I took star off-time memory 1.3 and modified it to add the feature that the longer press (of reverse clicky switch) cycles back the mode. (It’s less than 10 lines of additional code).
Finally I have the perfect driver for me.
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
Would you mind sharing what you added and/or changed in the code?
I’d like to see the code too. I finally got some drivers with an off-time cap, and am trying to decide how to design the UI for them.
I like short-cycle memory on drivers without the capacitor, and off-time would help with avoiding extra clicks to move from, say, mode 8 to mode 9, but I’m trying to decide if there are any other good enhancements to be made. (especially if I want instant access to both moon and turbo after being off for a while)
the modes are not circular, instead when doing a short press while in the highest mode, the firmware keeps it in that mode. I wanted to be able to put it and keep it in the highest mode without accidentally missing it, with a few fast clicks.
3 commands you can issue though the reverse clicky switch:
short press->mode advance
long press (cca 1.5s in my case)->mode go back
longer press->go back to the first mode (same state as turning the light after it has been off for longer than some time – 3s in my case)
notes:
5 modes: 2.5mA 25mA 250mA 0.9A 2.8A. These are aproximations from my memory using a 2.8A driver.
added another capacitor level constant to be able to distinguish between short and long presses. This is for a cca 5uF capacitor, so it should be tuned for whatever value you are using.
I might have disabled mode memory, dont’ remember. Also I might have hardcoded mode directions. You can take original firmware and take the snippets from my code.
so, as far as I rememeber, changes are from line 280-305, and in function next_mode(), and the added capacitor level constants
next step I plan to do: implement and hide modes (strobe) “before” the first (moon) mode so that they can only be accessed immediately after the light has been switched on, using “go back” / longer press of the switch.
edit: if there is interest I can make it more “tidy” so that this is a generic change while keeping all the other regular Star features I might have disabled while researching. I know it can be frustrating to do this yourself for somebody who’s new to this, it was so for me.
edit2: coding detection of a doubleclick is possible, but then how would you distinguish between two short clicks which should advance by 2 modes, and a doubleclick. I think having doubleclicks in the same UI with short clicks would make UI non deterministic.
Now that is a very interesting idea.
I think “backward from moon” might be a great way to access what I call “impress mode” on a stupidly-bright light I’m making. I wanted something to give me quick access to its brightest mode without interfering with EDC-style use, and that might work really well.
@vex_zg
That’s a really nice adaptation.
I just looked into it and I think I saw what you did.
I perfectly understand that you alter and hardcode the stuff, it’s so much easier if you program it anyway.
A tidy version would certainly help, if you find the time. But you already were extremely helpful.
So thx again.
Ok, I'm looking for some help in creating a perfect MTB cycling headlight firmware. I'm already working with another BLF user who will be doing the mod. Now I'm not a code writer/programmer so I haven't been following the various firmwares that closely, so please direct me if there is some other firmware better suited. If I should post this in a new thread let me know, but it seems there have been numerous offshoots from JonnyC's STAR firmware posted in this thread already. Because I'm not a programmer, let me know if my requests are not feasible.
What I would like is firmware that allows a MTB'r to increase brightness with a quick-click and decrease brightness with a slightly longer click. I would like to keep the "user configurable modes" and "Turbo with stepdown" and such that are standard in STAR. I want "Off" out of the mode cycle requiring a long-press to access which means a MTB'r never turns his light off on accident. Strobe should be accessed via a long-press from "Off" only (not accessible from any other mode). I would say strobe should be set to 50% brightness and be a medium speed (not too slow and not to fast). So standard modes would be "Low-Med-High-Turbo-(repeat)-Low-Med-High. . ." It would be an additional benefit to have low-voltage monitoring with stepdown for a 2S (8.4v) battery pack (ideally for both 1S and 2S I guess, as some lights do run on 4.2v). I'd also want mode memory (really doesn't bother me if it's "on-time" or "off-time" memory).
So is this feasible? Does it already exist? Anyone willing to modify existing firmware to handle this for me?
, MTBR’s Lights & Night Riding Forum NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Wrote this over the last couple nights. It’s something I’ve wanted in a light but never could do until now. I’ll probably be putting this firmware into all of my lights and adapting it out as needed. I found through testing handheld flashlights, the strobe and beacon is rarely used- I’m not a biker. But picking modes for my lights wasn’t fun either.
I wanted a ramp as the base with a hidden mode that handles strobe. I also wanted full time voltage monitoring and low moon when the tail switch is on.
So after some late night programming I came up with this.. It’s a smooth ramp up and down. It starts off in very low moon using fast pwm and the pwm 0 bug on a BLFDD driver. Looks pretty cool with a dedomed emitter like a white painted square.
Voltage monitoring is enabled through the watchdog interrupt anytime the tail is on. It’ll ramp down the light at low volts, and back to moon. This allows you to see the tail is on at any time too and gives you the heads up, time to charge!
Hold (eswitch) from off, and it ramps up all the way to 100%. An indication flicker was put in when you hit the top. On switch release and hold, the ramp goes opposite. You can get any light level you want. From off, you can single click to high and it will start the ramp backwards too. You can stop the ramp anywhere and go back and forth. Fast click turns it off.
The hidden mode strobe and beacon are done from off, double click. Any single click from that point alternates between the strobe and beacon. So let’s for example say you get jumped from behind like your in detroit or something. Ok your a gonner in that situation.. lol
Ah I needed to stick something like that in here.. jus cause
Anyways Double click to enter the hidden modes and if you hold the switch, it will flash once and you’ll be back to moon (off).
-If anyone could host this so others can play with it. I think this useful code for the community.
(Problem posting in this thread I guess) Are you proposing this for me? Because it does seem that I could use this. It's a quick click to off instead of long press like I proposed. I never considered a ramping firmware. Not sure how feasible it is on a bike light though. Probably prefer quick taps to change modes rather than holding until you get to what you want. Can the low voltage monitoring be set for 2 cells in series?
garrybunk wrote:
Ok, I’m looking for some help in creating a perfect MTB cycling headlight firmware. … What I would like is firmware that allows a MTB’r to increase brightness with a quick-click and decrease brightness with a slightly longer click. I would like to keep the “user configurable modes” and “Turbo with stepdown” and such that are standard in STAR. I want “Off” out of the mode cycle requiring a long-press to access which means a MTB’r never turns his light off on accident. Strobe should be accessed via a long-press from “Off” only (not accessible from any other mode). I would say strobe should be set to 50% brightness and be a medium speed (not too slow and not to fast). So standard modes would be “Low-Med-High-Turbo-(repeat)-Low-Med-High. . .” It would be an additional benefit to have low-voltage monitoring with stepdown for a 2S (8.4v) battery pack (ideally for both 1S and 2S I guess, as some lights do run on 4.2v). I’d also want mode memory (really doesn’t bother me if it’s “on-time” or “off-time” memory).
What hardware are you using? Does it have an e-switch, a clicky switch, or both? What kind of driver is in it?
Could you be a bit more specific about the interface? Specifically, in any given state, which actions cause which state changes? For example,
While off:
Short click goes to (lowest/highest/memorized/other) mode.
Long click goes to (… strobe?) mode.
Double click goes to (whatever) mode.
While on:
Short click increases brightness. (loop from max to min)
Long click decreases brightness. (loop from min to max)
How do you turn the thing off?
I’m not aware of any firmwares which handle voltage monitoring properly on more than one cell in series. They generally need a zener mod, and that tends to interfere with voltage detection. I don’t have any hardware like that, so I don’t actually have a way to test it.
As far as the UI goes (if I understand it), the closest firmwares I’m aware of are two that I made for the Ferrero Rocher driver in a Roche F6. One is very close to STAR-momentary, with some additions:
While off:
Short click to go to lowest level.
Long click to go to highest level.
Short-then-long to enter battery check mode.
While on:
Short click to increase brightness. At highest mode, this turns the light off.
Long press to decrease brightness. Hold until desired level is reached, then release. Stops at “off” if you hold long enough.
The other is based on the Olight Baton UI:
While off:
Short click to go to memorized level.
Long press to go to moon.
Longer press to enter (or exit) soft-lockout mode. When unlocking, it’ll enter the last memorized mode.
Double click to go to turbo.
While on:
Short click to turn off.
Long press to increase brightness. Hold until desired level is reached, then release. Loops from “turbo” to “low”, skipping “moon”.
Double-click to enter strobe (or beacon) (not yet implemented).
There are other firmwares I haven’t tried though. I try to get everything into my firmware repository, but there are a bunch I haven’t added yet or haven’t gotten permission to add.
fellfromtypo wrote:
Toymakers brass-edc.c
Meh… wrong name. Kind of a pet peeve.
I doubt my “s7” or “brass-edc” would work for this. I like it, but not many people like party strobes as much as I do. Also, it’s designed for reverse-clicky lights with stock drivers so it can’t distinguish long or short presses at all. The UI is totally different than what was requested.
I do use it as a handlebar light, but it’s not primarily intended for that. In that role, I generally put it on “high” mode (~175 lm) or the med-turbo flasher (~50lm with a ~400lm stutter every second or so). Depends on whether I want to see better or be seen better.
fellfromtree wrote:
Wait he wrote a bell curve on the ramp? That’s what I was thinking about but the memory limits are pretty strict on the 13a.. Been writing one for the last couple days Just posted it in the star thread.
Changing the curve shape isn’t that hard. I made one with a logarithmic ramp with extra-smooth transitions between the lowest levels, because I prefer to have more of the ramp space dedicated to the lower end. Comfychair changed it to a quadratic ramp, which is closer to visually-linear. I’ve been meaning to do a cubic ramp (should be exactly visually linear) but keep procrastinating about it.
If you want to try it, it’s in the Ferrero Rocher directory in my code repo.
BTW, why did you make your firmware incapable of shutting off? Is it for dual-switch lights?
fellfromtree wrote wrote:
fellfromtypo that’s perfect name for me Wait is that supposed to be insulting?
Just thought I should mention it. Using the wrong name bothers some people, even if it’s not intended to be disrespectful.
What hardware are you using? Does it have an e-switch, a clicky switch, or both? What kind of driver is in it? Could you be a bit more specific about the interface? Specifically, in any given state, which actions cause which state changes? For example, While off: * Short click goes to (lowest/highest/memorized/other) mode. * Long click goes to (... strobe?) mode. * Double click goes to (whatever) mode. While on: * Short click increases brightness. (loop from max to min) * Long click decreases brightness. (loop from min to max) How do you turn the thing off? I'm not aware of any firmwares which handle voltage monitoring properly on more than one cell in series. They generally need a zener mod, and that tends to interfere with voltage detection. I don't have any hardware like that, so I don't actually have a way to test it. As far as the UI goes (if I understand it), the closest firmwares I'm aware of are two that I made for the Ferrero Rocher driver in a Roche F6. One is very close to STAR-momentary, with some additions: While off: * Short click to go to lowest level. * Long click to go to highest level. * Short-then-long to enter battery check mode. While on: * Short click to increase brightness. At highest mode, this turns the light off. * Long press to decrease brightness. Hold until desired level is reached, then release. Stops at "off" if you hold long enough.
The hardware is a stock UniqueFire HD-016 bike light (possibly other stock bike lights too). The MCU would be swapped out with a flashed Attiny13a (as seen in ImA4Wheeler's SolarStorm X2 mod thread). All these bike lights use an e-switch (I do believe that is correct). All run 2S2P battery packs (though the HD-016 will also run on 4.2v).
Functions / modes I'd like to see:
From Off:
*short-press turns on in "Low" mode, additional short presses continue advancing to Med, High, & Turbo regardless of how long a mode has been in use. A short press from "Turbo" returns back to "low to start thru the cycle again.
*medium-press turns on in "Turbo" mode with additional medium presses advancing backwards in mode order (high, med, low) regardless of how long a mode has been in use. A medium press from "low" returns back to "turbo" to cycle back thru again.
*long-press (guessing about 3 seconds) activates Strobe. Long press from "strobe" turns "off". Short-press from "strobe" could either do nothing, be a beacon mode, or return the light to the standard "L-M-H-T" mode sequence.
From On:
*short presses advance modes increasing from L-M-H-T, repeat.
*medium-presses go backwards in mode order (T-H-M-L, repeat).
*long-press (again, guessing 3 seconds) turns the light off.
Additional Features:
*Turbo step down to "high" after 90 seconds.
*Low voltage detection / warning - something like dropping down one mode and flashing. (If this is feasible with the 8.4v pack.)
*thermal step down would be awesome, but I don't expect it.
Note: user should never activate "off" unless done on purpose.
The short version is I caught up on a few TODO items, added support for fast PWM, made PFM easy to turn off, added some precalculated ramps, and made the default build go extremely low on moon mode. On a full high-amp cell, the lowest mode dropped from ~3.6 lumens to ~0.1 lumens on my triple-219B with a Ferrero Rocher DD driver.
So, on my hardware at least, it goes from 0.1 lumens up to 1800 lumens on a full cell. When the battery charge drops though, the output drops to like 0.000001 lumens and 1200. That extra-low moon may as well be off unless the battery is close to full. At less than full voltage, it can’t get the emitters to light up with such short pulses — they’re like one ten-millionth of a second long!
garrybunk wrote:
Any other questions?
Thanks,
Nope, that makes sense.
Most of that would be fairly small mods to the STAR-momentary code, but it could get a little hairy trying to make it tell the difference between medium and long presses, and it has no strobe. It may require some pretty significant changes to make it do both medium and long presses, and I’m undecided how best to add blinky modes.
Timed turbo step-down is already implemented. Low-voltage detection is probably possible, but might be tricky and would require getting a copy of the hardware to whoever writes the code. Thermal step down isn’t possible without extra hardware.
The button delays take awhile to get it all meshed right Garry.. It’s not a lot of code you can stuff in there so your pulling out all the tricks to get to your goal.
But to answer your question Toy it’s for my Y3 (tail and eswitch). I’m trying to find quiet momentary button switches, but no luck so made my own.
Took sleep out to keep voltage monitoring on. While I was at it, might as well exploit the PWM 0 low moon as light ring refresher. It’s really nice if you give it a try. I throw together another board and try your ramps out.
Well forget that idea.. Your code is for rgb and not the tiny13a I deal with ghetto stuff
Played with the ramp I made last night.. It’s about perfect imo- starting low to high or high to low, you don’t really need to worry about the in between.
Huh? I’ve only made firmware for attiny13a so far. Granted, the driver I was targeting has a couple indicator LEDs hooked up to extra pins, but it still works fine on boards which don’t have that.
Where do I find the source code for dual-PWM off-time?
Thanks for keeping at this guys (and girls)!!! I like playing with all my new FW’s but its nice to be able to default back to STAR every now and then when I just need something to work with no debugging / other trouble.
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
I don't know if it is the bin, or the manufacturer.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Hi vex_zg,
I had seen your first post in this matter and I found the idea truly intriguing.
But I lost track of what went on and did not notice your success. It seems your endeavour went widely unnoticed.
Did you keep the capacitor value the usual 1yF or did you use a larger one?
I’d be happy to read about it.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
i didn’t monitor the thread for a while.
here should be the code:
http://www.codeshare.io/2Vlfm
changes in the UI:
notes:
#define CAP_THRESHOLD_SHORT
#define CAP_THRESHOLD_LONG
@vex_zg
So thx again.
EDIT: Your code went blue :bigsmile:
Oshpark Boards:
Thanks vex!
I will definitely try your code…
A lot of interest from my side.
ok, I’ll make the tidy version during the weekend (if wife allows
Thanks!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding ForumNOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Anyways
Hosted it
https://github.com/fellfromtree/Yezl-Y3-Drivers
-Garry
No it won’t with series. It’s a personal project of mine- but you can increase the ramp speed if you need to..
edit Actually what you need is Toymakers brass-edc.c it’s written for her bikes
Ok, link to a description of that firmware?
Thanks,
-Garry
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/h...
Try that one.. Might be what your looking for
Nah, sorry not for me.
-Garry
While off:
While on:
While off:
While on:
While off:
While on:
Ah she got you garry..
lol Hey he asked I just delivered!
fellfromtypo that’s perfect name for me :bigsmile: Wait is that supposed to be insulting?
From Off:
From On:
Thanks,
-Garry
Er, on a side note… I just updated the Ferrero Rocher ramping UI.
Details are here, but if anyone has a non-default page size the link won’t work:
http://budgetlightforum.com/node/30673?page=7#comment-675306
I like the whole idea behind ramping
Ok just put another board together.. I saw the green and blue pins and thought, wait a second xd
I’ll flash it in tonight and check it. Thanks
This might not have all of JonnyC’s most recent additions, but it does at least have dual PWM:
I’m a little behind on merging in his latest changes.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
