Test/Review of Keeppower 18650 3200mAh (Black) 2014
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 2 hours ago
DSC_4824
Official specifications:
  • Min Capacity: 3100mAh
  • Typical Capacity: 3200mAh
  • Normal Voltage: 3.7V
  • Quality Lithium Ion rechargeable cell made in Korea
  • Maximum capacity and reliability
  • Size: L:69.00mm*D:18.50mm
  • Cell made in Korea
  • High Discharge Rate (Max 2C)
  • Protection Circuit (Against overcharge, over discharge, over current and short-circuit.)
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Over 500 times of charge and discharge cycle life.
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-info
This is the highest capacity cell with 4.35 volt at the current time, but due to the protection the mAh is to low.
DSC_4823
DSC_4825 DSC_4826
DSC_4827
DSC_4828
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-Capacity
The discharge curves does not looke very nice, but that is not due to any problem with the cell, it is because the protection has intefered with the charging.
It can also be seen that the protection trips after some time at 7A.
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-CapacityTimeHours
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-Energy
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-PowerLoadTime
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-TripCurrent
Keeppower%2018650%203200mAh%20(Black)%204.35V%202014-Charge
Here it is obvious that one cell stops charging, before the other and probably neither of them is fully charged (The voltage drop when the charge current stops looks to large).
Test with 4.3 volt charging
Reducing the charge voltage slightly gets around the problem with the proction.
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-info
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-Capacity
The difference between 4.3 and 4.35 volt charging is minimal. This time the curves look fine.
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-CapacityTimeHours
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-Energy
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-PowerLoadTime
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-TripCurrent
Keeppower%2018650%203200mAh%20(Black)%204.30V%202014-Charge
Both cells is fully charged here.
Test with 4.2 volt charging
Keeppower%2018650%203200mAh%20(Black)%202014-info
Using a normal 4.2 volt LiIon charger does cost capacity, about 250mAh compared to 4.3 volt.
Keeppower%2018650%203200mAh%20(Black)%202014-Capacity
Keeppower%2018650%203200mAh%20(Black)%202014-CapacityTimeHours
Keeppower%2018650%203200mAh%20(Black)%202014-Energy
Keeppower%2018650%203200mAh%20(Black)%202014-PowerLoadTime
Keeppower%2018650%203200mAh%20(Black)%202014-TripCurrent
Keeppower%2018650%203200mAh%20(Black)%202014-Charge
Conclusion
Being based on LG cells, it is good batteries, but with the slightly low protection voltage they do not give the full benefit of the higher voltage.
Notes and links
The batteries was supplied by Keeppower for review.
Edited by: HKJ on 03/18/2014 - 11:36
sesgum
sesgum's picture
Last seen: 2 days 2 hours ago
Thank you for the great review!
HKJ
HKJ's picture
B25364 wrote:
Where can these LG cells be found without the protection ?
Try a google search for the cell type number, I got a match on Fasttech.
B25364 wrote:
Have you reviewed the unprotected cell ?
Not yet.
B25364 wrote:
LG is Korean But DLG is Chinese ? AFAIK
Correct, that is the reason it says "Cell made in Korea" on the label.
HKJ
HKJ's picture
B25364 wrote:
Did they change it just because of your review?
Definitely not due to my review, but maybe the comments or they are not using a Seiko chip.
Lithium
Lithium's picture
It appears you reviewed the older version of this cell, new one says it is now using a pcb with a higher voltage protection, can you confirm?
HKJ
HKJ's picture
I do not know if they have changed anything since I received the cell in January.
If they send me a new battery with a higher protection voltage I will, of course, test it.
Lithium
Lithium's picture
In fact While looking for this cell I came across two cell with different protection circuit stated by seller:
http://www.akkuteile.de/keeppower-18650-3200mah-3-7v-li-ion-akku-geschue...
http://www.akkuteile.de/lithium-ionen-akkus/18650/keeppower/keeppower-18...
It appears you reviewed the second one
