Battery size.
4 posts / 0 new
elbakan1
Last seen: 5 days 17 hours ago
Battery size.
Hello All!!!
I’m looking for a 3.7V lithium rechargeable that is shorter than a 16340 but longer than a CR2.
It can be up to 18mm wide.
Your input will be highly appreciated.
Carlos
Lighting up the world one flashlight at a time.
Edited by: elbakan1 on 02/19/2014 - 17:04
elbakan1
Never mind. I’m not sure such animal exists.
A Dremmel, imagination and perseverance, have made a titless 16340 fit.
Thank you for reading. Carlos.
Orion
Orion's picture
Last seen: 7 years 8 months ago
elbakan1 wrote:
Hello All!!! I’m looking for a 3.7V lithium rechargeable that is shorter than a 16340 but longer than a CR2. It can be up to 18mm wide. Your input will be highly appreciated. Carlos
The CR2 (3.0 & 3.7v) is also known as 15270. Subtract that from the 16340 (RCR123) and you get a 7mm difference. There is no other battery between the sizes of RCR123 and CR2 except for the 10280 cells (8mm diff). So you also perhaps need is an 8mm (16mm diameter) aluminium battery spacer (HERE) that can allow either the 15270 and 10280 to charge in an Ultrafire WF-138 battery charger for 16340 that can switch btw 3.0 to 3.7v. Beware the bare aluminium 8mm spacer cannot be used in a flashlight unless you tape up the edges otherwise it may cause a short circuit from contact with the inner tube.
“It is a far, far better thing that I do, than I have ever done; it is a far, far better rest that I go to than I have ever known.” – Sydney Carton in ‘A Tale of Two Cities’ by Charles Dickens (1812-1870).
elbakan1
Hi Orion.
Wow!!! I’m really impressed!!. Thank you!!.
Also, the link looks like they have all I need.
Thanks again, Carlos.
