Test/Review of Efest IMR26650 3000mAh (Red) 2014
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 weeks 2 days ago
DSC_4625
Official specifications:
  • Weight: 95g
  • Length: 66.67 mm
  • Diamter: 26.21mm
  • Top: flat top
  • Bottom:non-procted
  • Typical Capacity: 3000mAh
  • Min capacity: 3000mAh
  • Maximum discharging current: 15A
  • Maximum charging current: 6.5 A
  • Maximum pulse discharging current: 60A
  • Resistance: 13±2 mOhm
  • Battery WH: 125WH\Kg
  • Discharge cut-off voltage: 2.5V
  • Voltage: 3.8V
  • Full Charge voltage: 4.2V
  • Monthly Self-discharge rate: Temperature range: Discharge: -20~+60 ºC, Charge: 0~45 ºC
Efest%20IMR26650%203000mAh%20(Red)%202014-info
This battery is rated as a high current type.
DSC_4624
DSC_4626 DSC_4627
DSC_4628
DSC_4629
Efest%20IMR26650%203000mAh%20(Red)%202014-Capacity
The batteries can handle up to 20A, but does heat up at 15A and 20A. It is nice with nearly constant capacity at any load.
The 15A rating is fine for it.
Efest%20IMR26650%203000mAh%20(Red)%202014-CapacityTimeHours
Efest%20IMR26650%203000mAh%20(Red)%202014-Energy
Efest%20IMR26650%203000mAh%20(Red)%202014-PowerLoadTime
Efest%20IMR26650%203000mAh%20(Red)%202014-TripCurrent
Efest%20IMR26650%203000mAh%20(Red)%202014-Charge
Conclusion
These batteries has good performance up to 10A, but it is possible to find 26650 with lower capacity, but considerable better high current capability.
It will rate it as an acceptable battery.
Notes and links
The battery was supplied by Efest for review.
RaceR86
RaceR86's picture
Last seen: 5 years 9 months ago
Looks like a very good battery at 5A, like the KeepPower 26650.
At 5A performance is very close/similar to the Sony high drain battery, but this has got better capacity..
Then we are back to the usual question. Anyone know where to buy this exact battery at a good/ low price? (preferably free international shippping)
On a sidenote, HKJ, will you be looking into the Efest purple batteries?
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
djozz
djozz's picture
Last seen: 3 hours 46 min ago
Thanks for the review, nice capacity this battery has. I bought one these three months ago, will that be this tested battery or is there a new version?
HKJ
HKJ's picture
I do not have any in queue at the current time.
If Efest ships some to me, I will not have time to post any reviews before April.
I cannot answer that, I do not know how fast Efest updates their batteries.
djozz
djozz's picture
ok, thanks. I'm happy with it anyway Smile
sesgum
sesgum's picture
Last seen: 2 days 9 hours ago
Thanks for the detailed review and your hard work HKJ!
