Test/Review of Keeppower 26650 4000mAh (Black) 2014
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 20 hours ago
DSC_4437
Official specifications:
  • Product Name: Keeppower Protected 26650 3.7V 4000mAh
  • Supplier: Keeppower Technology Co., Limited
  • Cell: China 26650 4000mAh
  • Capacity: Min. 3920mAh; Normal: 4000mAhDischarge:0.2CmA
  • Normal Voltage: 3.70V
  • Stanard Charge voltage: 4.20V
  • Standard Charge current: 2000mA
  • Charge Time(Std.): 3 hours
  • Standard Discharge Cut-off Voltage: 2.750V
  • Standard Discharge current: 800mA
  • Standard Discharge cut off current: 30mA
  • PCB Protection trip current: Above 10A
  • Storage Temperature:-20°C~+60°C Less than 1 month, -20°C~+45°C Less than 3 months
  • WeightMax 95g
  • Size(L)71.10mm*(D)26.50mm
Keeppower%2026650%204000mAh%20(Black)%202014-info
The battery has good performance, but the over current protection does not work as expected.
DSC_4436
DSC_4438 DSC_4439
DSC_4440
DSC_4441
Keeppower%2026650%204000mAh%20(Black)%202014-Capacity
The battery does easily live up to its rated 4000mAh and the two batteries has good tracking up to 7A.
Keeppower%2026650%204000mAh%20(Black)%202014-CapacityTimeHours
Keeppower%2026650%204000mAh%20(Black)%202014-Energy
Keeppower%2026650%204000mAh%20(Black)%202014-PowerLoadTime
Keeppower%2026650%204000mAh%20(Black)%202014-TripCurrent
The protection does not trip, I asked Keeppower about it and they told me the protection was at around 20A. This is way to high for this battery.
The over discharge and over charge protection is still supposed to work correctly.
Keeppower%2026650%204000mAh%20(Black)%202014-Charge
Conclusion
This battery has good performance up to 7A, but the missing over current protection does reduce the safety some.
Notes and links
The battery was supplied by Keeppower for review.
djozz
djozz's picture
Last seen: 1 hour 46 min ago
Thanks for the review!
Tom E
Tom E's picture
Last seen: 12 hours 53 min ago
Thanks HKJ! This confirms what I've seen - the "2014" is a disappointment compared to their previous version - higher resistance, poorer performance across the board, even a worse higher trip point.
Did you notice they seem to be using cheaper, thinner metal for the cap on the + end?
Overall, it's a drop in quality for this cell, and for me, makes me wonder what they are doing across their product line.
HKJ
HKJ's picture
Performance is about the same, as can be seen in my comparator.
The old version had slightly lower over current trip point, but it was also too high. Comparing the "Protection test", the new version handles high current better.
Review 2012 version
No, I did not notice that, but then I did not compare them. Looking at them both now, it looks like you are correct, it is thinner on the new version. This is probably part of making the battery shorter.
Tom E
Tom E's picture
Ohh - I see the internal resistance was 0.08 on the old, 0.10 on the new and I looked at a couple of specific points on the 5A curves and saw a difference - this was before you added the new one to the comparator. I see now though, one of the old cells performed better than the other, and the other poorer performing cell match's the new ones -- hhhmmm.
