Solarforce Z1 - 1600 lumens on your keychain
68 posts / 0 new
Jalben
Jalben's picture
Last seen: 5 days 9 hours ago
Fine, I’m in for one. Also I’m stupid envious of all that you’ve done in this thread.
TODO List:
Acquire more parts.
Devise cheap way to make TIRs.
Rub some bacon on it.
Finish something that I
blfdemigod
blfdemigod's picture
Last seen: 4 years 8 months ago
comfychair wrote:
http://75.65.123.78/z1/Dsc07610.jpg
Oh my goodness man, what do you use to polish this baby this buttery smooth. Mothers mag and aluminum polish? HFT stick polish? I need to know with what and how! Amazing.
My collection 2 Small
Disclosure:
comfychair
comfychair's picture
Last seen: 6 years 4 months ago
Yep, well, Eagle One mag/aluminum polish (it's just jewelers' rouge) first on plain printer paper with a little paste smeared on, then a final light polish with a tiny bit of paste on cotton cloth. I go straight from wet sanding on 600 grit just to get it flat and then right to the polish, all that crazy mess with multiple grits before polishing is just wasted time, the end product is exactly the same.
ezarc
Put me down for 1 in the group buy Beer
blfdemigod
Thanks. Now I know the secret to get an amazing mirror finish. I tried using mothers mag polish on a light, with a cotton dremel pad and I swear it looks nothing like the mirror finish you created. 600 grit is the key I see!
Disclosure:
unit311
Last seen: 2 years 11 months ago
A triple in a light this small? I thought the Z1 was bright in stock form, I honestly never thought I would see a light this small pushing this many lumens. You are doing great things for this hobby. Please do us all a favor and sell us one of these.
scottyhazzard
scottyhazzard's picture
Last seen: 3 years 3 months ago
Wait, jewelers rouge on printer paper after the 600 grit…? Do you mount the assembly upside down in a drill press and the bring the piece down onto a flat plate with paper and rouge? Or hold the piece upside down and do figure 8’s as with lapping a surface? However it’s done, the results are very impressive. A new gold standard.
"Those who hammer their guns into plows will plow for those who do not."
comfychair
Use the paper+jewelers' rouge on a glass plate, just like you would if you were using ultra-fine grit sandpaper.
scottyhazzard
Thanks, Comfy!
comfychair
http://75.65.123.78/z1/Dsc07632.jpg
Keep these 219B, or switch to XPG2 4C?
nofearek9
nofearek9's picture
Last seen: 1 week 6 days ago
well done
comfychair
The only driver I have on hand that will fit into the pill is one of these things. Not bad, really, 5 mode with blinkies but it doesn't have memory and resets back to high after only about 1 second. Bridging the pad between the MCU pin and the ground ring switches it to 3 mode: high, low, strobe.
http://75.65.123.78/z1/Dsc07643.jpg
The little FET is awful, even with the resistor removed it only does 5.5A from a 20R, but of course a 20R won't fit in the light. The 16340s I have will only do about 2.75A. I have some AW 16340s on the way, and eventually the driver will be replaced with a BLF 15DD. I also have yet to polish the TIR before I make a judgement on whether shaving it down to ~17mm affected the beam. I think the Nichias are going to get replaced by some XPG2s, especially if the amps are going to stay in the please-don't-burn-my-hand-again range.
http://75.65.123.78/z1/Dsc07661.jpg
http://75.65.123.78/z1/Dsc07653.jpg
http://75.65.123.78/z1/Dsc07660.jpg
retiro675
Last seen: 2 years 10 months ago
Shocked very good work! is an amazing mod, I love it Love
PH_Oton
PH_Oton's picture
Nice build! What are your expectations of amps on IMR and XP-G2s?
Looking forward for final results Smile
comfychair
Oooh shiny, that's better
http://75.65.123.78/z1/Dsc07675.jpg
comfychair
Don't know yet, I haven't used either the new-design driver or the AW IMRs yet. I'll have to experiment with it a bit.
djozz
djozz's picture
Last seen: 5 days 5 hours ago
I vote for Nichia 219b 5500K! The Vf at 1.5A (that is about what it is going to be per led?) is 0.15 V lower than the xp-g2, with the same output.
comfychair
I used these: http://www.kaidomain.com/Product/Details.S022972
Well... what I mean is, the ones I used are whatever they sent me after I ordered that SKU and since it's KD there's not necessarily any relation between what it says there and what I got.
djozz
djozz's picture
The 5500K version is this one:
http://www.kaidomain.com/product/details.S022877
And because of the lower Vf it is really going to give more light than the xp-g2 as long as you do not go over 3.5A per led.
DB Custom
DB Custom's picture
Last seen: 3 hours 23 min ago
Excellent build. You’re really doing some fine work with that set-up on your lathe end mill drill-press. Way to think outside the box, love it.
comfychair
Ceiling bounce numbers...
100% stock Z1, fresh(ish) CR123 (2.93v OC), 1.59A (input): 12.4 lux
TR-801, 3x XPG2 R5 4C, FET driver, NCR18650 2900mAh (4.11v OC), 5A (input): this thing is crazy. At switch on it only does 33.x lux, but climbing rapidly - at around the 1:20 mark(!) it finally levels off at 61.3 lux, and hangs there for another 30 seconds, then finally starts to fall verrrrrrry slowly, 0.1 lux per about every 15 seconds.
The 3XP Z1, 3x Nichia 219B B11 SW45, crappy driver, crappy 16340 (only 3.93v OC), 3.35A (input): 33.4 lux at switch on, but falls rapidly (in line with the rate the current sags because of the crappy cell, it's not heat related). I need some real 16340s (it does 5.5A with a 20R, should do similar with an AW IMR, even if I don't swap the driver).
Beam profile seems fine even with the mutilated TIR.
Rufusbduck
Rufusbduck's picture
I like the OTB thinking and finish work on that light. Pm me if you want me to mail you a couple 2502’s for the BLF15DD.
Scott
Let-There-Be-Light
Let-There-Be-Light's picture
Last seen: 6 months 3 days ago
devman wrote:
Ahh, you used proper tools. Basically, you cheated. Silly
As punishment, I’m afraid we’re just going to have to put up a “comfychair modded-z 2 1 group buy” thread.
I’ll take 2. Can we get them signed by a good modder like Old_Lumens Silly
- Joe
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 3 months ago
There are amateurs, modders, tweakers then there are MODGAWDS
Comfy firmly rests in the all caps category…no freeking way I would EVER be that good at what he does!
comfychair
Rufusbduck wrote:
I like the OTB thinking and finish work on that light. Pm me if you want me to mail you a couple 2502's for the BLF15DD.
Heh, too late! I ordered a bunch of crap this morning, including some of those and an assortment of Oshpark boards. And some end mills. And (finally) a cross slide vise for the drill press, so I can adjust the feed by just turning a knob instead of whacking the table sideways with a hammer...
scottyhazzard
I was just looking at end mills. Little ones by proxxon that I will likely never be able to budget. Here Wadya get?
comfychair
Haha, not a vertical mill, just end mill bits for the poor abused drill press. http://www.ebay.com/itm/350462906524 Smile I needed one big enough to cut more than 1/2 the diameter of the pocket in a pill, so the whole surface can be cut just by rotating the part and not have to reposition it and make multiple passes... it never ends up close enough to flat when I do it that way. And one of these.
Next month, maybe? http://www.ebay.com/itm/390734932029
SchwarzeWolke
I don’t want to repeat myself but this is plain awesome!!!
Ledsmoke
Ledsmoke's picture
Cracy numbers you are pushing in that little package. Sure seems the like a helluva progress that is happening on this forum for the last few years. And you are one of the guys who just keep pushing the envelope. TY for sharing.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
comfychair
Update: It does 4.65A with a AW IMR16340 & still using the little toy driver. Current drops like a rock though, and it does the same with an 18650, I don't think the driver is very happy! Tired
