broken NITECORE I4 Charger
31 posts / 0 new
zelee
zelee's picture
Last seen: 6 days 25 min ago
Hi Guys
my I4 charger V2 isn’t responding with 220V AC power but it accept 12V DC,anyone know what is wrong with my charger?
the power cord is functional because i’ve test it with my I4 charger V1
Chloe
Chloe's picture
Last seen: 5 years 2 months ago
It is difficult to know, but at least the 12V DC is still working. Do you have a multimeter?
If it’s within warranty it might be worth contacting Nitecore.
HKJ
HKJ's picture
Last seen: 12 hours 28 min ago
It might be as simple as a fuse or it might be some part that is blown.
A internal fuse will usual not look like a normal fuse, but can often be recognized because there is a F (Maybe F1) on the circuit board near it.
Chloe
Chloe's picture
zelee
zelee's picture
@Chloe
its been more than a year i’m afraid :~
@HKJ
thanks for the advice i will try to open it to see if it can be easily fixed Smile
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
Fuse is behind the yellow square, to the left of the blue square..
If you look real close at top left you can see "fus" for fuse?
Apparently these things were put together by people who have no clue how to solder...so check yours out well!
StyXSIS
StyXSIS's picture
Last seen: 6 years 2 months ago
Check the solder points on the board for the figure 8 input, mine came lose over time when pluged in and out, it lifted the points from the board and bent the pins just enough away from the solder over time that it had no power one day when i plugged in, i just solderd them again and superglued the block down as the snapin hold down pins were lose causing it to lift when i pluged it in, my nephew has it now and hasn’t had any problems since i did the fix.
Simon
zelee
zelee's picture
If you look real close at top left you can see “fus” for fuse?
Apparently these things were put together by people who have no clue how to solder…so check yours out well!
i’ve tear it up and found out that the fuse is been fried Sad
any place i can find a replacement for the fuse or any substitute for it?
moderator007
moderator007's picture
Last seen: 1 week 4 days ago
Looks like what is called a pigtail fuse best I can tell, cant see much in the pic.
https://www.google.com/#q=fuse+pigtail
It should have a voltage and current rating on the fuse some where. Find a match and solder it in.
I don’t know if its a fast blow fuse or not, but I would probably replace it with one even if it was not, if you could unsolder it and post up a few of pics of what you find, might help further locate the correct fuse.
I guess other fuses could be used in a pinch, you would just have to solder your own pigtails on to the fuse.
vēer
vēer's picture
i4 V2 is brittle crap charger that overcharges AAA cells, there, I said it once again :D!
Both of my units never saw extensive or considerable use at all, they have been kept in good shape, however on one of them that Im using as spare-backup charger out in the country side the power cord has started to disintegrate near the tip of it where the in-charger tip is.
Piece
Of
Crap!
unit311
Last seen: 1 year 12 months ago
I had no idea that they soldered boards like this until I saw this on tv: http://youtu.be/3WRBMRyO4×0?t=39s . I thought they did it by hand.
WarHawk-AVG
Interesting
HKJ
HKJ's picture
unit311 wrote:
I had no idea that they soldered boards like this until I saw this on tv: http://youtu.be/3WRBMRyO4X0?t=39s . I thought they did it by hand.
This process has been used for many years, it is called "Wave soldering".
Werner
Werner's picture
Last seen: 2 years 3 weeks ago
Try to pull the “hats” from the fuse, I guess it is a standard fuse with just two contact joints pressed on…
snakebite
snakebite's picture
Last seen: 1 week 15 hours ago
in that pic looks like d3 is burned.
what is the chip next to it?
looks like a topswitch.smps and mosfet in one.
leaftye
Last seen: 10 months 1 week ago
If you can't fix it, sell it to me.  I want one to make into a battery charging cradle for a hobby charger.
The low mode should be lower.
Maxxsounds
Last seen: 2 hours 53 sec ago
My I-4 v2 quit this week also. No power when 110v ac applied. I loaded it up with 4 Panny 18650’s every night for 6 months. One night it just stopped. Going back under warranty which is 18 months.
leaftye
Maxxsounds wrote:
My I-4 v2 quit this week also. No power when 110v ac applied. I loaded it up with 4 Panny 18650's every night for 6 months. One night it just stopped. Going back under warranty which is 18 months.
They wanted me to ship it back to them.  No offer for them to cover shipping.  Here's the shipping address they gave me.
Rm1407-08,Glorious Tower,850 East Dongfeng Road,Guangzhou,China 510600
Attn.: Lei Jun lai,
Phone: 86 20 83862000
If you change your mind, I'd love to take that dead charger off your hands.  All I really care about is the sliders.
Maxxsounds
Nightcore is in China? Sheez. This is revolting. Maybe I will tear it open. If I change my mind either way Leaftye, you can have it.
arn357
arn357's picture
Last seen: 7 months 4 days ago
Did you purchase your i4 from a authorized dealer in the US? You should be able to return your i4 to them.
LINK
leaftye
It makes it a huge hassle.  I don't fault them for being a chinese company or having their chargers made there, but at least have a return address in this country.  There are services that could handle it for them.  That's what Fasttech does.
Try contacting Nitecore yourself, but I fear you'll get the same disappointing answer I got.  If so, definitely tear it open.  You have nothing to lose.  Hopefully you can fix it, but if not, I'll be thankful for your charging cradle host.
Maxxsounds
Yeah, That’s the link I contacted them through three days ago. No reply yet. Purchased through Amazon in August 2013.
leaftye
My first two responses from Nitecore took one day, and the third took three days.
When you purchased it through Amazon, was Amazon.com the seller or was Amazon only providing fulfillment?  Right now there are both types, and the primary vendor right now is Edison with Amazon providing fulfillment, but if you look at the right side you see that Amazon.com is also a vendor for a slightly higher price.
Maxxsounds
Yep, of course, I went for the lower price. Edison. sometimes saving a little $ is not the _best_way to go.
arn357
arn357's picture
Edison Bright is a authorized Nitecore dealer in the US with full US warranty according to Amazon’s page
LINK
leaftye
You'd be doing them a favor if you try handling the warranty claim outside of Amazon.  One of the guys from IS said an exchange for a vendor through Amazon costs them shipping back to Amazon, then back to the vendor, and they still have to pay for sending another unit to you.  If you handle it directly, I suspect they'll send another one out to you without requiring you to return it.  Or they might have Amazon ship you another one, again without requiring a return.  That's what Powergen did for me.  I contacted them directly, they asked for my order number, and they had Amazon send me a replacement.
http://edisonbright-led.webstorepowered.com/
arn357
arn357's picture
So leaftye you’re all set then, getting a i4 replacement?
zelee
zelee's picture
i’ll try to substitute it with nearly the same part if i got one since this is my main charger for my panny Flat Stare
I4 V1 can’t handle longer cells
leaftye
arn357 wrote:
So leaftye you're all set then, getting a i4 replacement?
Yes.  Illumination Supply came through for me.  Fortunately I bought it from them.  Ever since I've been buying more and more from domestic vendors that ship from within the US.
Maxxsounds
Well, mine still works on a 12vdc wall wart as well. That’s what I’ll do for now until they contact me. If they end up sending a new one, Leaftye this one is all yours.
sandra65ghsf
Last seen: 6 years 11 months ago
Any authorized dealer?
