I would like to buy a few of these if anybody has a handful (~5).
I’d still be interested even if you have one.
The Tir reflectors from IOS and fasttech will fit in an f12
http://www.fasttech.com/products/1606/10007055/1574902-21-2-12-6mm-pmma-optical-lens-for-cree-xm-l-t5-t6
Thanks Serifus. I have a few of these actually but still would like a few of these for a project of mine.
So nobody has any?
http://www.fasttech.com/products/1209601 - should be nearly the same thing, the S3 original part measures 20.4mm x 11.6mm
Also check with RMM, he's converting S3s to triple XPG2/TIR so he should have a stockpile of leftover reflectors building up.
Thank you CC. I have actually talked to Richard a few weeks back when I originally posted this. He said he sold them with the lights in case anyone wanted to convert it back. And thanks for the link. That might actually work. XR-E reflectors usually work well with XM-L’s don’t they?
Yep. They both use the same 7mm hole, only difference is the XRE parts usually have a wider base because they don't need the clearance at the wire solder pads like on a XML/16mm MCPCB. You can just file a little bevel off the edge if you need more room.
