[Review] DQG TinyAAA Ti II (XP-G2 R5 NW, 1x AAA / 1x 10440)
15 posts / 0 new
UPz
UPz's picture
DQG TinyAAA Ti II
LED : CREE XP-G2 R5
Battery : 1 x AAA / 1 × 10440
Modes 2 ( Low, High ) without Memory
Switch: Twisty
Date: January 2014
Links :
CNQG / RdL / Thread in ForoLinternas
INTRODUCTION:
The TinyAAA range is undoubtedly the most famous and well-known family of DQG , being the forerunner of the series and rated as one of the best keychain flashlights by worldwide users. Some time ago we saw version III analysis , and then the first Ti and recently the version IV. The new Ti II follows the marked trail of the above, with some changes to the external design , and showing a more sophisticated machining now , still keeps a similar look to the previous versions.
The presentation is exactly the same as we saw in Version IV, coming the flashlight in a small metal box including, in addition to Ti II aforementioned, a pair of replacement o-rings, a small claw for key chain, two split-rings, and it now includes the pocket clip that appeared as an extra (can be still purchased separately) with the launch of the DQG TinyAAA IV.
EXTERIOR FINISH:
Although it is undeniable aesthetic continuity in the main features of the AAA family, this Ti II has a much more elaborate external machining, giving it a more sophisticated and less simple than his previous appearance, but definitely keeping the identity of the signature.
The surface is not polished, nor has a sandblasted finish, showing some machining grooves. The size and weight are almost identical to the first DQG Ti, to date the AAA flashlight smaller and lighter than I know.
Changes in external machining , though subtle , give it a more elegant and distinctive touch , starting with the head where the knurling finish area has shifted down a few millimeters , making room now a similar bezel style as we have seen recently in the Tiny18650 and Tiny26650 .
Under the head knurling area has been machined a discrete dissipating fin, and the rest of the head have now a much more visible engraving as first introduced in the steel version IV. The total length of the head is kept in DQG IV, with few millimeters longer than previous versions certainly looking better dissipation.
Lens and LED remain unchanged, with a small TIR that hides under a GITD o-ring that glows in the dark when we turn off the flashlight.
The driver is protected by a coating of foam that prevents battery rantle when the flashlight is off and acts both as a protector against reverse polarity.
The threads, as is usual in this type of metal, have a rough and gritty feel, but runs considerably smooth even when dry.
The tube also has some cosmetic changes, such as shortened from the central part of knurling to accommodate a tiny engraved with the URL of personal web of DQG. The tailcap design is similar to the previous versions, with a hole for the split-ring surrounded by two recesses which allow you to place the flashlight in tailstand even with the claw installed. At the center there is a GITD dot, which optionally can be replaced by a magnet when purchasing this flashlight.
DQG IIIDQG Ti • DQG IV • DQG Ti II
USER INTERFACE:
The main features of the interface are maintained, with two modes in ascending order without memory. The selection of modes is by achieved by twisty, and thanks to the rough knurled head area this is done conveniently with one hand.
  • On/Off and mode selection: Simply tighten the head to close the circuit and turn on the flashlight in low mode. If we turn off and on quickly the flashlight starts now in High mode.
Which is undoubtedly the greatest innovation introduced in this DQG Ti II in compatibility now with 10440 rechargeable lithium batteries (Li -Ion). Keep in mind that a battery with a similar AAA positive top is necessary because if you try to use a battery with flat top or positive oversized in diameter reverse polarity protector (foam lining visible components face of the driver) will prevent proper operation. The length of the battery is not a problem as the contact point system does not require physical contact between the circuit and the profile of the threads, so that we can even make it work with 10440 protected batteries, usually way longer than unprotected.
In my case, I used a flat -top 10440 batteries to which I added a tiny blob of solder on the positive for correct operation, although protected Trustfire battery that came with the Mini – 03 also runs tight but OK.
(All measurements are taken following the procedure ANSI NEMA FL1 using a value of the highest reading of between 30 and 120 seconds after switch point. More details here. )
The usual test measurement modes with Eneloop shows a more than acceptable concordance to the specifications provided by the vendor, considering that the unit I’m measuring has a XP -G2 R5 NW, with typically has 10% less performance than the same bin in CW . For measurements with Li -ion, you can notice a real difference only with the maximum performance specified.
PERFORMANCE:
Let us first compare the runtime vs output of this new Ti II compared with data obtained in the test of DQG IV:
Both torches equipped supposedly with the same LED and same bin and therefore should provide similar performance, but in practice we can observe as the new Ti II still having an equal maximum, it is stabilized 5LM below the TinyAAA IV. We could easily appeal to the infamous Chinese Lottery, but shows more than five minutes stabilized linear output that the new Ti II, makes me think that changes in the driver are responsible for this phenomenon.
With a 10440 , flashlight offers similar performance, keeping the two modes but now the High mode offers 10 seconds of 140LM ( 270% higher performance than Ni-MH) with a time-controlled stepdown , lowering the regulated output 80LM .
You can clearly see how the 140LM seem to be perfectly regulated within the 10 seconds , with no hint of the classic directdrive-like curve to the with sharp drop in the first few seconds , so thereby you see that pretty current regulation is maintained in both phases .
BEAM PROFILE:
Being the same lens, the beam profile remains identical to the previous TinyAAA family:
A massive flooding with a huge central spot and plenty of spills, ideal for indoor illumination or outdoors two-steps-ahead full flood light.
The tint of this XP -G2 R5 is 3B (1A for CW version), and has a very nice tone with characteristic natural color reminiscent to Mediterranean sunset light. We see that tone is identical to that found in the Steel TinyAAA IV, yet quite different from the equipped the DQG III NW.
PERSONAL CONCLUSION:
I have always been fascinated by the lightness and simplicity of DQG TinyAAA. A clearly personal character design which George, the brain behind these little gems, gives us the opportunity to enjoy. A personal project away from the dictatorship of the market, version after version improves and grows to share with the lucky owners his interpretation of the ideal flashlight from a personal point of view of its creator, regardless of the trends that large brands are subject to meet for its economic goals. Once again I cannot do anything but surrender to the obvious and, not without some sadness, uninstall my dear DQG IV from my keychain to make room for this new gem to accompany me from now on at all hours of the day.
Negatives: The only thing that could be discussed is the price of the light, somewhat high when compared to other similar flashlights from the mass market. Obviously, it will always be cheaper having lunch (using week offers or discount coupons) in McDonalds than in the good old restaurant in the neighborhood Silly
Positives: Starting with the new exterior look , the new Ti II features some cosmetic changes that make it more attractive and sophisticated , but continues to maintain the simple and straightforward appearance that over recent years has characterized this family of tiny flashlights . The performance is set to fit almost perfectly coherent usage of a kind of these features a flashlight with a nice linear regulation. The absence of memory can be seen as a negative point by some people, but from a practical point of view I always thought that in this segment is a positive, as long as the two modes are in ascending order, always allowing us to assess whether it is really necessary to use the high mode for the task you’re performing, avoiding losing our visual adaptation to the dark while still helping us to save battery. The introduction of compatibility with 10440 rechargeable lithium batteries has been made in the best possible way, regulated in all modes , including the 10 second mini-turbo embebed in high mode.
The other positive aspects such as the ability to choose the tint, magnet or luminescent spot, are inherited from previous versions so I will not dwell further praising this new DQG, for me the PERFECT flashlight keychain.
djozz
djozz's picture
Last seen: 13 hours 12 min ago
Having ruined my version II of this light, DQG together with your review makes me tempted to replace it with this beautiful new version.
Thanks for the very good review!
mrbios
Last seen: 5 years 1 month ago
+1
Indeed.
UPz
UPz's picture
Thank you very much for reading guys! Beer
jacktheclipper
jacktheclipper's picture
Last seen: 2 days 22 hours ago
Thanks for sharing Upz .
Is the clip reversible ?
What I do
xxx
xxx's picture
Last seen: 2 years 7 months ago
nice review and pic…..
fartybum
Last seen: 7 years 3 weeks ago
I would never buy another torch labelled DQG Tiny, my SS AA version is very unreliable, almost as though it has constantly dirty contacts no matter how often it is cleaned.
UPz
UPz's picture
Yes, it is. Forgot to take pics with the clip on, maybe I’ll update pics someday soon.
In the meanwhile, two pics found in CNQG site showing the clip installed in both ways:
Thanks for your words!
UPz
UPz's picture
Have you tried cleaning all the battery tube, threads and visible contacts with alcohol?
I had a Fenix that performed as you described and it was solved by a batch on alcohol.
fartybum
UPz wrote:
Have tou tried cleaning all the battery tube, threads and visible contacts with alcohol?
I’ll give it a try thanks.
jpil
Last seen: 7 months 2 weeks ago
Nice review, thanks for sharing.
UPz
UPz's picture
Thank you for reading! Big Smile
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 22 hours ago
DQG really knows how to make a nice keychain light. Smile
The biggest problem I’ve found is that they make these so well, it’s not necessary to ever buy a new one.
(well, that, and the threads on my Tiny AAA IV get quite a bit more stiff a few degrees before it’s tight enough to activate; I like the twisting feel of the L3 L10 better)
Any chance of a runtime test on low, for either this or the IV model? I feel like an Eneloop does more than the spec’d 10 hours, but it’s hard to be sure.
jmpaul320
jmpaul320's picture
Last seen: 1 day 18 hours ago
I gave this light to my wife for her backup keychain light (I won this light in the CNQ xmas give away)… she almost never uses it … as she prefers her thrunite Ti AA light (because its pink)
after using it last night I requisitioned it as my own… its too awesome to sit on a key ring and not get used.
I offered to let her keep it and buy another (too be fair I did give it to her)… but she said it was just weighing her keys down and she didnt like it since it wasnt pink.
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
pdw
Last seen: 5 years 5 months ago
I’ve been edc-ing one of these for about 1.5 years, and have been quite happy with it. Last week, it started operating in low intensity mode only, so I dis-assembled it, cleaned it with alcohol, and re-assembled using deoxit on the threads and other contact points, but the problem remains. Strangely, while fiddling around with it, the high intensity mode has come on two times.
With low-power only, the light isn’t of much use to me… Can this light be modded, or otherwise repaired?
Thanks for any ideas,
Phil
