Test/Review of Charger Efest Xsmart
At first glance this charge might look like the Xblack charger, but it is a much better charger.
Efest has been building a line of chargers from single cell to four cell with fixed and variable current, this is a single cell charger with usb output.
The charger I got was not in the final box, i.e. I do not know what is included with the charger.
The charger can be supplied with 12V DC from a power supply or from a car.
It does also have a micro usb power input and a usb power output.
I wonder why the input is labeled with voltage and current, but not the output.
The charger can handle from 31mm to 72mm long batteries.
The charger has the usual red/green led. It is red while charging and green at all other times when power is connected.
It will flash green or red when usb output is active, depending on power level on the battery.
The charger can handle 70 mm long batteries including flat top cells.
Measurements charger
  • When not connected to power it will discharges with up to 0.5mA.
  • When power is connected with a full battery, the charger will discharge with 0.5mA
  • Below 2.8 volt the charger charges with up to 150mA
  • Above 2.8 volt is will charge LiIon with full current.
  • It will restart if battery drops to 4.13 volt.
  • It will not restart charging on reinsertion of the battery or power cycling.
The charger does a good CC/CV charging with a termination current of about 50mA, this is very good.
There is no surprise with the 2600 and 3400 mAh batteries.
The old IMR 16340 cells does also charge fine.
Same with the IMR 18350 cell.
Using the 5 volt input, do put a restriction on the charger. The current is reduced when the voltage reach 4 volt. The only negative aspect of this is the longer charge time.
M1: 36,7°C, M2: 37,5°C, HS1: 49,0°C
With 12V supply there is some heat in the charger.
M1: 38,4°C, M2: 31,1°C, HS1: 39,2°C
Using the usb power supply does reduce the heat in the charger significantly.
The charger starts very fast.
Measurements USB output
  • USB output is will turn on automatic when loaded, it is very sensitive (Less than 0.05mA load needed).
  • USB output is coded as Apple 1A
  • Led flashes green when usb output is active
  • Led flashes red when battery is nearly empty (3.30 volt) in usb output mode.
  • USB output is off when power is connected to the charger.
  • Output turns off when overloaded.
The usb output can deliver 1.2A, this is very good value for a 1A output.
The output can deliver 1A for 1½ hour, before it gets into problems.
Reducing the current to 0.5A more than double the time and gets rid of any funny stuff.
With a cutoff voltage of 3V, it is safe with all LiIon batteries, but cannot get the full capacity from the new generation Panasonic cell (2900/31000/3400/3600mAh).
Other battery capacities works just as well, and can sustain the output for different times.
The noise is very low on this usb output (17mV rms).
And reducing the current will also reduce the noise (8mV rms).
Conclusion
This charger is a good single channel charger. It can charger any 18650 battery, but with smaller batteries it has to be IMR batteries.
I like the automatic turn on for the usb output and it output works fairly well.
Notes
The charger was supplied by Efest for a review.
Read more about how I test USB power supplies and chargers
really?
The PA18650-31 needs to charge at 12V aroud 290 min., at 5V only 275 min.
So I think, using the 5V is faster, at least according to what you have measured.
PS: On your HP is the half missing click
Yes, really.
It looks like there is a capacity difference on my 3100mAh cells.
Maybe it is time to do a test cycle and remove the older LiIon cells from my charger test.
Thanks for the notification, I have fixed it.
I can’t anythink say about the diefferent capacity.
But I have some other points.
I have a few screenshots taken from your charts and have Enlarges and compared some points (I hope this is okay).
Here are three observations. In all three comparisons is left charge at 12V and right at 5V
The 1. The Currect at 5V is higher:
2. after 100min, charging time, the battery has a higher capacity (Is the point in the middle 100 minutes on the x-axis and 3.7 V on the y-axis)
And the same after 150 min.
I do not know how accurate the charts, but I mean charge via usb is faster
The charts are fairly accurate, current is measured with a 6½ digit DMM using the same 10mOhm resistance for all curves.
You might be correct that the charge current is slightly higher at 5 volt.
I do not have time to analyze the data today, but if you want the raw data to analyze, send a email (email address is at the bottom of my website).
Thanks for the review HKJ.
Just a heads up. I just received this charger & while it feels as if might be good spare charger/power bank that I leave in my bag please note that so far it the USB output ONLY works with the supplied micro USB cable (it has a slightly elongated micro-USB jack.) I haven’t been able to get it to work with other micro-USB cables or a cable for an iphone 4s.
I hope that I eventually find myself wrong -> it’s still a nice feeling charger/power bank but if it really does only supply USB output thru the included cable then I wish I had purchased something else. :frowning:
I did not have that problem, I never test with the supplied cables, because I need my modified cables to do the measurements.
Thx for that 411 HKJ. I’ll keep on checking other cables than. (hmm, there is always a possibility that I have a lemon on my hands…)
