Test/Review of Sibeile IMR14500 700mAh (Black) 2014
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 3 days ago
Button top version
DSC_4528
Official specifications:
  • Nominal Voltage: 3.7v
  • Max.Charge Voltage: 4.2±1v
  • Discharge Cut-off Voltage: 3.0v
  • Capacity: 700mah
  • Stand Charge Current: 1.2A
  • Max.Charge Current: 2.2A
  • Standard Discharge Current: 1.2A
  • Max Continue Discharge Current: 2.4A
  • Size: Height:50±2.0mm Diameter: 14±2.0mm
  • Cycle life: > 300 cycles
  • Material: li-ion
  • Operating Temperatue: 0~45°c
  • Storage Temperature: -20°c~60°c
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-info
The is the button top version of the cell.
DSC_4521
DSC_4529 DSC_4530
DSC_4531
DSC_4532
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-Capacity
Good tracking between the cells and also constant capacity at any load, this looks good.
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-CapacityTimeHours
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-Energy
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-PowerLoadTime
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-TripCurrent
Sibeile%20IMR14500%20700mAh%20bt%20(Black)%202014-Charge
Flat top version
DSC_4523
  • Capacity: 700mah
  • Material: li-ion
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-info
The is the flat top version of the cell.
DSC_4521
This version also has good tracking between the cells and also constant capacity at any load, this looks good.
I expect they are using the same cell, i.e. they must have the same performance.
DSC_4524 DSC_4525
DSC_4526
DSC_4527
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-Capacity
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-CapacityTimeHours
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-Energy
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-PowerLoadTime
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-TripCurrent
Sibeile%20IMR14500%20700mAh%20ft%20(Black)%202014-Charge
Conclusion
The batteries has a good capacity for IMR batteries, even though it is lower than rated. The performance is also good, even at much higher current than they are rated for.
There is a very small difference between flat top and button top, the button top increases the resistance slightly.
I will rate this battery acceptable.
Notes and links
The battery was supplied by Sibeile for review.
Comparison to other LiIon batteries
StyXSIS
StyXSIS's picture
Last seen: 6 years 4 months ago
Thanks for the test info, it’s very Appreciated.
Simon
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 6 months ago
Excellent as always sir!
Group buy! Big Smile http://www.alibaba.com/product-gs/1117290480/Sibeile_IMR_14500_700mAh_3_...
Manufacturer/seller site, you can buy singles there (or so it says)
http://www.sblbattery.com/product/1488319684-218373299/14500_sibeile_3_7...
MountainKing
I do not understand the protection test Sad What does this mean? It has protection and it works?
Thanks for clarifying!
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Hikelite
It has no protection.
HKJ
HKJ's picture
MountainKing wrote:
I do not understand the protection test Sad What does this mean? It has protection and it works? Thanks for clarifying!
In the protection I increase the current until the protection trips or I hit my limit (7A in this case). The curve will stop when the protection trips. Here it does not stop but continues all the way to the limit, i.e. not protection or it has a very high limit. Being an IMR cells it is no surprise that it is missing a protection.
