I just got one today from TMart, advertised as focusable and 200mW, reviews say it is probably closer to 70mW.
My understanding is that you can see a green beam even in direct sunlight. Is that your experience? I can't see mine in direct sunlight, so I was curious.
Is impossible to see the beam in direct sunlight, even with a real 200mW laser. You can see the beam in the evening or at the sunset but surely not in direct sunlight
Here is a couple things to try. You should be able to burn black electrical tape, take a wooden match and black marker and mark the match head than you should be able to light it also a you should be able to melt right through a black trash bag. Check the amp draw if you have a DMM. Definitely cannot be seen in direct sunlight.
The 150 mw Laser is the only one that i made by myself using some elettronic component and an old dvd writer.. Is quite impressive. It can also burn black plastic if well focused but i always wear safety goggles when i use it.
