I started making my own p60 drop ins for fun. I really liked the cool white 1A tint for brightness at first at 2.8 amps these are as bright as the Manafont direct drive drop ins, but now I am totally infatuated with the 1D tint.
I use these P60 empty drop ins
http://kaidomain.com/ProductDetails.aspx?ProductId=11201
I use the Nanjg 105c 2.8 amp drivers.
http://kaidomain.com/ProductDetails.aspx?ProductId=11088
I use these isolation discs.
http://kaidomain.com/ProductDetails.aspx?ProductId=1745
I was using these cool white XML 1A on 16mm stars.
http://kaidomain.com/ProductDetails.aspx?ProductId=11130
I use these Shiningbeam XML premium tint 1D on 16mm stars.
http://www.shiningbeam.com/servlet/the-34/**NEW**-Cree-XM-dsh-L-T6/Detail
Here is some parts fresh out of the envelope.
Drivers are soldered, 3 mode selected and ready, going to prefit everything before I solder the emitter and driver in and glue it down with Fujik on both sides driver and emitter.
Driver is glued and soldered in, looks good.
Emitter is glued in and the isolation disc is stuck on top to prevent shorts to the reflector.
Used an OP reflector, it is good to go now to find a host to test it in.
Host 504B XML 1D on left XML 1A on right low mode.
1D on left 1A on right medium mode
1D on left and 1A on right high mode.
I am really liking the 1D tint. The camera really captures a very accurate tint color. Now what do I do with all the 1A tint drop ins I made? What do you guys think about these 1D tint emitters?
