STAR Firmware by JonnyC - Source Code and Explanation
1335 posts / 0 new
HighEfficiency
HighEfficiency's picture
Last seen: 4 years 2 months ago
odd wrote:
This should work:
Comment out “#define ADC_LOW” and replace the voltage-mon section with this one:
EDIT: Too late :~ , but its a cleaner soultion Smile
#ifdef VOLTAGE_MON
#ifdef ADC_LOW
if (low_voltage(ADC_LOW)) {
// We need to go to a lower level
if (mode_idx == 0 && ALT_PWM_LVL <= modes[mode_idx]) {
// Can't go any lower than the lowest mode
// Wait until we hit the critical level before flashing 10 times and turning off
#endif
while (!low_voltage(ADC_CRIT));
i = 0;
while (i++<10) {
set_output(0);
_delay_ms(250);
set_output(modes[0]);
_delay_ms(500);
// Turn off the light
set_output(0);
// Disable WDT so it doesn't wake us up
WDT_off();
// Power down as many components as possible
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_mode();
#ifdef ADC_LOW
} else {
// Flash 3 times before lowering
hold_pwm = ALT_PWM_LVL;
i = 0;
while (i++<3) {
set_output(0);
_delay_ms(250);
set_output(hold_pwm);
_delay_ms(500);
// Lower the mode by half, but don't go below lowest level
if ((ALT_PWM_LVL >> 1) < modes[0]) {
mode_idx = 0;
} else {
set_output(ALT_PWM_LVL >> 1);
// See if we should change the current mode level if we've gone under the current mode.
if (ALT_PWM_LVL < modes[mode_idx]) {
// Lower our recorded mode
mode_idx--;
// Wait 3 seconds before lowering the level again
_delay_ms(3000);
#endif
#endif
Odd – so far so good on this. I’ll keep testing it and report back.
HighEfficiency
Odd – so far so good on the code. Thanks
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 16 min ago
pilotdog68 wrote:
How much work would it be to add dual-pwm to the dual-switch firmware?
Hmm… good question. I didn’t realize there was still a flavor of STAR without dual PWM support.
I’m not sure how much work it would be. I just checked for updates upstream, hoping it had already been done, and there haven’t been any since January. The methods used in other versions of STAR have varied, and the dual switch driver isn’t quite like any other. So, it would be more than just a simple merge or a cut-and-paste job. I think there’s at least room to add it though; I get 796 bytes when I compile STAR_dual_switch.
pilotdog68
pilotdog68's picture
Last seen: 5 months 5 days ago
TK, would it be easier to add mode memory to the STAR momentary FW? I feel like that’s all it would take to make it work as a dual-switch FW, and it already has dual-pwm
(of course, I think we’d all love it if you were to make your own dual-switch FW Wink Soft-toggling memory would be really nice on a dual switch light, and better control of the second channel would be welcome as well)
ToyKeeper
ToyKeeper's picture
You know, I’m not sure what the easiest option would be.
There should be room to add a bit of eeprom save/restore code to STAR_momentary, but I doubt there would be room to add much more.
The momentary switch code is significantly more complicated than clicky switch code and uses more room, so it’s kind of hard to fit both. However, I haven’t seriously tried so I’m not sure how hard it is.
If I can do it without so many interrupt handlers, maybe I can save enough room to fit both plus extras, but I get the feeling I’ll have to basically start from scratch in order to make any significant progress.
pilotdog68
Question: Is there a way to have STAR dual-switch recognize when the e-switch is held while power is turned on? So that moon or strobe is accessible from off by holding the mode switch while the main power switch is clicked? Perhaps by checking e-switch status once outside of the main loop so it only checks it when power is first applied?
ToyKeeper
ToyKeeper's picture
Sure, it should be very possible to have a different response for “power connected while switch is up” versus “power connected while switch is down”. I don’t think anyone has tried it, but it should be easy.
I haven’t been doing e-switch stuff lately, but have been itching to start on a FET+1 e-switch project. I definitely won’t have time for like a month though, and would need some extra parts.
pilotdog68
If only we all had more time, right? Smile
I need to increase my own understanding of how the code actually functions. It’s probably my weakest point.
Tom E
Tom E's picture
Last seen: 7 hours 52 min ago
I tried combining my e-switch version with my NOINIT (power switch) in order to get full functionality on both switch's, but ran out of code space. I just ordered a few ATTiny45's - they have 4 * code and data space. There's been some successful porting effort goin on, so hoping I can get these up and running.
Update: Mission Accomplished! Got it working now on a ATtiny45. Some details here: http://budgetlightforum.com/node/41067, post #115.
ToyKeeper
ToyKeeper's picture
Awesome. Smile
I’m hoping I can fit both by reducing the use of interrupts and volatile variables in the e-switch code. I’ll probably still need 2K to fit both the A6 code and the smooth ramping code though.
Tom E
Tom E's picture
Ahh, yes. The only down side to the 25's now is the cost, but I really haven't done much shopping around yet. Mouser is a killer for shipping and NYS taxes, so $30 becomes $40 easy. Dunno yet where to go next. Would like to get temp sensor working, but also would love to get what I have now into a X6R, Convoy L4, Warsun X60, Y3, etc. We know of course, temp sensor and 25/45/85's have been implemented by or for BLFers, but no one apparently has posted any helpful details - obviously could be good reason why they can't, dunno.
finges
Last seen: 20 hours 29 min ago
Tom E wrote:
The only down side to the 25’s now is the cost
Would this be the right one?
ImA4Wheelr
Last seen: 2 weeks 1 day ago
That is the larger size.  You would need to bend the pin down slightly for most drivers, except the 22mm DD+7135 wight driver board.  A direct drop in would be the SSU package on other boards/drivers.  If you are willing to use the larger SU package, you can get 10 for $16.20 here:
http://www.ebay.com/itm/201060737002?_trksid=p2057872.m2749.l2649&ssPage...
These are what I'm using.  They seem to work fine.  As of last night, I have 3 of them up and working in different types of drivers.  Of the 5 I have connected to a programmer, all 5 successfully connected..
Tom E
Tom E's picture
Well at least it looks like it's worth looking around. These are the 25's with the same package as the 13A's:
ATtiny25V-10SSU     (I ordered these from Mouser, qty 10 for $19.50, total order: $32.64, total payment: $39.63)
ATtiny25V-10SSUR
ATtiny25V-10SSH
ATtiny25V-10SSHR
In the same Mouser order, I also ordered qty 3 of these:  ATTINY85V-10SU for $2.42 each.
Just doing a search on the SSU part # on AliExpress found qty 10 for like $13-$14 which is a pretty good deal, just hope these haven't been pre-programmed with the reset bit set as an I/O pin - this happened to me for a qty 10 order of 13A's on eBay.
ImA4Wheelr
At the above link, Tom E wrote:
. . . I did get brown out detection OFF time method working, and it's working in the eswitch version. So, I have firmware that is 1074 bytes running on a 45, about 26% code space used, and has a fully functioning power clicky switch support with mode memory and OFF time support, as well as full e-switch support! Best Of Both Smile. Dang, this is getting easy...
Using that Fuse calculator too, I am using these fuse values to enable this combo of features:
  -Ulfuse:w:0xE2:m -Uhfuse:w:0xdf:m -Uefuse:w:0xfe:m
Basically, I melded the STAR_NOINIT stuff into my eswitch version. This is where I ran out of code space before, and why I got into the 25/45/85's, specially since ImA4Wheelr got it basically up initially.
For the fuses, I analyzed what was done for the full brown-out detection, and made the same settings for the 45 family. With the Fuse Calculator, it was pretty easy to do.
Really sounds complicated to combine those functionalities.  Would love to try in a couple of lights if you at a point you wouldn't mind sharing it.  Could it be used in a e-switch light to assist with lock out?  Something like, the light can't be turned off with the momentary switch.  Would force user to "lock out" to turn off.  That way, the risk of forgetting to lock out is significantly reduced.
Tom E
Tom E's picture
I wouldn't mind posting it as-is, just that it hasn't been tested in a light yet, so thought I'd wait, but of course, couldn't get to it as soon as I hoped.
It's here, ZIP'ed: Google Drive shared folder, file called: switch_NOINIT.zip. Let me know if you can access/dnld it ok.
Well, then it would work like a L4 (I believe), and that's what I was trying to avoid. My goal was full functionality from the side switch. If you can't turn it off from the side switch, it's not fully functional. I agree it would help from forgetting to lock out the light though - good point, but I would not want to sacrifice ON/OFF because of that.
Update:
 Just installed it in my X6R. Swapped the 13A out for a 25V on the piggyback wight FET+1 driver, and it worked out pretty well - used a hot air gun, and the one I got doesn't target a part well, so other parts loosened up but didn't move around. Reflowing did the same thing. What I did was used solder wick to remove the old solder off the pad, then applied new solder paste - think it works out better this way.
Not sure what happened, but didn't find the fuse settings I used in previous testing (or messed them up??). I used these on the 25 and seems to work well:
     -Ulfuse:w:0xE2:m -Uhfuse:w:0xDE:m -Uefuse:w:0xFE:m
Also, the brown-out NOINIT timing is a bit long. I would prefer it quicker - you have to have the light off for maybe 1-2 secs or so for it to keep the same mode.
ToyKeeper
ToyKeeper's picture
Tom E wrote:
Also, the brown-out NOINIT timing is a bit long. I would prefer it quicker – you have to have the light off for maybe 1-2 secs or so for it to keep the same mode.
Do you have an offtime capacitor on that? If so, make sure it isn’t charged, and the noinit thing might speed up. But then, if you have an OTC, it’s probably better to use that instead of noinit. Smile
Tom E
Tom E's picture
True Smile. I think I'm using the OTC pad to solder the e-switch wire to. It was bugging me a few mins ago - couldn't recall if there's some setting brown out detection could work off of. Thought it worked better, maybe PCB design dependent - not sure.
Ohh - I set turbo timeout to 90 seconds and timed it on the bench with a TrustFire - was somewhere between 90 to 91 secs on my stopwatch - impressive! Wonder if it works more accurate configured at 8 Mhz. Only choices for internal clock is 6.4 Mhz and 8 Mhz, at least in the fuse setting app.
So, this was a 25V SSU (same package as a 13A) on a 17mm wight FET+1 driver. Didn't realize the X6R's tailcap switch is a fwd (tactical) clicky - works well, interesting...
ImA4Wheelr
Thank you Tom E for sharing your latest WIP.  I as hoping to install and try it out this weekend but things came up.  Hopefully, I will by the end of the week.
Tom E
Tom E's picture
Ok, no prob. Couply of things for you and T_K (anyone else for that matter) on eswitch_NOINIT:
  • e-switch and power button share the same mode table, default is 5 modes with 1st 3 modes using the 7135
  • strobe is not accessible from the power switch - it's not in the table, special only for the e-switch
  • changing modes on the e-switch does not effect the stored mode, so the power switch saved mode is unaffected. I'm not sure if this is a good thing or bad thing, might be more confusing, but seems nice for some usages like tactical - you can program the power button to come up in Hi/turbo if you want, then change modes from the tail, and that will set a new default, including OFF. For now, I'm gonna leave it this way but not sure if this is the best. Might make a nice user configurable option.
 I'm also thinking about more functionality, like using the long press to get strobe now, but treat is as an advanced mode set, so another long hold might be battery check, slow strobe, beacons, etc. A good thing I could do, for safety, is if the e-switch is permanently stuck, I could cycle thru the advanced modes and end it with OFF.
RMM
RMM's picture
Exciting stuff Tom.  You rock!  I'll be happy to start helping work some more on the temp. sensor stuff, but it's got to wait until next week.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
ToyKeeper
ToyKeeper's picture
Tom, you keep putting things on my todo list. Smile
Have you ever tried using git/github or bzr/launchpad? They’re pretty helpful for tracking and generally dealing with code.
Tom E
Tom E's picture
We use Git @work, but we have our own server repository. Been using github, but not for my own stuff. I know, really should... I gotta get better organized, overall. I'm off in way too many directions.
ToyKeeper
ToyKeeper's picture
Awesome, so it shouldn’t be a big stretch. Smile
I really need to spend some serious time with git. It’s functionally almost identical to bzr, but everything has different names and options and defaults. And git officially won the DVCS wars, so I should get on board with it. Even Launchpad supports it now, though it’s not widely used there yet.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 3 months ago
WarHawk-AVG wrote:
wight wrote:
WarHawk-AVG wrote:
I have a question…I boogered up my SOIC clip, it makes if VERY difficult to program the ATtiny13 on the board
Would it be possible if there was a breakout board (pre wired to the correct pins) to flash the chip BEFORE soldering on the board?
I designed a Nanjg Programmer…is it possible to just set the IC on the pads, gently hold it down with something non shorting, plug into the standard header cord and flash it this way? (I have several loose ATtiny13A’s
I have it on my OSHPark account but not sharing…wanted to know if this was possible and/or if it would work
[snip]
If it works…they would be $1.60 for a set of 3, just need a bunch of header pins to solder into the thru holes
Good work. The boards like this I normally see are actually ment to be soldered to, they are known as breakout boards and meant for prototyping. They are available for all popular SMD package sizes and pin counts, you use them to hookup hard to work with parts for easy hand wiring or breadboarding. I don’t see a problem using them in the way you describe though, + RMM already said it works ;-).
Another option for this type of flashing is a SOIC ZIF socket such as this one at Adafruit. That might be good for those who have unsteady hands as well.
I’ve actually been thinking about making a board similar to yours, but setup for pogo pins such as these. It would be for in-place programming w/out a clip.
What is the part # from mouser/digikey on that SOIC ZIF and the Eagle .lbr file…and I will whip up a nanjg board with that ZIF socket. $15.95 ain’t bad…but why do that when you can DIY right Wink
Well only place to get that module is adafruit…so might have to go that route…but too ‘spensive for my blood at this time…
Followup and new find if interested folks
https://www.fasttech.com/products/0/10012070/2056803-sop8-to-dip8-progra...
And a 16 pin one
https://www.fasttech.com/products/0/10012067/2056800-sop16-to-dip16-150m...
HighEfficiency
Thanks to the input of several in this thread I was able to manipulate the code for a 5 hour shutoff on a light using the STAR firmware.
I recently had the timer fail. Instead of shutting off as usual, the light kept running.
Any ideas why something like this would happen?
RMM
RMM's picture
HighEfficiency wrote:
Thanks to the input of several in this thread I was able to manipulate the code for a 5 hour shutoff on a light using the STAR firmware. I recently had the timer fail. Instead of shutting off as usual, the light kept running. Any ideas why something like this would happen?
This was on a light that you had tested working previously?  A momentary power glitch or inadvertent MCU reset would be enough to reset the timer.
ToyKeeper
ToyKeeper's picture
That’s a good point. It might be a good idea to add a “noinit” attribute to the timer variable, and only set it to zero on boot if the offtime capacitor (or noinit-based offtime sensor) says it was a long press. This would allow the timer to keep counting after a short press or brief interruption.
HighEfficiency
RMM – yes this the timer on this light had been working. Since I posted yesterday it has failed once again. I’ll test again today to see if it continues to fail.
Toy – as always thanks for the suggestion. I may reach out for a bit of clarification on the specifics of implementing this.
HighEfficiency
I’ve flashed another circuit with the 5 hour timer for testing and have also had this one fail once in about 10 cycles.
Any additional thoughts here?
Many thanks
