I have this 2D maglite I plan on modding with a SST-90 I have lying around. The vF of the led is going to be on the upwards side of 3 volts when driven at 9 amps. Any suggestions for batteries? I’m not too keen on hacking up the body, making it shorter to accommodate a 18650 or 26650 so what are my options?
I’ve kind of decided I probably would get 2 adaptors like this and modify together so 6 of the 14500s would be in parallel config. That way I am still above my forward voltage. I plan to use nanjig drivers set up with a master- slave config like Old-Lumens did.
Will there be a problem running all those batteries in parallel? I really would just like to use NIMH D cells but the voltage is too low.
Having some second thoughts about this… I tested my sst-90 last night and at 5 amps the forward voltage was right 3.9 volts. At 9 amps, the vf is probably going to be something like 4.2 volts. I’m not sure that’s going to work given a li-on cell puts out approx. the same voltage and only when fully charged.
I also have an MT-G2 I might use instead, but with the 14500s in 3 parallel 2 series config. Then comes the headache of finding a proper driver…. and BTW whatever led I used will be direct bonded to either a copper mpcb or a custom copper slug.
