New arrivals - 17mm Cree XM-L/XM-L2 1-Mode 3.0V-18V Circuit Board - Newestrend.com
18 posts / 0 new
zlmlzm
zlmlzm's picture
Last seen: 6 years 9 months ago
A good driver board for DIY your Flashlight.
New arrivals
Aptitude+Attitude=Altitude
Ouchyfoot
Ouchyfoot's picture
Last seen: 10 months 3 weeks ago
Nice. 17mm and 3V-18V.
Too bad it’s only 2A. It would be nice if it were 3A.
Good for running 2 x CR123.
AlexGT
AlexGT's picture
Last seen: 1 day 10 hours ago
Buck/boost?
Can it be modded with a lower sense resistor for more amps?
Hikelite
Last seen: 7 hours 59 min ago
Why these Chinese specify USA as their location?
zlmlzm
zlmlzm's picture
Hi,Hikelite
Sorry,Let you misunderstood,this is one of my mistake,right now.
AlexGT
AlexGT's picture
Can you answer my previous question? Thnx!
Rufusbduck
Rufusbduck's picture
Last seen: 9 months 4 days ago
Prices seem high in general but they do have an impressive selection of aspherics.
Scott
DayLighter
DayLighter's picture
Last seen: 4 years 8 months ago
I took the bait and bought some drivers.. and let’s see if I can add resistor to it.. it’s seems plausible as it has 2 R500 on it ;)
The only way to do a great work is to love what you do.
Hikelite
DayLighter what you have posted is not a buck driver.
DayLighter
I didn’t say it was buck driver.. I just posted what I ordered Silly
Overclocker
Last seen: 4 years 1 month ago
New arrivals
If I use this driver on a 12v car can I string three XM-L2 emitters in series using one driver?
Overclocker
BEWARE!
this just arrived today. it is a 1amp driver! not 2amp as advertised. what a bunch of l!@8$
i’ll try to change the sense resistor later…
TexasToasted
TexasToasted's picture
Last seen: 1 week 2 days ago
It’s rated for input of 3V to 18V. It may only produce 2A with a high input voltage.
Overclocker
i used 12v with 3 XML’s in series. got 1A
then i tried 2 XML’s in series. same 1A
stock sense resistor is R250. i paralleled an R100. got 2.65A, so yes it’s usable just be prepared to have to mod it
DayLighter
can you just remove the R250 and just installed R100 instead?
I’ll be receiving my drivers soon.. it’s in US sorting center now Smile
Overclocker
yes you could do that. this was just a preliminary test so i just soldered the R100 on top of it coz it’s easier
my target current is actually around 2.5A. it’s gonna be a DIY lightbar with 15 XML’s using 5 of these drivers
comfychair
comfychair's picture
Last seen: 5 years 8 months ago
DayLighter wrote:
can you just remove the R250 and just installed R100 instead? I'll be receiving my drivers soon.. it's in US sorting center now :)
That would give you higher resistance and thus lower current, resistors in parallel always add up to less than the lowest value one.
R100 is 0.1 ohms, R250 is 0.25 ohms (http://www.hobby-hour.com/electronics/smdcalc.php). 0.1 and 0.25 in parallel equals 0.071 (http://www.1728.org/resistrs.htm), which is lower than either one alone.
ImA4Wheelr
Last seen: 4 months 1 week ago
I wonder if you can get different modes.  Seems like a waste of an MCU to just have one mode.
This driver looks interesting.  Does anyone know if it has last mode memory?  I tried googling and searching a little bit, but gave up.  It looks familiar though.
