Test/Review of Keeppower IMR18650 2900mAh (Black) 2014
10 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 32 min ago
DSC_4419
Official specifications:
  • KeepPower 18650 3.6V/3.7V 2900mAh High Drain Li-ion Rechargeable Battery
  • Min Capacity: 2750mAh
  • Typical Capacity: 2900mAh
  • Normal Voltage: 3.6V
  • Quality Lithium Ion rechargeable cell made in Japan
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 10A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Dimension: (D)18.50mm*(H)66.50mm
  • Weight: 46.0g
Keeppower%20IMR18650%202900mAh%20(Black)%202014-info
This is a high capacity high current battery
DSC_4418
DSC_4420 DSC_4421
DSC_4422
DSC_4423
Keeppower%20IMR18650%202900mAh%20(Black)%202014-Capacity
The two cells has very good tracking and only a minor capacity loss when the current is increased.
Keeppower%20IMR18650%202900mAh%20(Black)%202014-CapacityTimeHours
Keeppower%20IMR18650%202900mAh%20(Black)%202014-Energy
Keeppower%20IMR18650%202900mAh%20(Black)%202014-PowerLoadTime
Keeppower%20IMR18650%202900mAh%20(Black)%202014-TripCurrent
Keeppower%20IMR18650%202900mAh%20(Black)%202014-Charge
Conclusion
There are cells with higher voltage at high current, but none other with this much capacity.
With a Panasonic cell inside it is a very good battery, that can deliver a lot of current.
Notes and links
The battery was supplied by Keeppower for review.
Edited by: HKJ on 01/26/2014 - 04:46
CRX
CRX's picture
Last seen: 1 week 21 hours ago
Another great review, thanks HKJ.
Does this cell have the Panasonic NCR 18650PF inside?
HKJ
HKJ's picture
Yes.
luminarium iaculator
luminarium iaculator's picture
Last seen: 14 hours 42 min ago
Thanks HKJ,
Panasonic NCR18650PF 4,2V is the best cell for single 18650 nanjg amc7134 drivers. And this one is protected. So it is probably unbeatable battery in performance and safety. Sanyo UR2600FM (FT) is small crying baby comparing to this beast delivering much less current than NCR2900PF (IMHO).
HKJ
HKJ's picture
Where did you get that idea from?
So it is not protected? My apologize... I tough it was protected cell...
HKJ
HKJ's picture
When I put "NA" in "PCB protection trip current" it is an unprotected cell.
With most batteries you can also see it on the batteries, the protection circuit is "visible" as at the bottom of the cell.
Thanks for the info,
I did not pay attention on that since it is re wrapped.
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Thanks for the review. Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
dazed1
dazed1's picture
is there protected version of this ones?
And where to find them?
Fenix TK61 MOD> resistor, transistors, copper heatsink, Artic Cooling MX4, dedome, 3A > 5.7A ~ 1700 lumens > (600.000cd)
