[sold out] SKY RAY 6 x Cree XM-L2 T6 3-Mode Cool White Light Flashlight - Black (4 x 18650) US$ 25,76 free shipping @ DX
226 posts / 0 new
Ejected Filament
Ejected Filament's picture
Im guessing, but I think he meant whether its xml v xml2…
one of us is misunderstanding anyway lol… its not the end of the world…
Beachlogger
Last seen: 11 hours 35 min ago
These look the same as the ones wallbuys had on sale for around 34 bucks back in November . XML x 6 but only 2 mode med -high
Edit to add… was just looking at wallbuys, a long press will produce a disco, so the wallbuys one is 3 mode.
unknown00101
I am so tempted. I want to get one to sell to a coworker, but I have a feeling I would just end up keeping it… Like always. Silly
blueb8llz
Last seen: 8 hours 11 min ago
cant believe these kings are going for so cheap nowadays. stilll one of my all time fav. lights.
cnrffl1
Last seen: 4 hours 16 min ago
So far I have only single 18650 lights. This will be my first multi cells light. Does this light require special battery? I mean protected or matched unprotected cells? Thanks.
Pulsar13
Pulsar13's picture
Last seen: 11 months 4 days ago
This is parallel config, it is quite forgiving. You can use between 1-4 batteries. It is recommended to have matched set of course, but it is not as crucial (vs serial config).
Protected cells are recommended as previous SRK drivers allow rundown to around 2.3V which is bad for the battery. And that stop is not even caused by the driver, it stops only because the Vf of the XML already reached its lowest. In other words, the known SRK drivers did not have low voltage protection. No reason to suspect this driver will implement it, as they normally only copy each other. Smile
Wolf
Last seen: 6 years 11 months ago
This one is 6x, that should happen sooner at least?
cnrffl1
Ordered one. Thanks for the heads up.
jps
I ordered one too, couldn’t resist this offer! Now I need 4 protected 18650’s for this SRK. What to choose?
1. Sanyo red 2600mAh —> $8,36 /pair
2. Panasonic NCR18650a 3100mAh —> $12,50 /pair
For this goal, I’m leaning towards the cheaper Sanyo’s. Any good reason to go for the Panasonics?
koyotee
koyotee's picture
Last seen: 6 months 2 days ago
You get 6 sanyos(15.600mah) for the price of 4 panasonics(12400mah) Smile
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
jps
Hehe, nice insight if mAh’s was the only decision criterium Smile
As I understand, the discharge curve of the Sanyo’s is more flat. I consider this as an advantage for the SRK. Am I right?
sirpaul
You’ll get more high-brightness time with the Sanyo’s, but less overall run time. Personally, I always use fresh batteries when using it to show off anyways, so prefer to simply have a higher capacity on the batteries. I keep it on low mode hours at a time, so the more time between battery swaps, the better. It’s all user preference!
unknown00101
Odd my Sanyo’s have more resistance than my 3400mAh panasonics. Leading to lower brightness with the Sanyo’s and less runtime.
B42
B42's picture
As said above if you are showing it off you are prob using full batteries= no diff. On a long usage you arent needing the extra time of absolute of max output probably, you want more run time. Depending on how its driven, it may be 6 hungry LEDs @1.6A (guess), so I guess ask yourself if it has 65min vs 85min of battery, how long are you going to walk, and if longer than 60 min, are going to want to carry and change out 4 batteries in the dark. Remember its unpredictable though because we dont know what the LEDs are driven at, or if it is less efficient, it could be a more significant difference if they are driven better, could be 40 mins or less with the 2600mAh’s.
ImA4Wheelr
Last seen: 1 month 6 days ago
I hear you brother.
dantemens
Last seen: 1 week 5 days ago
Mine’s on the way, and have sent me the message.
Dx has behaved again.
B42
B42's picture
So tempting even as 6x XML, I’m finding “reasons” to buy more myself…gifts for family and mobile lamps right? But then the reality of “they need batteries, charger and education” creeps in, and I guess I’ll have to keep them all myself… Silly
DayLighter
DayLighter's picture
Last seen: 4 years 5 months ago
ugh.. weird, DX won’t let me pay with paypal Silly
The only way to do a great work is to love what you do.
southland
southland's picture
Last seen: 2 months 2 days ago
Had the same problem, don’t click on pay with paypal, click on the other one and them select paypal on the next page, worked for me.
DayLighter
I always get this message “ 0×80042021 : A match of the Shipping Address City, State, and Postal Code failed “
when I tried to pay with paypal :Sp
Gj
Gj's picture
Last seen: 7 months 2 weeks ago
Wolf wrote:
Pulsar13 wrote:
This is parallel config, it is quite forgiving. You can use between 1-4 batteries. It is recommended to have matched set of course, but it is not as crucial (vs serial config). Protected cells are recommended as previous SRK drivers allow rundown to around 2.3V which is bad for the battery. And that stop is not even caused by the driver, it stops only because the Vf of the XML already reached its lowest. In other words, the known SRK drivers did not have low voltage protection. No reason to suspect this driver will implement it, as they normally only copy each other. :)
I think it may happen later (someone check my logic). With 6 emitters, each is likely driven at lower current than typical 3 emitter versions. At lower current Vf is lower, allowing the cells to be discharged lower.
jps
Sold out!!
DayLighter
never underestimate the power of BLF Big Smile
OscarM
Last seen: 4 years 5 days ago
maybe it was a pricing mistake? like when they had ultrafire m5 for $1.30, after a while they changed to “sold out”, instead of adjusting the price.
(DX themselves said something about it being an activity for loyal customers to hunt down bargains IIRC)
pacbough
pacbough's picture
Last seen: 4 months 1 week ago
They did put up a post for this light on facebook yesterday with the same price. So I don’t think it was a mistake.
jps
Thanks for the answers, and I may conclude there’s not a real winner. I arbitrarily decided to go for the Panny 3100, $35 for 3 pair @DX.
cia212
Wow, I’m a little surprised DX would actually tell people it’s out of stock.
DayLighter
more like they realized their pricing mistake and decided to pull it out Wink
B42
B42's picture
Probably is a “mistake”, though they also probably still dont lose money on it at that price. From what I’ve heard about a year ago, they could sell SRKs for $20 and be OK, so +$5 for 3 old XMLs (maybe T4s or T5s), its still within that range.
southland
southland's picture
Looks like a good candidate for a custom pill with so many buying the same light at the same time. Vestureofblood, bucket, ryansoh, hope I got those names right from memory.
