Discharge Capacity Tests on Soshine 18650 2900mAh Protected, cells courtesy of Louis Huang of T-mart. NCR-PF/Soshine graph added
20 posts / 0 new
tatasal
Last seen: 5 min 4 sec ago
Hello Guys,
This all started when T-mart advertised an Ultrafire 4000mAh 18650 cell. I dared Louis Huang of Tmart if indeed there is one, telling him I’d like to test one in my iCharger to find out once and for all if indeed there is a 4000mAh cell. Instead, he offered to me to try this:
http://www.tmart.com/2pcs-Soshine-18650-2900mAh-3.7V-4.2V-PCB-Protective-Li-ion-Rechargeable-Batteries-Black_p161833.html
Well, I accepted his offer and he sent me a pair to try a “discharge-capacity” test.
To say the least, I’m very much surprised and impressed with the results, thinking and believing that the name Soshine is not quite yet at par as those with the major Japanese and Korean cells. You be the judge with the results, fellow BLFers.
Nothing is mentioned about the PCB’s maker nor of the cell used, except the marking ‘Made in China’ printed in the label.
The cells came in at about 3.587V out of the box. Both cells overnight-rested voltage before tests had rested voltage at 4.14./4.15 volts.
Both cells were charged at 1A charging rate on every occasion.
All cells were discharged to 2.50V during the tests.
I have also tested the over-discharge protection. It kicked in at about 2.47V.
I have not tested the over charge protection voltage ceiling.
Please take note that the voltage read-out at the upper right-most in the display AFTERDONE” is displayed is not the cut-off voltage but the voltage of the cell after it has slowly ‘bounced’ back to its normal voltage when the charger terminates the discharging process.
Nevertheless, below are some pictorial results of the discharge capacity tests I performed in my hobby charger:
Photo below shows a discharge capacity of 2871mah @1A discharge rate
Below is at 3A discharge rate at about 39min elapsed time
Below, DONE at 3A rate with 2915mah!
Below, surprise! My brand-new, unused Panasonic NCR18650PF 2900mAh came out slightly lower at 2882mAh @3A discharge
Logview result of the test on the Panasonic NCR-PF below:
Logview result of the 2nd test of the Soshine 2900 @3A, getting 2889mAh in the the pic below:
Pic below on the 2nd discharge test of the Soshine at DONE with 2889mAh
Below is at 5A discharge rate at about 24 min from start
Below, DONE at 5A discharge with 2907mah still!
Below is Cell # 2, DONE with 2870mah @ 1A rate. (Note: it is slightly shorter by about 1mm compared to the Panasonic protected)
Below is Cell #2 at about 26min from start, 3A rate
And finally below, DONE with 2883mah, @3A rate,
Edited by: tatasal on 10/16/2014 - 06:18
Gurthang
Last seen: 4 years 5 months ago
Seems like good quality cells. T-Mart price for pair is just a tad higher than other sellers for same or greater capacity cells.
tatasal
You can probably haggle for a lower price with Louis Huang for a lower price through PM here in the forum, though I have not tried it yet. It has worked for me for, 100% of the time with the other vendors.
Shadowww
Last seen: 2 days 7 hours ago
There’s Panasonic NCR18650 cell inside. No wonder it does well.
And, at $17/pair, you can get protected 3400mAh Panasonic NCR18650B’s from e.g. Fasttech.. $8 cheaper, and with much higher capacity, too.
tatasal
Soshine must be using a different make of PCB, as it is shorter by about 1mm+ compared to FT’s Panasonic protected NCR’s.
chiefinspectorfinch
chiefinspectorfinch's picture
Last seen: 10 months 2 weeks ago
Location: Croatia, country with kleptomaniac clero-fascist government
It must be a top button protection variant.
Society is like a pot full of nuts and bolts, finest pieces always end up on the bottom...
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 7 months ago
Still a nice test!  Thanks
kronological
kronological's picture
Last seen: 5 years 1 month ago
Nice tatasal…thanks for posting the results.
So…when is he gonna send you the HouseFire 4000mAh batts to test? Seems like Louis was employing a little mis-direction there…
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
jmpaul320
jmpaul320's picture
thank you for the test results! i would expect such results from a panasonic cell – but it is nice to see concrete evidence that they are indeed great cells
i just grabbed 2 pair of 3400 soshine cells from illumination supply
looks like the soshines are a nice alternative to the fasttech/wallbuys “green” protected 3400s as they are a hair shorter and might fit easier into a few lights! Smile
thx again
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
tatasal
I will be testing my FT’s Panasonic NCR18650A 3100 protected down to 2.5V @ 3A and see how it will compare to the Soshine, and see if it can exceed its declared capacity.
I will post the result when available.
moderator007
moderator007's picture
Last seen: 1 hour 2 min ago
I kind of think these maybe a Panasonic PD or the newer PF cell. I noticed from your discharge test at 5 amps it actually gained capacity over the 1 amp discharge. Also looking at HKJ’s discharge test may show signs as well.
http://lygte-info.dk/review/batteries2012/Orbtronic%2018650PD%202900mAh%20(Black)%20UK.html
Maybe you could unwrap one of the cells and then they’ll be no more mystery. :bigsmile:
tatasal
I also have Panasonic PF cells. I’ll give it a try in the coming days and show the results. Nice to try this model because it’s also a 2900mah cell.
Before this Soshine cell, I have never tried to test anything at this amperage.
Maybe I will have to fasten the crocodile clips with sturdy tape (aside from the 2 magnets/side) since I think 5 amps is the highest rate the ‘magnet only’ can handle. The crocodile clips got considerably hot. I even planned of doing a 7A discharge rate (the highest my iCharger 106 can handle) as the Soshine, according to its label, is rated up to 7.2A I think.
EldoEsq
Last seen: 1 year 11 months ago
Very informative test…thanks for sharing. Gonna pick up a pair!
moderator007
You might try one of these for adding more pressure.
http://www.harborfreight.com/4-inch-ratchet-bar-clamp-spreader-46805.html
I have been going to make one like HKJ’s forever and just haven’t got around to it. Its near the bottom of this page.
http://lygte-info.dk/info/HobbyChargers%20UK.html
tatasal
OP has been edited showing the pictorial and Logview result of the discharge capacity test of my Panasonic NCR18650PF 2900mAh, measuring out slightly lower at 2882mAh than the subject Soshine’s 2915mAh, both discharged @3A.
Most probably Soshine uses Panasonic cell inside I must say. (and as Shadowww and Moderator007 says so too)
wolfdog1226
wolfdog1226's picture
Last seen: 3 years 7 months ago
You can get Two2 of them for $17.99 from Illumination supply and they ARE 3400 mAh.
They are on sale. Normal price is $19.99 a pair which is .24 cents cheaper and 500 mAh more capacity!!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
tatasal
I’m sure T-mart is already aware of your concerns regarding its price. Let’s hope they do something about it.
moderator007
If you have the logview graph for the soshine could you post it below the PF graph. If the voltage curve under the load resembles the PF, my guess would be that it is a PF.
tatasal
Other than the test last night on the PF, I have not used the Logview in my tests for a long time. I’ll try to see if it’s still in the iCharger’s memory. If no longer there, I might as well do the same 3A discharge test on the Soshine cell, this time with the Logview result.
tatasal
I have added a new Logview graph and photo on my 2nd discharge test on the Soshine 2900mAh protected cell in the OP.
The discharge capacities are virtually identical with just over a 1% difference after 3 tests. (Soshine and Panasonic NCR-PF)
To sum it up:
First test on the Soshine: 2915mAh
Test on the Panansonic PF: 2882mAh
Second test, Soshine: 2889mAh
My observation: the differences are so negligible as to make me conclude that the Soshine cell has a Panasonic NCR-PD or PF cell inside.
