I purchased three DIY Micro USB TP4056 4.2V CC/CV Li-Ion Chargers from Mountain Electronics. They charge at 1.0A, but I would like one of them modified to charge at 0.5A so I can use it with my 16340 batteries.
I understand that the chargers can be modified to do so by changing the (REALLY TINY) resistor on the board. (There is a chart on the charger’s sale page linked above that identified the necessary resistor.)
I do not have the soldering skill necessary to change the resistor. Is there someone on this forum available for hire to make this change for me?
A Micro Lipo or LipoNano can be set to 500mA, solder bridge two pads.
Tho it looks like the chip averages more like 400mA unless you can heatsink it well. Lipo nano / MCP73831 test. Maybe encase the chip in thermal adhesive & place an aluminum heatsink on top.
I will do it for you, just need to change the 122 resistor (or Rprog [the resistor on pin 2 of the IC]) to a value of approx 2.5K ohm (I believe 252 or 2K5)
