constant current) mode when voltage is between 1.8V and 3.6V
  • Rated at 500mA current output @ 1.5V input
  • Rated at 800mA current output @ 3.6V input
Measurements
Tested with: Cree XP-G2
Driver diameter 16.8mm
Driver height 5mm
The driver uses boost mode and will be forced into direct drive when voltage is to high.
The driver has high, medium, low, strobe and sos.
Driver height 5mm
No memory, always starts in high.
A short off/on will select next mode.
Medium pwm 550Hz with 40% duty cycle
Low pwm 560Hz with 15% duty cycle
Strobe 7.6Hz with 50% duty cycle
High
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL
Below 1.5 volt the driver will try to draw a constant current from the battery.
When 1.5 volt is reached the brightness is stabilized, until the voltage reaches Vf of the led.
Above Vf of the led the driver will be in direct drive mode.
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HLDriver
At low voltage the efficiency is low (as always) and a lot of power is lost in the driver.
When the driver stabilizes its output, the power loss goes down, as the current goes down.
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HLLed
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20LH
Starting from 0 volt, the driver turns on at 0.75 volt.
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20LHDriver
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20LHLed
High%202.4V
High%201.2V
In high mode there is no pwm in the light and only a small amount of high frequency noise.
Medium
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL%20medium
Because the driver uses pwm, the shape of this curve looks very much like high mode (With pwm the led is driven at full power, but not all the time).
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL%20mediumDriver
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL%20mediumLed
Medium%202.4V
Medium%201.2V
Pwm is at 550Hz.
Low
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL%20low
Low mode is also the same, but at even lower currents.
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL%20lowDriver
1-2%20AA-AAA%205-Mode%20800mA%20Linear%20Booster%20%28YJP%29%20HL%20lowLed
Low%202.4V
Low%201.2V
Pwm is at around 560Hz.
Strobe
Strobe%202.4V
Strobe%201.2V
Strobe is at 7.6 Hz. Brightness is at full.
SOS
SOS%202.4V
SOS%201.2V
Conclusion
The driver looks like a good driver for one or two NiMH batteries or a CR123 battery, but cannot safely be used with LiIon.
With one NiMH battery the voltage will be too low to stabilize brightness.
With a maximum current draw of about 2A it is not really a good driver for alkaline batteries.
Notes
How do I test a led driver
List of all tested drivers
WarHawk-AVG
WarHawk-AVG's picture
Would these be ok with the new 3v LiFePO4
HKJ
HKJ's picture
LeFePO4 is not 3 volt, but about 3.2 volt during the full discharge (Using small cells at high currents will give lower voltage).
That will work, but you are at the start of the direct drive phase.
unknown00101
Last seen: 2 months 5 days ago
Very similar to this I believe?
HKJ
HKJ's picture
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Thank you for the review!
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
unknown00101
HKJ wrote:
Yes, but not the same: http://lygte-info.dk/review/DriverTest%20Nanjg110%20UK.html
Ah nice! Didn’t see that review.
What is meant by “direct drive phase”? Is that the spike in current after 3.25V input (unregulated range?)?
Thanks.
HKJ
HKJ's picture
unknown00101 wrote:
HKJ wrote:
unknown00101 wrote:
Very similar to "this":http://intl-outdoor.com/nanjg-110-boost-12aa-circuit-board-p-482.html I believe?
What is meant by "direct drive phase"? Is that the spike in current after 3.25V input (unregulated range?)?
Yes, the current basically runs straight through the driver and through the led with only some (small) circuit resistance to limit it.
lagman
lagman's picture
Last seen: 2 weeks 5 days ago
Thanks for your reviews HKJ. Very useful and scientific approach. A graph is much better than many lines of explanations. Smile
I really like your website too but it’s too bad that we can’t post comments.
Keep them coming please! Smile
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
HKJ
HKJ's picture
lagman wrote:
I really like your website too but it's too bad that we can't post comments.
Most of my test and articles you can find here on BLF, where it is possible to post comments. Opening up for comments would require that I used a lot of time on filtering spam and general maintains.
You can also use email or PM (from BLF) for specific questions, usual I do answer (But please, do not ask what is the best xxx, usual there is no best, because it depends on what you require).
Iraksat
Last seen: 11 months 1 week ago
Nice review thanks.
Looks like the current set resistor in the test driver is 0.15ohm ,which by the datasheet (pam2803) sets the maximum current to 633mA.The drivers I got from Fasttech few weeks ago have 0.12ohm resistors,this sets the current to 792mA,close to the promised 800mA.
I used this to replace a single mode driver in a 2 AA flashlight.First mode memory is superb.
