STAR Firmware by JonnyC - Source Code and Explanation
1335 posts / 0 new
zeremefico
zeremefico's picture
Last seen: 10 hours 6 min ago
Hi, I really like a feature, rmm’s tk61 super driver has, the momentary turbo from off mode. It works until you leave the long press. Richard gave me some tips on how I can add this to star firmware but my skills dont let me to accomplise that.
Can anyone assist me on that?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 4 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
Adding momentary turbo from off shouldn’t be terribly difficult, but it has a cost that you lose the ability to map long-press-from-off to something else.
I added it to my todo list, but I’m not sure when it’ll happen.
For now, there are a couple of similar options:
  • Long press from off goes to turbo, release and short-press to turn it off. (in one variant, holding the initial press longer will ramp down) Short press from off goes to the lowest mode (repeat to increase brightness). Turn off by raising or lowering brightness past the maximum level. One version also has a battery check mode on short-then-long-from-off.
  • Long press from off goes to moon, short press goes to last-used level, double click from off goes to turbo. While on, short press turns the light off, long press and hold ramps brightness (smoothly or in steps). Extra-long press from off toggles soft lockout on one version of this UI.
Would either of those work? There’s basically STAR momentary, my version of STAR momentary, a smooth ramping UI, or a stepped ramping UI (like an Olight Baton).
zeremefico
Thanks TK, will I find these in your repository?
My YouTube channel
K40M F16
ToyKeeper
ToyKeeper's picture
Yes. STAR itself is in the JonnyC directory, and the others are all under ToyKeeper/Ferrero_Rocher/ .
I still need to make the red/green battery indicator bits easy to turn off at compile time; these were designed for a very specific driver. They work on other attiny13-based e-switch drivers though. The most likely thing to need changing is the PWM levels, since that’s very hardware-dependent. It’s calibrated for a FET by default.
Edit: Actually, looking at the code today, I have lots of misc cleanup to do… and need to apply upgrades from some of the files to the other files. I mostly stopped after getting things working, and didn’t finish the “polish” to make it really clean for others to use.
Edit 2: I just did some significant cleanup, mostly merging code between the three Ferrero Rocher firmwares to make them more consistent. It should be significantly easier to turn off the red/green indicators now, at least. Also freed up more space on two of the three.
seepeli
Last seen: 6 years 8 months ago
Hello all!
I really like the Star (On-Time Memory) program. It is simple and functional. However, I would like to see one additional feature: the ability to reduce the mods in the normal and reverse cycle. I mean the following:
Short press (from off) (ML), Low, Med, Off
Long press (from off) Turbo, High, (Med), Off
In this way I do not need to go through unnecessary mods.
Is this addition difficult to accomplish?
RMM
RMM's picture
Last seen: 2 years 7 months ago
seepeli wrote:
Hello all! I really like the Star (On-Time Memory) program. It is simple and functional. However, I would like to see one additional feature: the ability to reduce the mods in the normal and reverse cycle. I mean the following: Short press (from off) (ML), Low, Med, Off Long press (from off) Turbo, High, (Med), Off In this way I do not need to go through unnecessary mods. Is this addition difficult to accomplish?
I think this is impossible.  Long/short press functionality while on has been implemented by a member here in STAR off-time, but I believe it is impossible from an off state.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
seepeli
I meant, of course “Star momentary driver” program.
I apologize for the error
RMM
RMM's picture
seepeli wrote:
I meant, of course "Star momentary driver" program. I apologize for the error
No worries!  Unless I am misunderstanding what you want to do, the momentary program already does have that functionality.
seepeli
Function may be already in the program, but I do not find it there. So, I just may have to study more about the program.
RMM
RMM's picture
It is already there by default.  You can change the amount of time that constitutes a long press by changing the LONG_PRESS_DUR value.  32 ticks (0.016 seconds each tick) is the default, but I prefer 22 to 24 ticks.
ToyKeeper
ToyKeeper's picture
seepeli wrote:
Hello all!
That should be do-able with only small changes.
First, you’d want to put a 0 in the middle of the mode sequence. Second, you’d need to add a line in the main loop which sets the mode index to zero when the PWM level is zero. This way, it would reset to the default “off” state whenever you reach that level.
Using the stock STAR_momentary, you may also need to redefine the number and value of output levels, disable alt PWM, and possibly disable the hidden momentary mode.
Does this make sense?
seepeli
Yes, it does make sense!
Now I just need to focus on programming.
Thank you for your help.
FmC
FmC's picture
A couple of members have recently sought a “1 mode” driver/firmware for various reasons.
Using STAR as a base, it’s easy enough for people with limited code skills such as myself to comment out all modes bar 255, but I found that this method doesn’t play nice with the low voltage warning/step down, as there is no lower mode to step down to.
If I keep a 2nd lower mode in there, the code works as it should, but there will be instances where the lower mode can be inadvertently changed to, even when set to come on in High mode every time.
I want to keep the low voltage step down routine, so “Mr. Muggles” sees the light has dimmed noticeably, & figures that it’s time to change the battery.
I’m thinking that the best solution would be to disable the part of the code that looks for the ‘quick-click’ for the mode change, or just shorten that time so as it’s not possible to click into the lower mode.
Could one of the code Guru’s help me out with what needs to be changed – I’ve tried to follow it through, but can’t put my finger on it.
Cheers Smile
Mike C
Mike C's picture
I guess easiest would be to simply comment out the “next_mode()” call from the mode_idx&0×10 check (or comment out the entire mode_idx&0×10 check routine), disable mode memory and have mode direction high to low.
wight
Last seen: 2 years 6 months ago
I assume we are talking about the clicky firmwares.
For the clicky firmwares I think the most straightforward way to handle it is to set the minimum stepdown brightness manually. This line determines the lowest PWM level the driver will stepdown to:
if ((PWM_LVL >> 1) < modes0) {
Note that it’s based on modes [0], the first mode, but in a single mode driver that’s the only mode we have! Instead we just set it like this:
if ((PWM_LVL >> 1) < 30) {
where “30” is the lowest level we want it to step down to in this case. Assuming the single-mode was set to 255, stepdown pattern would look like this:
255, 128, 64, 32, 30, 30, 30, etc, …, critical shutdown
If you’re building a lot of single mode drivers and plan to change the minimum stepdown level a lot you may use a define for that value, just add one at the top like:
#define STEPDOWN_MINIMUM 30
if ((PWM_LVL >> 1) < STEPDOWN_MINIMUM) {
EDIT: My kingdom for a [code] tag. The forum software is messing up the first code quote, the mistake is fairly visible though (modes with a superscript zero).
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
RMM
RMM's picture
That's what I usually do: define a lower mode, but don't put it in the normal mode orders, then tell the program to step down to that level as the minimum.  I also do the same thing when I want the turbo timer to step down to a "hidden" level.
vestureofblood
vestureofblood's picture
Last seen: 3 weeks 3 days ago
Hi all,
I have a somewhat related question.    Is there any way to use a pot to control a 7135 based driver?
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
wight
vestureofblood wrote:
Hi all,
See my posts a few pages ago where I started working on the code to do that with LVP integrated.
Alternatively you can use a VaraPower driver and hook up the PWM input on the 7135’s to the gate pin on the FET of the VaraPower (but do not route LED power through the VaraPower of course!).
FmC
FmC's picture
Thanks for the help everyone, I’ll try defining the step-down level & adding it in there.
I’ll be flashing a couple this weekend if all goes well.
ToyKeeper
ToyKeeper's picture
It should work to simply make the step-down reduce the PWM level without changing the mode index. Like, if the PWM_LVL is less than some minimum (10, maybe?) blink and shut off. Otherwise, tell it to cut the PWM level in half — “PWM_LVL = PWM_LVL >> 1;”.
If there’s only one level defined, any quick tap should return the light to its maximum level… and then it’ll step down when the voltage has been low for a while.
I’m assuming this is a clicky switch.
wight
I think the clicky firmwares already behave in exactly this way (only the momentary firmware actually steps down through the modes IIRC). The issue is that with normal operation the “some minimum” is the lowest defined mode rather than an arbitrary value. After swapping in an arbitrary minimum (10, whatever) the behavior is almost exactly as you described, except that after we reach the (10) or whatever the firmware will maintain a constant output level until it hits the ADC_CRIT value, then it shuts down.
FmC
FmC's picture
wight wrote:
If you're building a lot of single mode drivers and plan to change the minimum stepdown level a lot you may use a define for that value, just add one at the top like:
OK, I've defined the stepdown value in this section of the code;
 * Settings to modify per driver
#define VOLTAGE_MON            // Comment out to disable
#define STEPDOWN_MINIMUM        50 // Hidden mode level for low voltage step down
// #define MODE_MOON            6    // Can comment out to remove mode, but should be set through soldering stars
// #define MODE_LOW            12  // Can comment out to remove mode
// #define MODE_MED            39    // Can comment out to remove mode
// #define MODE_HIGH_W_TURBO        110    // MODE_HIGH value when turbo is enabled
#define MODE_HIGH            255    // Can comment out to remove mode
// #define MODE_TURBO            255    // Can comment out to remove mode
// #define TURBO_TIMEOUT        240 // How many WTD ticks before before dropping down (.5 sec each)
#define WDT_TIMEOUT            2    // Number of WTD ticks before mode is saved (.5 sec each)
#define ADC_LOW                130    // When do we start ramping
#define ADC_CRIT            120 // When do we shut the light off
 And altered the code at the end where the stepdown routine is;
// Flash 3 times before lowering
                hold_pwm = PWM_LVL;
                i = 0;
                while (i++<3) {
                    PWM_LVL = 0;
                    _delay_ms(250);
                    PWM_LVL = hold_pwm;
                    _delay_ms(500);
                // Lower the mode by half, but don't go below lowest level
                    PWM_LVL = modes[0];
                    mode_idx = 0;
                } else {
                    PWM_LVL = (PWM_LVL >> 1);
                // See if we should change the current mode level if we've gone under the current mode.
                if (PWM_LVL < modes[mode_idx]) {
                    // Lower our recorded mode
                    mode_idx--;
 I'm bench testing this with a partially charged cell, starting around 3.2v, & letting it run down.
I don't get the three flashes + stepdown to the defined value (50.)
Instead, it goes straight to the 10 flashes for critical voltage, but does not power off.
At no point does it step down to the predefined value (50).
What have I done wrong?
vex_zg
Last seen: 4 years 3 months ago
Hi all,
I was thinking about that also a few weeks ago, It should be fairly easy to make a voltage divider with the pot, and put it to ADC.
wight
Hi all,
In order to maintain use of the full physical throw of the pot and have the full desired range of PWM levels stay available a voltage divider is no good by itself – it’s not regulated so the maximum input will go down as battery voltage declines. Instead you need a regulated voltage source, probably either an LDO or on a Zener mod driver just add a divider off of the Zener. That way you have fixed target for both high and low voltages when looking at the ADC values.
wight
OK, I’ve defined the stepdown value in this section of the code; [snip]
 And altered the code at the end where the stepdown routine is; [snip]
I don’t get the three flashes + stepdown to the defined value (50.)
Oops, my mistake. Oops
Also look here:
if (mode_idx  0 && PWM_LVL
Looks like it should be:
if (mode_idx  0 && PWM_LVL <= STEPDOWN_MINIMUM) {
vex_zg
wight wrote:
Hi all,
i see 3 options
1. use regulated voltage reference
2. design the circuit so that you are comparing voltage of the battery with the voltage drop of the divider. Did not think this one through thoroughly though.
3. not use the full physical range of the pot, so you have some headroom to make up for the voltage drop (i.e with full battery you need to turn the pot only to 60% of it’s range to get 100% light, and with low battery you need to turn it to 100% to get 100% of the output
also the pot solution might be used with constant DC power supply, so perhaps battery is not the power source in this one at all.
wight
vex_zg wrote:
i see 3 options
Yes, all correct. (Based on who’s asking, I assume it’s a flashlight. VoB is probably looking for something like a new Lambda VaraPower.)
The ATtiny can be set to use Vcc as the reference voltage, so your #2 option is a good one assuming that don’t need to do battery monitoring. If we do need to do battery monitoring then we have to switch the Vref back and forth. I’ve already written (and posted in this thread) simple/hacky code to do that – it didn’t work correctly. I think we probably need to take two readings every time we switch the Vref, but I haven’t tried that yet.
FmC
FmC's picture
wight wrote:
Also look here:
Thanks wight, I’ll try that out tonight. Beer
FmC
FmC's picture
wight wrote:
Also look here:
if (mode_idx == 0 && PWM_LVL <= modes[mode_idx]) {
if (mode_idx == 0 && PWM_LVL <= STEPDOWN_MINIMUM) {
Thanks - that worked, in so far as stepping down to the STEPDOWN_MINIMUM value.
However, it continues to give the 3 periodic warning flashes, until the voltage gets down to around the 2.6 mark, where it seems to eventually peter-out.
It does not appear to be getting to the Critical routine (10 flashes & power down).
As it is now, I'm happy with the operation. I ended up increasing the time between warning flashes, as they were annoyingly frequent.
For educational purposes, I'm still interested as to why it's not getting to the Critical/Shutdown routine.
#ifdef VOLTAGE_MON
        if (low_voltage(ADC_LOW)) {
            // We need to go to a lower level
                // Can't go any lower than the lowest mode
                // Wait until we hit the critical level before flashing 10 times and turning off
                while (!low_voltage(ADC_CRIT));
                i = 0;
                while (i++<10) {
                    PWM_LVL = 0;
                    _delay_ms(250);
                    PWM_LVL = modes[0];
                    _delay_ms(500);
                // Turn off the light
                PWM_LVL = 0;
                // Disable WDT so it doesn't wake us up
                WDT_off();
                // Power down as many components as possible
                set_sleep_mode(SLEEP_MODE_PWR_DOWN);
                sleep_mode();
            } else {
                hold_pwm = PWM_LVL;
                i = 0;
                while (i++<3) {
                    PWM_LVL = 0;
                    _delay_ms(250);
                    PWM_LVL = hold_pwm;
                    _delay_ms(500);
                    PWM_LVL = modes[0];
                    mode_idx = 0;
                } else {
                    mode_idx--;
            // Wait 10 seconds before lowering the level again
            _delay_ms(10000);
    #endif
wight
FmC wrote:
<p>
wight wrote:
Also look here:</p><pre>if (mode_idx == 0 &amp;&amp; PWM_LVL &lt;= modes[mode_idx]) {</pre><p>Looks like it should be:</p><pre>if (mode_idx == 0 &amp;&amp; PWM_LVL &lt;= STEPDOWN_MINIMUM) {</pre><p>
</p><p>Thanks - that worked, in so far as stepping down to the STEPDOWN_MINIMUM value.</p><p>However, it continues to give the 3 periodic warning flashes, until the voltage gets down to around the 2.6 mark, where it seems to eventually peter-out.</p><p>It does not appear to be getting to the Critical routine (10 flashes &amp; power down).</p><p>As it is now, I'm happy with the operation. I ended up increasing the time between warning flashes, as they were annoyingly frequent.</p><p>For educational purposes, I'm still interested as to why it's not getting to the Critical/Shutdown routine.</p>
Probably due to an additional oversight on my part.  Let's see where I went wrong.
Hmm.  Are you _certain_ that it's stepping down?  To me it [now] looks pretty clear that the stepdown process is broken by the changes I suggested.  It seems that I missed was this line that will continue to reset the driver to modes[0] (100% duty cycle, 255/255):
                    PWM_LVL = modes[0];
                    mode_idx = 0;
                } else {
As you can see, the line highlighted in red above should continue to reset the mode to mode zero every time we get PWM_LVL down to the point where halving it will take it below STEPDOWN_MINIMUM.  Instead we should set it to STEPDOWN_MINIMUM there!  Otherwise this conditional never becomes true: "if (mode_idx == 0 && PWM_LVL <= STEPDOWN_MINIMUM)" because we keep stepping down from modes[0] towards STEPDOWN_MINIMUM over and over without ever actually reaching <= STEPDOWN_MINIMUM.
Depending on what you set STEPDOWN_MINIMUM to we should be stepping down several times and then going back up, then doing it again - over and over.  At least that's what I see at the moment...
