Review: cheap 18650 mobile power bank
Warning ! Apparently there is another variant of this power bank with PCB using FM6316CE ic that appears to be very problematic, perhaps even dangerous. Seems like white color power bank is still OK…
This generic power bank appeared rather recently in many shops with very decent specifications and incredible price in 2-3 $ range ! Although I have no means to test it thoroughly as some other members, some basic info might be helpful…
Construction of this power bank is rather simple and straightforward to use with clearly marked input and output ports.
Only unprotected cells are supported…
Closing lid is quite sturdy and keeps everything nice and tight inside but it might be a little difficult to open.
Overall build and plastic quality is superb and surprising for this price range, even usb connectors feels solid.
Positive battery tab and negative side spring are also high quality and will ensure reliable connection to battery.
Circuitry is based on a brand new ETA9635 ic that combines li-ion charger, protection and step up converter in a single 8-pin SOIC package !
Specifications promise up to 1A/5V output with high efficiency of 85% for 0.9A output and 92% for 0.5A. Battery charging (cc/cv) current is also specified up to 1A. It also promises short circuit, overload protection and 2.8V cut out voltage along with 50uA quiescent current.
PCB looks quite decent.
View of indicator led’s and battery positive tag.
USB output is AFAICT apple coded and it provides 0.5A current to android devices.
Output voltage is well in range of usb specification and quite stable (near 5V or slightly under)
Output current is just a little bit below 0.9A and fairly stable and no detectable heat is produced.
Actual charging current is 0.9A and it seems that cc/cv pattern is followed properly. When battery is full charger stops charging completely. Termination voltage is in 4.17-4.19 V range on all of four power banks I tested and termination current is around 100mA.
Two indicator led’s indicate status of charging or discharging in following pattern:
RED is lit while charging battery, BLUE and RED when done.
BLUE and RED is lit while discharging and battery is over 4V, under 4V only blue remains and shuts off when battery is depleted.
Led’s are adequately bright while charging but when discharging they are barely visible, especially as white lid blocks quite a bit of light…
Overall this is a great little power bank. Quality is mind blowing for it’s price and all examples I tested worked flawlessly and ensured safe operation for both battery and device charged. Weak led indicators are IMHO only real drawback…
It’s available in several colors at popular web stores (currently 1.99$ at BIC)
Nice review. Thank you very much. Looks like a great little bargain for a handy device.
Thank you, please post more often :wink:
Nice review, thanks for the great work :slight_smile:
do you have a method for opening this? i got the impression it was a more or less permanent locking design
Link to the powerbank?
Also need HKJ to do some voltage/current tests, see if it holds up at 1A clean or drops off like some of the other cheaper power banks...but very very nice they put the charger/setup up circuitry into one IC...most excellent!
Found link at Banggood
Coupon code BLF does apply!
FYI
Small flat screwdriver or plastic lever will do fine. Plastic is quite sturdy and won’t be easily damaged…
Currently on action at BIC
http://www.buyincoins.com/item/35357.html
BIC4ELECTRO 6% coupon is valid…
Oh even better! Darn good price!
I’m thinking at ordering this or Miller 102 V5 mainly for backup power for my phone and 3DS. Which one has better circuitry?
This one...the miller just like any of the other single cell portable power banks have 2 separate circuits, one for charge of the Li Ion battery in the pack, then one for the boost output for 5vdc, this one both are contained in one chip, 1A both directions (probably less due to inefficiencies and heat loss)
Unless they have new miller chargers that have something similar...
Like this one (the latest V5 Miller charger)
https://www.fasttech.com/products/1421/10001919/1137904
  • Single TP4056 IC for battery charging
  • Single PT1301 IC for charging devices
I was tempted to order one of each of 6 colors from BIC. At $2 each, even just the cell holder portion is worth it.
However, I resisted the urge and only ordered 1 each of black, white and pink.
See, I CAN control my addictions :smiley:
I had 10 in the basket and hovering over the buy button then remembered my wife put the kabosh on my spending till payday, already bought 4 at $1.00 more expensive at banggood
I have a BUNCH of panasonic laptop pulls (thanks 18sixfifty) and itching to try em out, I have two super cheapo tube ones that just can’t hack it and end up going dead because they leave a draw on the battery all the time (plus the batteries suck anyway!)
Just imagine a "mod" and putting this on a 4x parallel 18650 battery pack!
looks good.
Initially I had over a dozen in my cart with the intention of gifting these all out but then I thought -> “I’d better order just one to start out.”
Being one handed I’m not sure how much trouble I might have getting this thing open. Better to just try one out now. I can always order a bunch later if it’s a go.
Thanks for the nice review on this!
AZ
Order two of them to try out. Thanks for the review on these.
They do come with lid open so it’s not an issue…
So V5 is using 2 separate ICs while this one using the same IC for both tasks?
Can anyone recommend some good batteries to put in these? Ideally something under $6? Thanks!
Yes, per the data sheet, it eliminates two separate channels worth of electronics and soldering
I am planning on using laptop pull panasonics (or sony [the red ones])
Decent enough and can handle 1A charge and has enough mAh to actually be worth it
