Who: Any BLF member with 25+ posts. If you join BLF because of this giveaway, you need to promise to come back even after the giveaway has ended! The winner will be selected via random.org and is encouraged to make a review of the light.
Yesterday evening. Typical night walk on standard route. Instead of comparing my two latest C8 mods (4,5A Qlite and direct drive East 092) with 20R cells, I put in a Keeppower Protected 18650 in both of them to keep them more similar (and both below 4,5A).
I also used my new custom MRsDNF light attached to my keychain a little bit..
The last time I used a flashlight was to light up a totally dark room in Uganda (which was last week). Used a Shiningbeam Caveman and then a Convoy S2.
This morning; getting up and walking down some stairs. It’s still pretty dark here in the mornings around 6AM. Instead of using the house lights, I have been using flashlights to get around in the dark. My light of choice is the Jetbeam RRT-01 variable brightness.
It’s perfect since it starts off in low and I can turn up the brightness to a comfortable level. With only a control ring to twist, it makes for easy operation with one hand. I thought the control ring was a bit loose when I first got the light, but now I think it’s just perfect because of how easy it is to operate.
Thanks ryansoh3 and Banggood for sponsoring such awesome contests/giveaways as of late.
I’m in!
I used my Convoy S4 last night to check on the contents of our moving truck. I’m helping a friend move from Santa Fe, NM to St. Paul, MN and we are currently in staying in Denver, CO.
I was using my Convoy S8 to repair a tub for squeaking. I cut out the drywall and used the S8 to see where the problem was and added shims on the top of the tub supported by the horizontal 2x4.
Last night - as every night - going for sleep i used my Olight S10 walking in the house and did not want to turn on the lights… And also i tsecked for any pigeon in the balcony with my Xeno F7….
woo hoo another cool giveaway at BLF…count me in!!
last time I used the flashlight? every night shining the perimeter of the house with Mod’ed TR-J18 before I go to bed :bigsmile:
